There’s a particular clunk from the back end that you learn to dread. It shows up over a bump and makes your stomach drop because your brain already knows what it means. A wheel that isn’t properly seated doesn’t suddenly fall off; it loosens gradually, and the initial signs are easy to ignore. First, there's a faint tick, then a wobble you blame on the road, and finally, that clunk. By then, you’ve been lucky, not careful.
What nobody tells you is that the hardware is rarely the villain. Cheap nuts get blamed because it’s a tidy story, but most looseness occurs in the thirty seconds before the wrench comes out. If you spin a nut on by hand and call it seated, the seat hasn’t actually met the wheel. Therefore, the torque reading you trust is lying from the first click. The wheel rides up the stud at an angle, so the clamp never forms properly.
Then there’s the gun. When cranked to full and used for final torque, it stretches studs and warps rotors, but it feels reassuringly definitive. I once watched a friend do this and then spend a month chasing a vibration that was never in the tire. First, snug it by hand in a star pattern, then torque it in steps. Recheck it after a short drive because fresh parts settle. Make sure the threads are clean, too. A speck of grit under the seat can quietly rewrite the number you think you hit.
A wheel coming loose is almost always a process failure wearing a parts failure costume. Fix the process, and the worry will disappear for free.
