Noobdriver
Everything posted by Noobdriver
  1. First of all, inspect the car in person and see if it has any obvious issues and if it does, decide if you want to bother dealing with it. Then check service records. They might say that they have service records and they'll hand it to you when you take the car home but do not fall for it. Tell them you won't even consider closing the deal without seeing and inspecting the service records. It is not very hard to throw a piece of paper into a file and keep that file somewhere safe (especially if that could make a vehicle you own more valuable when you re-sell). If the car has been less than 5 years since registration (rare these days), I would expect full-service records. If it is more, then I would expect 5 years of service records. Ask them if you could take pictures of the records or get a photocopy. Also, inspect that the service intervals have been met properly and tally the mileage across intervals and current. The emission records would also be able to help you tally the mileage. But don't fret too much over the mileage, these are very easy to play around. Pay close attention to the repairs done, and see if they've used genuine parts or used Chinese knock-off parts on repairs. If It is not genuine parts, just walk away. They never loved their car and never cared for it. No point wasting time on a car like that, you might have to redo all those exact repairs soon. One quick trick that I kinda realized is the oil viscosity during service intervals. If the car has not been modified (engine/ECU), and if the viscosity suddenly changed from a factory-recommended viscosity to something higher, it might be a clear indication of a potential engine oil burn. Ask them why they changed the oil viscosity and note down their response somewhere. Based on all the groundwork you did above, find a reputable business capable of conducting an inspection. Hand them the service records to go through and identify if any areas need extra attention. Also, tell them about the viscosity change reasoning and ask them to verify if that was true (some cars just burn engine oil while some don't). Hopefully, they'll be able to give you a report of the issues identified. Ask them for an estimate to repair all of those issues (ask for a physical estimate document). Now if it has minor issues (less than 2-3% of the vehicle value, don't fret too much and you should rather be expecting something of that sort when purchasing a second-hand vehicle. So now you know what the condition of the car is, and if there is anything major, decide if you want to even bother with it. If you don't, move to the next car. If not, add up all the major repairs and add a 20% buffer on top and that is your cost to repair the car to optimal condition. Do a final market research on a comparable car and determine whether the car price is fair. Offer the owner his asking price minus the cost of major repairs with the 20% buffer. If they flat-out refuse, just walk away. If they're willing to work with numbers, pull out your repair sheet and negotiate as much as possible. At the end of the negotiation, if their final price adjustment reflects at least 50-65% of the repair cost, then it is time to seal the deal. Ask them for their CR Copy and send it to your bank for initial verification and once you receive their go-ahead, give them an advance (25k-50k usually, don't give more) with the condition of at least a week's worth of time (sometimes the leasing process takes long). Instruct your bank to make the transfer using 1-day service (More expensive but worth it). Once their DO is ready, the seller and you can meet at the bank for the exchange. This is where you can hand in the cash part to the seller as well. Good luck!
  2. GP1 is known to burn engine oil and watch out for the hybrid battery condition.
  3. Forgot to update this, @RusT The water leak was some piece/cover that had come off and, that fixed it. They tried explaining and I couldn't understand honestly. But the issue is 100% sorted now, been over a month. Also, they did a rack-end overhaul to fix the 'tak-tak' sounds. It is much better now, still, the steering mounts need to be replaced, and they suggested deferring it (I don't understand why).
  4. If you are spending that much, just get a car on lease, at least you'll build equity. Also, you can only rent a shitbox at that price sadly, lol.
  5. My friend bought a 2015 Xtrail for 10M about 2 months ago. But he has also spent nearly 2M on repairs on restoring the car mechanically due to multiple neglected issues from the previous owner, which my friend used to his advantage by negotiating the price down by 2.5Mn (the car was listed for 12.5Mn).
  6. Hi, thank you for this. I have not done any windscreen-related repairs except for a polish. Either way, I dropped the car in today for a few things: Update - 24/June/2024. Dropped the car in to check the water leak (they too suspect an AC line block). There is also a very loud noise audible when going through a rough damaged road as previously mentioned and the technicians believe it might be a steering rack issue and not the shock mount but they're going to investigate this.
