Nissan Lucino Fb14 Fuel Consuption
I'v got a Nissan Lucino GG 1500cc and the fuel consumption is too bad compared to other 1.5 Nissans. It goes only about 7.5km/l (im not a sporty driver and shift up whenever possible). Recently i got a tune-up done but it didn't work. How can i fix this and is there a particular fellow to try?
2 answers to this question
Have you changed your petrol filter machan? Try Bruce Nigel of Brucemotorsports. He's pretty good. pm me if you want his contact details. His garage is in Thalahena. Other places might be better though, the others will let you know.
That's very low. When I had mine I used to do 13+ with even my style of driving. But it was properly tuned and well maintained throughout. Start with a basic check {start with plugs, I had platinum... but not necessary… replace with a new set of standard NGK if your plugs are worn-out, Check filters… replace if required, and also check oil and other filters at the same time}
