Hi bikers,
Since recently, I'm experiencing heavy vibration when raising the engine or accelerating beyond 40kmph. What can be the problem? Any ideas.
Az
Hi bikers,
Az
Admins, please remove the repeat posts. When I submitted the form, there was a server error. So I submitted it several times, which has resulted in duplicate posts. Sorry about the inconvenience.
two things i can think about
1) you have a leak in your air hose
2) your bikes starving for fuel which means its running lean or fuel line is clogged
maybe ripper can give you a better headsup on it
Hi bikers,
Az
what's the bike? the vibration...say if you were to rev the motor up in neutral....do you still get it?
like Yala had said...if the bike is running lean and starving for fuel...you can get this kinda vibration!
If the motor is starving for air and can't breath properly, this can happen
but in both instances...performance should drop drastically! it should have poor acceleration especially in mid to high rev range...bike should be bad in puling!
engine vibration can also come from internal mechanical issues of the motor!
It is a Bajaj Pulsar, a regular bike I use for commuting to work, nothing fancy :)
Yes, it was vibrating even when revving it up on neutral... the bike become really shaky after 60kmph. I gave it for repairs today, and will be collecting it in the evening. They say that the clutch balancer had to be replaced. I will update this thread once I get the bike back.
Thanks Ripper & Yala
can possibly be the case then...there's a counter balancer to eliminate vibration as the engine is turning...
Yes, that was the problem. They managed to repair it, and didn't have to replace it.
probably done some work at a lathe shop!
sometimes those jobs dont hold up for long though! lets that wont be the case with yours :)
But Mr. Silvy Wijesinghe will be thrilled to find out that even in this era, there are mechanics who can repair these items instead of replacing them/ LOL :D
well lets leave that gentleman alone.
it's a huge generation gap issue and pointless arguing about it :)
  • 1 month later...
Guys,
Can the same be happen with a car ?
Few days back when I was driving my sisters car, I felt certain vibration when it reaches 80km/h....Its an Auto.
Any ideas?
thanks
