deco
Everything posted by deco
  1. Can someone please recommend a place for me to repair a laptop?? my problem is not powering on and the brand is Acer.. Thanks in advance.
  2. The difference between BKR5E-11 and BKR6E-11 is the heat range. First one is more hotter than the latter. all the other aspects are the same. it is not advisable to switch between heat ranges bcos more hotter plug can damage the engine. On the other hand colder ones do not damage the engine but fouls in a much shorter period. Irriduim plugs are also available it ends with suffix IX as mentioned. As i mentioned above BKR5E-11 's Irridium option would be BKR5EIX. 11 means the plug gap is 1.1mm. But with Irridium the plug gap is not adjustable i think. Thanks
  3. There is a sensor called "Mass Air Flow Sensor" normally fitted in between the air filter and the throttle body. Once this sensor gets contaminated the same kind of symptoms could appear. Please have a good look at this sensor through a qualified technician as this is a very fragile and easily get damaged. I strongly advice you to have this inspected before going any further.. Thanks
  4. There is a mechanical part called "Thermostat" in every engine to keep the engine in optimum operating temperature. this helps to burn fuels in more efficient way keeping the fuel economy and minimizing the pollution. The thing is Sri Lankan mechanics always tend to remove this part every time they do a engine repair.. better check the thermostat is still there with the engine.
  5. Hi Priya, If you can give us details how we can have those is much appreciated. Thanks
  6. deco
    Electric Fan Kit
    Hi dhp, Its an old lancer.. Actually the stock fan is fixed to the water pump without even a fan clutch. so it spins w'ther the engine is cold or hot.. I heard that those fans are consuming engine power thus effecting the milage. So i thought of doing this as an experiment all by my self.. I think the electric thermostat is the harder part, right?? if you can help me to find parts, and places, would be much appreciated.. Thanks in advance
  7. deco
    Electric Fan Kit
    Has anyone here installed an electric fan replacing their stock radiator fan?? If so more info in this is much appreciated..
  8. Thank you Don..
  9. I searched the web and found lots of places with the matching one. They are much expensive when coupled with shipping expenses. The thermostat is much neglected part in an engine, specially in sri lanka. no one cares about it. but when it malfunctions either engine over heating or running below efficient temperature will result.. Thanks
  10. Please help me to find a Thermostat Valve for my old Mitsubishi Orion engine. If you can give me a place where to buy would be much appreciated. The thing is the engine never comes to its normal operating temp. i know this will increase fuel consumption and efficiency too. most of the mechanics remove these stuff thinking its useless. if its useless why does the manufacturer fixes them?? Please help me to find it.. dont just say that my engine is too old and live with what it has.. Thanks
  11. Thanks mate. I just wanted to do the timing in a proper way..
  12. Hi niro123, I too live in Piliyandala.. So.. if you can give me the exact location of the place you did yours would be much appreciated.. Thanks
  13. Its an old lancer with a 4G36 (Saturn 1200cc engine)
  14. Does anybody know a good place or garage to clean and repair a carburetor?? A place near Piliyandala is much prefered.. Please help...
  15. From where did you find the disks?? is it from Panchikawatta or any other used parts dealer?? BTW how do you know you can fix them for sure??
  16. Hi all! Is anybody having a lancer Wagon A75V model with a 4G36 engine, in this forum???
  17. One Punchikawatta guy said that they are having the salvaged ones for Rs3,500/- each. The thing is they can not be trusted and most probably the ones they are offering are nearing the end of their life span. that is why I thought of replacing with relatively new ones if it permits to do so..
  18. Hi all!! Mine is a 12 sri Lancer wagon (A75V). The problem is when I applied brakes the car drags to the left. After consulting my mechanic, said that some of the rear wheel drum brake parts are missing and some are worn out thus causing the automatic brake adjuster seizing to work. Actually my parking brakes are also not working which is an obvious result. My question is will it be possible for me to replace the rear drum in all with ones which are available with used parts dealers?? Is the drum and the backing plate is compatible with all cars (not the very recent ones)?? I would be much appreciated if you can give me a clue if resolving this matter. I have heard that some Lancer wagons are fitted with disk brakes and all. So there may be one or two guys out there who can help me with this.. Thanks
  19. Thanks TT, I also heard that mytools might be having the stuff. Can pls give me the address or any contact no on the vendors you mentioned??? Thanks again
  20. Hi all!! I'm looking for an Ignition timing light and a Dwell meter. Can anybody give me a clue in finding a vendor in Sri Lanka? or Does anybody have an old one willing to sell?? Would be much appreciated if someone can help me out with this.... Thanks
