prad
Everything posted by prad
  1. I got a KR42 which had a issue on one of the locks on the passenger side, Got a guy called Dineth 0710311117 to have a look. Checked it and said that the motor had busted Paid 1500 and replaced the motor. Now the problems begin. After this guy leaves I notice that the light on the door does not light up when opening. OK must be the guy forgot to plug in the connection. Thereafter power shutter makes a crackling noise when going down with the door lock shaking. Thereafter again the door does not get locked not even manually. Called this guy and complained. His responds should be a small issue show a near garage what ??? You come to fix the door lock and mess the door light mess the power shutter and after paying for your service mess the door lock again and I have to take it to a garage and get it checked ??? Word if caution don't get caught to this cheat again
  2. Hi there I would appreciate if someone could comment on the various brands of engine oils available in the market. Are there differences in the oils as advertised by the suppliers or are all oils the same? I have been using Mobil for my car (petrol) and should I continue the same oil. Will there be any repercussions if I change to say Caltex ect.. and what about the locals stuff or the Indian oils such as Servo they too have oils from 20w to 50 mentioned. Are they good as they advertise ??? would appreciate some feed back
  3. prad
    Citroen
    Hi there, I got a Citroen Xsara and lately noticed that the signal indicator goes off even when the handle is in the idle position (middle) guess there’s a loose connection , is there a good place I could get it checked out or even replaced ? showed it to the company and they need 1 month to get the part down. Is there a easy way ? Prad
