Steph740
My Vehicle Details
  • Vehicle Make
    Toyota
  • Vehicle Model
    Camry
Steph740's Achievements
  • First Post Rare
Recent Badges
  1. The problem is most likely related to the transmission oil cooler you can check the location of the leak by applying pressure to the system. If this is indeed the problem, then you need to replace the transmission oil cooler. if you need oil or spare parts, look at globy.com. then thoroughly flush the cooling system to remove all remaining oil. after all this it would be good to check the transmission and engine.
  2. The brake pads may need to be replaced if squeaking occurs during or after braking. or worn wheel bearings. also check the shock absorbers, maybe they need to be replaced
