lathsara
Everything posted by lathsara
  1. Thanks for the help
  2. Dear Administrator, Pls check the time tag in the site. I think it is 1/2 hr more than the correct time. Rgds Lath
  3. I also like one. It is better if u can post a sample of that.
  4. I’m using Mitsubishi L200 4WD Double Cab. I have a problem in my Break system. Problem is in the front wheels disk breaks. Some times my vehicles front wheels get heated much more than normal. And at that time my break peddles also very tight. And if I drive ignoring it again it get loosen and front wheels comes to normal temperature. I checked it with my mechanic and first time he changed the break washers in the break pump. Again same thing happened and he said it is a problem in the caliper set and change both caliper sets. Still Im having the same problem some time break peddle is loose as normal and some time it is very tight. Do you have any suggestions for that? I really don’t know what to. Thank you