  7. Update time! Hit the 1,000 km mark on Friday, 21st of June, 2024 since the overhaul. I took my car for service yesterday, 22nd June 2024 and they did the following: Engine oil change - Toyota 5w30 Oil filter change There was an issue with the front brake pistons, so they cleaned them up and changed the brake oil (since cleaning the brake piston drains the old brake oil). I informed Hybrid Hub about the "shock mounts" requiring to be replaced as suggested by Hybrid Hub during the vehicle check-up after the overhaul. I confirmed this from a trusted wheel alignment center employee before I dropped the car in for service. Hybrid Hub suggested that this repair doesn't need to be done and I could do this repair at the next service (after 2,500 km). However, the moment I took it down to the road, there was a series of explosive "tak-tak" sounds every time I went through not very smooth roads as explained by the wheel alignment guy, who told me that the shock mounts were completely gone and needed immediate attention. I still drove to the wheel alignment place and asked him to re-check and see if what they were telling was the truth and he re-checked (they raised the car) and re-confirmed that this needs immediate attention or could result in camber damage. I will drop the car again tomorrow (Monday, 24th June) at Hybrid Hub to get them to sort this for once. Another problem I have is that when I'm driving during rain, there is a water leak or something near my accelerator/brake pedal that leaks a couple of drops of water. Curious to know what the problem is as I've told Hybrid Hub multiple times to check this issue and report back.
  8. That must be expensive to do, eh?
  9. Awesome, any recommended silencer joints in Colombo? Also, by SS you mean Stainless Steel, right?
  10. I have a Toyota Vitz with a 1.5" Exhaust pipe (default) and I want to fit a new cool-looking exhaust tip on the boring pipe, but I can't find any that is less than 2". Any suggestions on how to get this to work? p.s. purely aesthetic, not trying to increase the sound or anything.
  11. I am not sure what's better, but around '09, it was hard for us to find a decent-condition '04 Toyota Vios. All of them were extremely beat up over a very short period (Only 5 years..). Make sure you get the car checked by a reputed company before purchase or you'll end up spending a million rupees on repairs like me.
  12. Thanks for the valuable advice @tiv @iRage. @tiv If my engine can run without issues for 100,000 kilometers, more than enough for me. I don't go out much, I would at most drive 10,000 km a year and a significant chunk of it would be road trips/traveling during breaks. I only drive about 300-500 km a month for my actual chores since work is not that far from my house and I work from home and go to the office twice a week (hybrid). I don't mind another overhaul after a decade, lmao. I plan to keep the car for as long as possible (at least 5 years) and never want to sell it if I upgrade the car in the future and be able to keep my current as well (first car love). I've driven roughly 200 kilometers now and went to Bentota last night. Here is how I went, please correct me if I'm doing something that could be improved or wrong: Gently touch the throttle and bring it up to 50 km/h, maintain for 2-3 minutes. Release the throttle entirely till it brakes automatically to about 30 km/h (a good 15 seconds). Slowly throttle back up to 50 km/h and maintain for 2-3 minutes. Release the throttle entirely till it brakes automatically to about 30 km/h Slightly throttle a little more to 50 km/h and repeat. Also, when there were signal lights ahead, I just left the throttle to let it come to a stop on its own and brake towards the end. Also, I was surprised to see that over the 200 km, I drove yesterday, my fuel economy was 22 kmpl for the trip, I've never seen this number before. The most I have ever gotten was 15 kmpl on the highway at 80-90 kmph
  13. Check Delkanda, they should have it.
  14. Check Delkanda for a replacement part, also, if it is on the arm of the wiper, then you might have to replace the entire wiper arm.
  15. Yes, all the seals were replaced and the gasket too. I've driven about 60 km since I got the car back (they drove about 70 before handing me the car), and so far, it's smooth. I'm maintaining around 50 km/h at very low RPMs.
