Pasan_Robotics
Everything posted by Pasan_Robotics
  1. Yes i bought lots of items from them. I bought some items today here r some pics
  2. What r the PIC Micros that u r looking for machan ? PICs r normally hv in SL. At Pettah. But not ATMELS. I also looking for some Atmels like ATmega8515, ATtiny. But c can order those from FARNELL SL joint at OS Projects ( PVT ) Ltd No.49, Sri Jinarathana Road, Colombo 02 Tel: 4792103 , 4792105 http://www.farnell.com/distributors/srilanka_osp.htm I hope above infos r useful for u Good Luck Bro
  3. Hi hi heee pin probes r grate for me. Or im going to hack my connecter. This soft is grate for my future home made Intel P4 CAR pc.
  4. Soonly i hope to make that cable. after i do it, i'll put my results here. Its new to me. Soonly i hope to make that cable. after i do it, i'll put my results here. Its new to me.
  5. This is very cheap. actually 500/= bugs is enoughf for this. hi hi heeee. If u go to the agents can u play arround with ur car. hi hi heee u cant. I like to play with my car using this software and using my electronic knowledge. But if something goes wrong with ECU unit I hope to go to the A MW.
  6. Hey guys u can make the cable by ur self. U only need comport. Ya this soft is not for free. But u can find crak for it easley. Ok here is the schematics for cable ( make it ur self ) http://www.plmsdevelopments.com/images_if/...ult_if_rev4.pdf Download Program http://202.43.226.57/NissanDataScan1_52.zip Crack http://rapidshare.com/files/4350981/upload..._Anilrgowda.rar Pass Still i also didn't try this. Coz i have no time to make that data cable. But as soon as posible i'll make it and test my FB14 (sentra). HACK THE WORLD
  7. 1. ECU Part Number Nissan Identification part number -------------------------------------------------------------------------------- 2. Data Display Resizable window Analogue and digital gauges Peak value display Parameters depending on ECU: RPM Air Flow Air Flow Right Hand Water Temperature (C or F) O2 Sensor O2 Sensor Right Hand Speed (KPH or MPH) with tyre size correction Battery Voltage Throttle Position Sensor Fuel Temperature (C or F) Intake Air Temperature (C or F) Exhaust Gas Temperature Injector Time Ignition Timing AAC Valve Air Fuel Base Air Fuel Base Right Hand Air Fuel Base Self Learn Air Fuel Base Self Learn Right Hand Injector Time Right Hand Duty Cycle Duty Cycle RH O2 Sensor B1 O2 Sensor B2 Registers: Closed TPS Power Steering Air Conditioning Switch Start Signal Neutral Air Conditioning Relay Fuel Pump Thermo Fan VCT Waste Gate Solenoid Air/Fuel ration (lean/rich) EGR Solenoid -------------------------------------------------------------------------------- 3. Data Logging Parameters and registers as per Data Display -------------------------------------------------------------------------------- 4. Active Test Engine Temperature Timing AAC Valve IACV Valve Air/Fuel Base VCT Fuel Pump Cylinder Off Base Idle Adjustment clear Self Learn -------------------------------------------------------------------------------- 5. Self Diagnostics Read Fault Codes Reset Fault Codes -------------------------------------------------------------------------------- 6. Speed Trial Measured times (kph or mph): 0-60 0-100 50-100 0-xx xx-xx And many more options Supportable Vehicles Nissan Data Scan software has been tested on following cars: AUS 200SX S14 (SR20DET) AUS 200SX S15 (SR20DET) AUS Maxima A32 (VQ30DE) AUS Pulsar N14 (GA16DE) AUS Pulsar N14 (SR20DE) AUS Pulsar N15 (GA16DE) AUS Pulsar N14 (SR20DE) AUS NX/NXR Coupe (SR20DE) JDM 180SX S13 (SR20DET) JDM Silvia S14 (SR20DE) JDM Silvia S15 (SR20DET) JDM Pulsar GTi (SR18DE) JDM Pulsar GTiR (SR20DET) JDM Bluebird U14 (SR18DE) JDM Bluebird U15 (SR20DET) JDM Skyline R32 (RB20DET) JDM Skyline R32 GTR (RB26DETT) JDM Skyline R33 (RB25DET) JDM Skyline R33 (RB20DE) JDM Skyline R33 GTR (RB26DETT) JDM Skyline R34 (RB25DET NEO) JDM Avenir PWN10 (SR20DE) JDM Infiniti Q45 CAN '92 Infiniti G20 (SR20DE) US 300Z Z32 (VG30DETT) US Sentra B13 SE-R(SR20DE) US '94 Sentra B13 (GA16DE) US NX2000 (SR20DE) US NX1600(GA16DE) US Maxima A32 (VQ30DE) US '93 Altima (KA24DE) US '99 Altima GXE (L30, KA24DE) UK Almera N15 GTI (SR20DE) UK 200SX S14a (SR20DET) UK Micra K11 (CG13DE/CG10DE UK 1993 Primera P10 (SR20DE) FRA 200SX S14 (SR20DET) FRA '93 100NX 2.0 GTI (=NX coupe) (SR20DE) GER Almera NX (GA16DE) GER 200SX (SR20DET) GER '91 300ZX Z32 (VG30DETT) Primera HP10? SR20DE(T) Cefiro A32 VQ20DE FIN 99 Maxima A32 (VQ30DE) Here r some screen shots
