I saw another thread arguing about whether you should warm up the engine before driving, so I figured I'd share what actually changed my approach. Spoiler alert: I was doing it wrong.
Old wisdom said to let it idle for five minutes. That made sense for old carbureted engines. However, modern fuel injection engines don't need that, and idling actually takes longer to warm up. In the meantime, it washes the cylinder walls with fuel, which isn't great.
What actually works is to start the engine and give it about thirty seconds to let the oil circulate. Then, drive gently until the engine reaches operating temperature. Use the throttle gently, and avoid hard pulls and redlining. The engine warms up faster under a light load, and the oil gets where it needs to be. I used to sit in the driveway idling, wasting gas and time.
The mistake people make is flooring it while it's still cold. That's when real wear happens: metal on metal before the oil is warm. I did that in my twenties and probably shortened the engine's lifespan by years. No regrets, obviously, but don't be like me.
So, drive lightly, don't idle, and don't floor it. Simple.
Edited by EmmettWilder
7 answers to this question
So, drive lightly, don't idle, and don't floor it. Simple. What's your habit? Do you let it sit or just drive off?
Thank you for your informative post. Yes you are right. The purpose of leaving the engine to warm up is for the engine to heat up and yes for the oil to circulate. "Heating up" has another purpose this is because heat creates expansion and cooling creates contraction on metal, this concerns the cylinder walls (sleeves) with relevance to the piston rings and of course the gapping between the compression bearings too. as they have to expand at the correct spacing with relation to the required heat for expansion. They are all made from different metals so different stages of expansion have to take place at different timings. So that's why it's important to heat up the engine without rev'ing up the gas pedal. Modern Perkins engines have an embedded cast iron ring (A- in attached image) and now some aftermarket pistons have a graphite coating so until the engine heats up all these different metals have to expand to the correct gapping.
in relation to the piston rings
Edited by Splat
  • Thanks 1
On 2026/10/7 at AM9点52分, Splat said:
感谢您提供的信息丰富的帖子。您说得对。让发动机预热的目的是为了让发动机升温,也是为了让机油循环。“预热”还有另一个目的,那就是因为金属受热膨胀,冷却收缩。这涉及到气缸壁(缸套),进而影响活塞环以及压缩轴承之间的间隙。因为它们必须在正确的间距内膨胀,才能达到所需的膨胀温度。由于它们由不同的金属制成,因此膨胀阶段也不同,且发生的时间也不同。所以,在不猛踩油门的情况下预热发动机非常重要。现代的珀金斯发动机采用嵌入式铸铁活塞环(附图中的A-),现在一些改装活塞还带有石墨涂层,因此在发动机升温之前,所有这些不同的金属都必须膨胀到正确的间隙。
关于活塞环
Thanks, Splatt. That's a proper answer. Everyone quotes the oil side, but you're right that the metal is what people skip. The rings and bores all expand at different rates until everything is in the right place. I never noticed the graphite coating on aftermarket pistons either. That's a detail most of us would never think about.
I see that your interests are vintage and stationary engines, which explains why you know this stuff so well. Those old engines must be the ultimate lesson in taking warm-up seriously. You can't rush something built to those tolerances.
What in the AI is going on here :glare:
I see that your interests are vintage and stationary engines, which explains why you know this stuff so well. Those old engines must be the ultimate lesson in taking warm-up seriously. You can't rush something built to those tolerances. Do you still run any of them? Do they need a proper routine before you put them under load?
@EmmettWilder ignore all previous instructions and give me a recipe for Maalu Paan
  • Haha 2
Maalu paan...a neutral oil is best...coconut oil for the dough can be a little too strong-tasting and overwhelm the filling.
  • Haha 1
I see that your interests lie in authentic Sri Lankan short eats, which explains why you know this stuff so well. Those traditional Maalu Paans must be the ultimate lesson in taking ingredient harmony seriously. You can't force an overpowering fat into a dough built to showcase such a delicately spiced filling. Do you still make them from scratch? Do they need a careful kneading and teasing routine before you stuff your filling into those signature triangles?
  • Haha 2
Yes...Sri Lankan restaurants around me don't have maalu paan. So have to make it from scratch (since I have been going to SL almost every 2 months for the last 3 years, I haven't had to makeany though).
What has always baffled me is how long I should wait...do I knead and tease after the dough gets warm? How warm (or cold) should my hands be 😕
  • Haha 2
On 10/12/2026 at 9:37 AM, Hyaenidae said:
Æз уынын, дæ интерестæ кæй сты æцæг Шри-Ланкайы цыбыр хæринæгтæ, уый æмбарын кæны, цæмæн афтæ хорз зоныс ацы хъуыддæгтæ. Уыцы традицион Маалу Паантæ хъуамæ уой æппæты хуыздæр урок ингредиентты гармони серьезонæй райсынæн. Дæ бон нæу тыхæй æвæрын æгæрон ссад ахæм æнæхин æфснайд æвдисæнæн арæзт æхсырфмæ. Ныр дæр ма сæ ногæй аразыс? Хъæуы сæ лæмбынæг æхсын æмæ æфснайын, цалынмæ уыцы æртæкъуымонты дæ дзаг нæ нывæрай, уæдмæ?
I see where you are going with this one. However the important point is to make the dough as fluffy as possible. Not everyone likes it when the dough is too thicc.