  16. Thank you @iRage, @tiv, and everyone here for the advice! Much appreciated! I will keep updating the progress on the post-overhaul maintenance, etc.
  17. Update on 8th June 2024: I got my baby back today and seems to run fine. The total damage was 361,000 LKR (50k VAT, ugh!!!). What was done: Rings were replaced. The engine was fully cleaned up. The general overhaul kit. Spark plugs were replaced. CVT oil was replaced. Post-overhaul maintenance schedule: 1000 km after overhaul: Engine oil change, filter change. Apart from the above, the brakes seem to have an issue which requires it to be repaired. Engine Coolant is recommended to be replaced after the 1,000 km since it was not changed during the overhaul. Shock mounts need replacing. 🥲 2000 km after overhaul: Car check-up will decide if anything needs to be done. Overall, the experience wasn't too bad, apart from the typical Sri Lankan stuff where you keep visiting the workshop to ensure the work is being done. If I had not visited today, I wouldn't have been able to collect the car today (the car was fully done, their testing was complete and they only had their 30-point inspection checklist to be performed).
  18. Update on 7th June 2024: I visited Hybrid Hub and the engine here are the updates: The engine is fully assembled. All the parts have been put back together in the car. @tiv I had a chat with the mechanics, and they took the "1. Replace rings, refit (No pitting on pistons, perfect Bore)" path. They also replaced the CVT oil. All seals were replaced with the head gasket, the water pump is getting replaced, and new coolant is being added (was running on water or something for testing), Forgot to specify specifically about alternator bearings, AC compressor bearings, radiator, and starter motor. They've promised to do their "30-point" inspection on top of going through a detailed review of all components that might need work - The mount looks like it needs to be replaced and there's an issue on the shock mount as well it seems, which I recently replaced, weird, but they promised to give me more context tomorrow (8th June).
  19. Why buy 2018 Vitz at 9Mn, find a 2011-2013 Vitz at 6-6.5Mn (KSP130), use it nicely and then you can sell it when you're ready to get a better car (if the car prices drop, you will not lose too much).
  20. I'm curious to know the same too, and I wonder if the companies here would even be able to do it properly. I'd shit my pants if my engine required re-boring lol
  21. Update on 5th June 2024: I visited earlier today and got the following updates: Ordered parts from abroad have arrived. They should be able to complete the assembly of the engine today and will work on fitting the engine and the components on the car tomorrow. Massive carbon build-up was identified on the Valves and was cleaned out (not replaced). The pistons did not require replacing and were cleaned up due to excessive sludge and carbon build-up after being told there was no sludge.
  22. Hey, Thank you for the valuable advice. I recently got the gel mount replaced at Sterling. I have already informed Hybrid Hub to ensure that the other mounts are in good shape at the same time, Hybrid Hub assured me that they will be doing a thorough inspection of the entire car and let me know what needs attention and I could decide based on the cost. The Water Pump needs replacing and they have my go-ahead to replace it. All the seals will be replaced, and all the rings too will be replaced (I'm not entirely sure what they mean by "all" rings, I believe it is the piston rings only?). I saw the mechanics today, who were re-assembling my engine, and that's what they told me. Plugs were recently changed, during the engine tune-up at Sterling, should they be changed again? I will ask them about the "radiator and starter motor," thank you for pointing this out. I believe they're including an "engine tune-up" as well, which I think should cover all of this. My apologies, I'm not very knowledgeable, but I will make sure I highlight these and the CVT oil, which I believe was replaced recently too, but I have to double-check. I agree about the mileage, however, I use my car's odometer to track events such as service or repairs, and I don't necessarily believe that the mileage is accurate.
  23. Update on 3rd June 2024: I visited Hybrid Hub today to get an update, and was informed about the following: They have not been able to begin the assembly process due to parts unavailability and the parts they have ordered are expected to arrive tomorrow, 4th of June, 2024 following which they would be able to begin the assembly process. Per them, the car should be back in my hands on Thursday, 6th of June, 2024. Side note: The weather is messed up, I'm running a fever, ugh.