  8. My connection is ADSL. No problem with my firewall. two or three monthes ago, there is no problem with same settings.
  9. I cant see any picture in BUY section. I also Installed flash player. What will be the problem?
  10. Automotive repair shops that use the ALLDATA system have a clear differentiation from other repair facilities. AllDATA-equipped shops can provide their customers with the most accurate repair estimates and proof of diagnostic and repair procedures. ALLDATA also includes factory-correct maintenance schedules that itemize additionally needed services. Moreover, ALLDATA helps shops build consumer confidence and loyalty. Professional repair shops need current, factory-correct information to meet the complex repair demands of today's automotive industry. ALLDATA shops have fast access to the industry's best information for vehicles from 1982 to present, including TSBs, maintenance schedules, manufacturer recall information, OEM solutions and factory diagrams. ALLDATA DVD, the leading computer-based diagnostic, repair and estimating information system, can help you boost shop performance and build customer loyalty as you efficiently repair more makes, while reducing comebacks. Reinforce your expertise with current factory-correct automotive information. The most comprehensive information for 1982 to present vehicles, diagrams and diagnostic flow charts. Parts and labour information. Maintenance schedules. Manufacturer TSBs and recalls. Integrated estimating software. OEM wiring diagrams with connector, ground, power distribution and splice information. A2Z Component Search - the fastest route available to component information. A2Z Component Search ALLDATA offers you its unique A2Z component search feature. When you enter the full or partial component name, the system automatically displays the information route. Information is only a click away. Automotive Service Information Structure Information is structured around the needs of an automotive service business: maintenance; diagnosis & repair; parts and labour; technical support. Automotive Oriented Lookup Hierarchy (Component Indexing) Component Indexing arranges the entire ALLDATA database into a single, consistent information format - organized the way a master technician thinks and works. From the vehicle to the component level, all relevant information types are consistently listed together. You get fast, easy access, reduced search time and more efficient diagnostics. Year, Make, Model & Engine Specific Information presented applies to specific year, make, model and engine (YMME) combination. Unrelated information about other years, makes, models or engines is not displayed. TurboView Navigation ALLDATA’s exclusive TurboView navigational tool automatically tracks the information that you look up as you use the system. A click of the mouse instantly displays a list of the component and subsystem information that you most recently looked up and makes it readily available to you. Advanced Hyperlinking ALLDATA’s editorial staff creates hyperlinks so that you can easily and quickly move to related articles. With hyperlinks, you can move between all related repair articles from a single screen. Split Screen Text & Image Viewing (Image+Text Display) ALLDATA saves shops time with its adjustable split screens for simultaneous viewing of repair procedure text, plus images. The Image+Text Display eliminates the need to move between multiple screens. The zoom