Hi All,
1.Could you please explain the usage of Shift lock in Suzuki Swift?
2.Sometime I've noticed that gear can not change from "P" position to other positions (Eg "D").To move the gear into other postion I've to do it while pressing "Shift lock" button.Is that normal?
3.I heard that shift lock useful to fuel economy? Is that correct?
Please explain how to use that function properly.
Shift lock is there to change gears when the ignition is not on. or the change gears without pressing the brake peddle(when the engine is switched off)
another use of shift lock is. if the transmission is jammed for some reason. using shift lock you can change the gears
It has Nothing to do with with fuel economy. ABSOLUTELY NOTHING.
