PCV Valve Grommet fell inside engine
pantheraleo
Hi All,
The PCV Valve rubber grommet fell inside when I was trying to change it as a DIY job :(
I can’t see it and I feel it’s somewhere inside the engine, is it a bad idea to use the car with a rubber part like that inside.
2000 Honda Accord 2L
Edited by pantheraleo
On 3/18/2022 at 6:16 PM, varotone said:
Inside the engine means inside the cylinder? How did it fall inside?
If it fell inside the cylinder, DON'T START THE CAR. Take it to a place with a borescope. They can remove whatever is inside without removing the cylinder head.
Thanks for your reply, no it was not inside the cylinder. I was able to get the rubber grommet out after removing the rapper cover.
