thara123
thara123's Achievements
Hi All, I have Toyota Aqua S Grade 2012/10 car. I have NSCP-W62 navigation system in built. My car has mono display system indicator(I mean i cannot change to different system indicator screens such as Energy indicator etc. using multifunction Disp key in steering wheel). My question is, Can I sync the Dashboard System indicator with my navigation system to see different system indicator screens from navigation system screen? I saw a Youtube video which did like that. Unfortunately, it has removed by the user. Thanks in advance
Hi All, Now I have imported a Toyota Aqua 2012/10 S Grade reconditioned car, one week back. it has already run 6000kms. My question is, 1. Do I need to do the service before further running the car? 2. What kind of service do I need to do(full service(oil changes, changing filters etc.))? 3. if yes for 2, which engine oil do I need to replace(i might need to ask the service centre about this)? 4. Do I need to do the first service from toyota lanka or else any other recommended places? Thanks in advance.
Check Engine Is Indicated And Stopping Car
thara123 replied to thara123's question in Mechanical problems
Hi All, again,thanks all for your replies then my car was again stopped and it kept running 1-2 minutes and automatically stopped. inside the distributor there was a noise like sparking. then i took my car to electric place in kiribathgoda. they replaced the ECU and now car is running up to now . and now new distributor i bought is fixed to the car. but now there is a problem. Always RPM is going around 2000 before and after comes to the heat in both parking(P) and N mode either A/C on or off. when i put to the D mode, it reduced to the 1100 RPM. that electric guy said there might be a problem in throttle body sensor and i need to do a tune-up. Please advice me on this Thanks- 9 replies
- distributor
- check engine
(and 1 more)
Thanks for your all replies. I was looking at all of your ideas until I fixed the Computer box before reply. My friend had replaced some of capacitors on the circuit board and then garage people fixed that computer box back to the car today. then we have run test drive for around 10 kms. then I drived only 15kms and up to now, car is running. I'm not sure when its stopped again. bad thing was now car is running under the previous distributor. my money was lost like. i bought it from N.I.N in wijerama. and they will not return money for it. thanks all for your valuable ideas.- 9 replies
- distributor
- check engine
(and 1 more)
Hi Guys, I have a toyota carina AT192 car. While i was driving 10kms suddenly check engine is indicated and car was stopped. Then I had to drag the car to a garage. then they attached a scanner and scanner indicates "Ignition system" and they said i need to replace the distributor. then I bought a distributor and attached it to the car and they replaced one of relays. garage people drived the car for around 6 kms and then that problem did not come back. after 3 days, again when i was driving the car for 2 kms, again the same problem occurred. then garage people attached my previous distributor back and checked. they brought the spark plug wire to top and spark plug wire is sparked some times but some times it does not. then they removed the computer box and checked. some capacitors are overflowed and computer circuit board has brown color patches there. then they asked me to replace those capacitors. still that replacing capacitors is in progress. so please tell me what would be the actual issue and what should i do for this issue? thanks in advance
- 9 replies
- distributor
- check engine
(and 1 more)
thanks all for replies. Car_Madness, smoke color is somewhat white/blue like. i could see that smoke upon starting and then that faded away with the time, but it increased smoking with more revs. Ripper, i counted it and result is 50 blinks for 25 seconds. still I have not changed the PCV valve.in the sense, without changing new PCV valve, i checked the diagnosis. I have no idea about this OBD1/2. Can you tell me how to do that checking? I checked with home garage. no any oil is available around the area. smoke is increased as engine revs increased. do you guys have recommended place except agent if i need to replace rings set?
thanks for the reply. Sanjeev, Can you give me his contact no. I ll contact and show him the vehicle. and do you guys know other expertise about this issue other than toyota lanka. if so, just give me contact nos.
Hi All, I have a Toyota Carina AT192(1995) car. It has run 130000km. When I'm running the car, some times it is blinking the check engine bulb. but it is not always coming on. when the bulb comes on, car is running slowly. once i checked with a garage. they scanned and said there is a problem with the oxygen sensor and instructed me to do a engine tune up. they said u might have to change the oxygen sensor then. But I connected the TE1 and E1 in the diagnosis and check the check engine bulb. it is blinking normally as recommended. and other problem is i need to put engine oil time to time. i think engine oil is burned more than normal condition. i informed this to the garage and they said you have to change the rings set first and then do the the engine tune up. they said without changing the rings set, no point of doing the engine tune up for that check engine problem. for this issue, my friend (mechanic) said just put new PCV valve first and check still this engine oil issue is there. please give me the correct advise for this issue. because I'm confused with this different advises of different people.if i have to change the rings set and do the engine tune up with genuine parts, what will be the cost like? what is the suitable place to check this both issue? thanks
can somebody tell me a good place to tune the engine? I'm in Gampaha, but a place around colombo is OK orelse tell me a contact number.
Thanks. Guys, Will this low RPM like 600 and 750 lead this vibration problem? When I went to the garage, Mechs just turned a screw which is connected right at the end of the accelerator cable and tried to reduce the RPM in the cold start. This caused to reduce RPM?
Thanks guys for the reply. Other thing is I feel a bit high vibration in side the car. And If this 1200 RPM is high in cold start, what should I do?
Hey guys, First I thank both of you very much for the reply. This happened only at cold start, as I said earlier its 1200 RPM. When It comes to its normal operating temperature, when the gear position 'P' its 750 RPM. and when the gear position 'D' its 600 RPM. These two values were not changed both with and without A/C, even with the High A/C. But I felt A/C is bit low in a few days. Guys, Can You tell me what I should do next? Still I didn't go for a tune. Thanks a lot again.
Hi, I have a toyota carina AT192 car with auto transmission. The problem is when I start the car and keep idling without putting the A/C, RPM value is 1200 RPM (its one + 1 unit). This is when the car is in "N" or "P" gear positions. I checked with a guarage. First they just turned a screw which is connected right at the end of the accelerator cable. but it was not done. They are saying that first tunning up the car and it might solve the problem. If the problem is still there, I have to replace this item (i dont know its an electronic gadget and its name) which is under the end of the accelerator cable (white color one). Can somebody tell me wht is the correct way to solve this issue?. And If I have to replace that gadjet, what is the price of it and the name? I dont know these details are enough for solving this. thanks
Hey, I bought toyota carina at192, 1995, full option from 1.2 million. is that worth these days?