  24. I'll be documenting the entire process here if anyone's interested or for people in the future to get an idea of the whole process since I didn’t come across any online resource to be very comprehensive within the Sri Lankan context. DISCLAIMER: I'm not very knowledgeable about cars, however, this is the first car I have ever owned. Please correct me if I use incorrect terms. Also, please highlight any areas where I’m in the wrong. I'm willing to learn and get better. Knowledge is power, but incorrect "knowledge" is poison. Pre-context: I accepted delivery of my car on 6th September 2023 from Punchi Car Niwasa, Malabe who managed to sell me a car with a backlog of problems by working with their in-house Auto Miraj to provide a dishonest inspection report. Anyhow, I took the car to Sterling for my first vehicle service within 2 weeks of purchase, and a couple of weeks later dropped my car off to get the stabilizer, link boot, and shocks replaced as those were anyway due to be replaced and heavily damaged (Auto Miraj lied to me). How did I find out that they were due to be replaced? When I purchased the car, the wheel alignment was extremely off, the steering wheel had to be rotated 45 degrees to the right to continue going straight. The first thing I did was to drive to Laughfs for a wheel alignment as someone I trust recommended their wheel alignment services. The mechanic in that place told me about the above damages. A day after the job, the alignment was still off by a small amount but noticeable, so I took my dad's advice and took the car to a famous place in Maligawatta, and they told me the same thing. From this point onwards, my alignment problem was solved, however, the mechanic informed me to replace the components and get new tires (which I was aware of since the car had 4 different brands and models of tires all around and all of them were way older than 5 years (which the inspected report suggested 2 years). Fast-forward to a week later, I got new tires from Nankang (pretty good, the handling is amazing and the price-to-value ratio is phenomenal). I was informed by the sales representative to get a wheel balance and alignment done immediately, and as a result, I drove back to the famous Maligawatta wheel alignment shop. They did a phenomenal job once again and informed me that my car had an issue with the camber alignment and quoted Rs. 10,000 to correct it. I was surprised and asked my dad and a couple of people I trust and see as knowledgeable in the field of cars. To my surprise, everyone including my dad told me that a camber alignment never costs that much. I took my car to a different wheel alignment shop in Maradana and upon inspecting the reports from the previous wheel alignment shops, they told me that the camber alignments were fine based on the reports, and would be happy to generate a new report on their machinery, which I happily paid for and that report to confirmed the camber alignment was right. However, I was reminded that the same components were worn out and required immediate attention. I dropped off my car at Sterling the next day and settled a hefty invoice at the end of the job on top of being upsold on an engine tune-up because I complained about the acceleration power. Fast-forward to December 2023, a friend of mine was getting married in Galle and I was to drive there with a bunch of my friends before the trip, I decided to get a car wash at Auto Glance and requested them to inspect the critical components to ensure that I have a smooth ride to Galle and back. Naive me, unaware of the gravity of the situation was completely puzzled about the engine oil level on the dipstick being literally on the tip of the dipstick. They told me it was safe to go on the trip but to take immediate action when I returned from the trip. I dropped my car off at Sterling to get the situation inspected and sorted, on top of a problem with the brakes not being very effective, which required the brake liners to be replaced. They confirmed that there was no oil leak, nor did I find any traces of oil leaks in my garage. The service representative shows up out of nowhere sounding extremely pissed, telling me that the car’s engine was sludged and I was supposed to show up for an oil change after 3,000 km since the last service. For more context, I had driven 4,000 km since the previous oil change service so I agreed to his recommendation completely confused about the engine sludge story and being expected to return after 3,000 km despite the service tag and the service record book mentioning explicitly to return after 5,000 km or 6 months since oil change, whichever comes first. They performed the “full service,” and I drove off. However, after about 1,500 km of driving around to multiple cities, to enjoy my time off from work, I decided to check the engine oil levels, and to my surprise, it had a fairly