vidura
Everything posted by vidura
replaced the reverse switch with japan one cost 2750/= regarding the break sound my mechanic guy told it is normal and comes due to ABS activation.
Great i will check this weekend and update you. Yes i used aftermarket brake pads it cost me around 4000/= for frond disk pads
hi i got 2 issues recently hope you guys can help on this too my reverse light + reverse sensor didnt work from last week. Bulbs and others are ok hope the issue in reverse light switch. Can i know where is it? Can i replace/repair it at home or do need to go to garage? When i do sudden breading at speed more that 20KMph i hear some "kata kata" sound like coming from front side. Not immediately like 1 second after breaking. No sound in normal breaking only on sudden stop. I replace all the break pads 2 months back too. Is it due to ABS? Or any other issue?
regarding the display It didn't obstruct field of view much . I place the display as much as lower for clear view. Regarding the wires hear i post the image just after fix the display yesterday i don the wiring for the display and hide all the wires that were in all over the dashboard. I will upload a image soon.
Thnx for the information. Hope my airbags will work when it needs Anyway did you see the my display installation (posted 2-3 articles before)? Does anyone know the place to make eyebrow http://www.e-shoppinghouse.com/index.php?main_page=popup_image&pID=1191
yes this car is brand new imported fro permit. As i know airbags on only if seat is belt wear. SO in that case if my car does not have sensor to check seat belt status does air bag is on always?
does CS has seal belt warning light. It was their in my manual. But really not exist in my car. Does my bulb gone? but i cant see the wire that connect to seat belt
planing to buy alloy wheel set for my car any cheep good place around colombo?
Done the cleanup on last week and still didn't notice the RPM fluctuation after that. Hope issue is solved thnx for the great help Regarding the display that we discuss early stages finally i end up with my own installation like this
Great and clear information thank you for every thing I will try it this weekend.
thnx for the quick replies. I will check the vacuum lines and PCV. How we can check the PCV and tube for blocking? Do i need to go to garage for that? can we remove and clean the ICV valve without removing complete throttle body?
RPM fluctuation noticed during without AC and didnt check with AC When i on AC idle RPM 1000 always yes don throttle body cleanup during tuneup I just brought and done the tuneup and no idea about before that. Put i noticed this issue after running nearly 1500km after tuneup
I done tune up 2000Km back. The issue notice during the traffic while AC is off but blower is working. other think my RPM vary on 750-850 without AC and with AC it is 1000
Hi Mi car idle RPM vary between 750- 850 But some time while in the traffic idle RPM increase to more than 1000 (nearly 1200) sometime it comes to 850. Also i have some feeling it has more acceleration when i release the paddle (that is it takes some times (10-15 sec) to come to normal 850 rpm. Is it normal or any issue?
Same output for me as well
after tuneup my one doing 10KMPL in city and done 13KMPL in kandy trip. But still some people are saying it should do more like 10-12 in city
i used the command that u mentioned ATIB 96 \n ATIIA 13 \n ATSH8213F0 \n ATSP4 \n 0100 by adding as custom command under car profile but still it not connecting to ECU
im having the paid version of torque can i know which protocal that i need to select and where from the app?
today i got ELM327 scanner and tried to connect through the torque free version but application says Scanner cannot connect to the vehicle ECU anyone able to work with ELM327? or any better software to communicate?
after the tuneup also it does around 9.5- 10 in city limit. Most of the time i drive in economical way but i stay around 15-20 min in traffic daily (daily i do around 22Km). Last week i done emission test and CO2 level is 0.01 in idle and 0 in 2500RPM. Does any one get higher figures for CS3 2007 version? Or is the figures are normal?
than what type of scanner suitable for lancer
First you remove the existing bulb and check their socket type (T5/T4/T3) Then search it on ebay. Ebay has any type of bulb with any color so u can easily find them. You just want to sure about the socket type
no idea about local place but in ebay u can find those bulbs. those are T5 type bulbs. I also ordered some and waiting for them http://www.ebay.com/itm/230696520962?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 hope them will fit to my dashboard
is model is matching the CS3 car? there is two ports under steering one is white and black. Is black one is scanner port? then what is white port
Did anyone import OBD scanner for lancer CS3 2007 car. or any one know which type suit for it?
