Dear All,
I/m planning to add q winch to my bj43..
Can I get some expert ideas from you'rll. shall I go for a electric Winch or Shall I go for a Manual winch........
How much will it cost.....
Dear All,
Sir ,
Can you give more details of the winch what you require Voltage Pulling capacity fixing method.
Wijesinghe.
Dear All,
manual u means mechanical right, we'll electric is good as long as u hv a good battery, mechanical is much better cz it runs straight from the engine but u hv to know how to use it properly n mechanical wont wrk when ur engines off( :) ), for a BJ43 9000lb's will be more than enough, i think mechanical has a much better pulling capacity cz it runs straight from the engine if ur going for a mechanical get a recon OEM toyota winch+ pto + shaft from a recon shop n if required a warn winch cable
How much will it cost?
Winch....
PTO.......
& what kind of PTOs we can fix for toyota Bj43? Same as Mitshubishi? or something different?
Winch....
PTO.......
i dnt think Mitsubishi PTO would wrk for BJ cz the Gear Box is Different so your gonna have to find a Toyota one, but has to be around 50K