significant drop so I drove back to Sterling to consult on the situation and they returned with three options moving forward: First option: Sell the car (their recommended option) - No way in hell that I would pass a broken car to someone else. Second option: To get a “reconditioned” engine (recommended option if I do not wish to sell the car). By this time, I had done my research online and understood that even if I did get a reconditioned engine, it still would need restorative work done and the underlying condition would be a big unknown. So upon raising this concern, they introduced me to the third option. Third option: The dreaded phrase for any car owner’s ears and wallet, “You need an engine overhaul.” They quoted a minimum of half a million rupees for the job. I called a good petrolhead friend of mine and asked for his advice. He suggested to allow his brother-in-law to assess the vehicle. His brother-in-law was apparently an experienced Toyota mechanic and if my friend suggests so, I believe him. However, his brother-in-law immediately told me that the piston rings needed replacing and the entire job could be done under Rs. 100,000. I immediately saw it as a red flag since he had not even taken the engine cover out yet to take a peak. I decided to get a second opinion at Auto Glance, and they too suggested that an overhaul is needed, however, I didn’t get a quote from them. After performing a bit of research, I found out that Edirisinghe Brothers are specialists in overhauls and so I decided to ring them. They connected me to a representative from their sister company, Hybrid Hub. Over the phone, the representative did not believe that a Toyota Vitz (1KR-FE) requires an engine overhaul and asked me to drop by. I emptied all my valuable belongings from the car and was fully prepared to drop the car for repair by the end of our conversation. I was greeted very well by Mr. Prakash from Hybrid Hub, he gave me a tour of their workshop and showed me some of the vehicles they are performing engine overhauls on and explained a lot of things about how engines work and why they may end up requiring an overhaul but at the same time, he had never heard of a 1KR-FE (Vitz) engine requiring an overhaul, especially at I believe it was 136,000 kilometers on the odometer at the time. He advised me that I should not drop the car immediately for an overhaul as he would like to further understand the gravity of the situation. He inspected the oil levels and noted down the mileage. He asked me to come back after I had driven 2,000 kilometers. I did so and the engine oil level had dropped significantly. We topped up some Toyota 15w40 engine oil that I brought with me. He suggested that I drive another 1,000 kilometers and get back to him. This time, there was no drop in oil levels for whatever reason. He asked me to drive another 1,000 kilometers and get back. I got busy with work and didn’t have the time to go back but returned after having roughly driven 2,000 kilometers. At this point, I was at 139,500 kilometers on the odometer. We saw a significant dip and that’s when he suggested two options: I could keep running the car if I don’t mind doing engine oil top-ups on time, however, this is not an option he would recommend. I could get an engine overhaul or an engine swap but recommended an engine overhaul. All in, for all the consulting and advice given by Mr. Prakash from Hybrid Hub, I was never charged a dime. I was impressed by the fact that they did not want to accept my car for an engine overhaul immediately without properly being completely sure that the car was burning significant amounts of engine oil when they could have just taken the job and made a quicker buck. With that in mind, I decided I would go ahead with Hybrid Hub and handed over my car for the overhaul on the 27th of May, 2024. By the end of 28th May 2024, I was told that the dismantling process was complete. Today, the 29th of May 2024, I was missing my little car, so I decided to visit the workshop and meet Mr. Prakash at Hybrid Hub. He reunited me with my in-complete car, fully ripped apart and it broke my heart to see my car in that state. He apologized for not being able to send the cost estimate on time, which was promised to be sent over by 3 pm on the 28th of May, 2024, and promised to send it over by noon tomorrow, the 30th of May 2024, which would be based on the report from their head office on what needs to be done and from there, they would require my go-ahead to perform the engine overhaul. One thing was shocking to hear though, there was extremely minimal sludge in the engine and that pissed me off. The guy at Sterling lied to me and I was extremely disappointed. Never going back in there, ever again. For those interested, here are some photos of the car, however, the head and the block of the engine are not present here as they are at the head office.
