Hi peeps,
looking for a place that does a full automatic transmission oil flush. Where they inject new oil from the trans cooler and fully flushing your trans oil with out removing the trans oil drain plug.
Also where can I find Toyota T-IV oil
Thanks!
It would help if you indicate your location so that those members in your area can respond with recommendations. However, ATF exchangers are available with almost all major service stations. Same goes for Toyota T-IV ATF which is freely available  at most automotive spare part shops and the agent'. BTW I do not consider use of an exchanger without the use of the drain plug as the best method for a complete flush unless your specific circumstances  warrant such procedure. You may go through the following thread for some insights on the complete procedure even though DIY may not be your cup of tea.
Edited by Rumesh88