feature allows close-up viewing of diagrams and illustrations. Comprehensive Vehicle Manufacturer Coverage You get factory diagrams (including wiring, ground, connector and exploded diagrams), service precautions, repair illustrations, factory diagnostics procedures, and connector locations. Advanced Technical Service Bulletin Features TSBs give you access to the most up-to-date factory fixes available. Unlike other information systems, ALLDATA TSBs are linked all the way to the component level. If a TSB applies to the information being viewed, it is easily spotted by the user and accessible with a mouse click. Simultaneous Parts and Labour Lookup (Image Hot Spots) Image Hot Spots provide the fastest, easiest way to identify the exact parts you need. Just click on the highlighted parts within exploded diagrams and the system automatically displays their OEM part numbers, prices and associated labour times. Integrated Parts and Labour Parts and Labour are fully integrated with the other ALLDATA vehicle information. No need to change the DVD! ALLDATA Customer Reception Tools Use ALLDATA's shop operations or any description of operation article to help your customers' gain valuable knowledge and a general understanding of what may be needed to fix their vehicle. Integration - Open System Ready ALLDATA supports iSHOP, the industry integration standard. Open System Ready enables software manufacturers such as shop management software (SMS) companies to integrate with ALLDATA’s repair information. For more information on iSHOP, go to [www.ishopstandards.org/overview.htm]. Custom Annotations Annotations provide a great way for shops to create their own helpful hints regarding specific repairs. Technicians can pin customized notes to any specific repair article or image. These annotations remain in place, even after database updates, for all shop technicians to view on future repairs. Tune-Up and Maintenance Specifications ALLDATA provides a centralized tune-up database location for quick access to routine service data such as ignition timing, idle speed, firing order, fuel pressure and air/fuel mixture information. More information: www.alldata.com DO NOT REPORT LINKS ALLDATA DVD 8.50 Program (~117MB) http://rapidshare.de/files/30031474/AllData.part1.rar.html <<<< CRACK http://rapidshare.de/files/30031915/AllData.part2.rar.html <<<<< CRACK [refer to "AllData 8.5.txt" for install info] General Motors DVD1A (~2.5GB ISO in 100MB rar's) http://rapidshare.de/files/29611528/GM1A.part01.rar.html http://rapidshare.de/files/29614984/GM1A.part02.rar.html http://rapidshare.de/files/29626465/GM1A.part03.rar.html http://rapidshare.de/files/29636590/GM1A.part04.rar.html http://rapidshare.de/files/29647493/GM1A.part05.rar.html http://rapidshare.de/files/29658112/GM1A.part06.rar.html http://rapidshare.de/files/29667254/GM1A.part07.rar.html http://rapidshare.de/files/29672952/GM1A.part08.rar.html http://rapidshare.de/files/29675889/GM1A.part09.rar.html http://rapidshare.de/files/29678310/GM1A.part10.rar.html http://rapidshare.de/files/29681040/GM1A.part11.rar.html http://rapidshare.de/files/29683012/GM1A.part12.rar.html http://rapidshare.de/files/29684832/GM1A.part13.rar.html http://rapidshare.de/files/29686511/GM1A.part14.rar.html http://rapidshare.de/files/29688174/GM1A.part15.rar.html http://rapidshare.de/files/29689727/GM1A.part16.rar.html http://rapidshare.de/files/29691275/GM1A.part17.rar.html http://rapidshare.de/files/29692864/GM1A.part18.rar.html http://rapidshare.de/files/29694776/GM1A.part19.rar.html http://rapidshare.de/files/29697930/GM1A.part20.rar.html http://rapidshare.de/files/29701209/GM1A.part21.rar.html http://rapidshare.de/files/29705530/GM1A.part22.rar.html http://rapidshare.de/files/29710322/GM1A.part23.rar.html http://rapidshare.de/files/29715999/GM1A.part24.rar.html http://rapidshare.de/files/29721741/GM1A.part25.rar.html http://rapidshare.de/files/29726813/GM1A.part26.rar.html http://rapidshare.de/files/29731207/GM1A.part27.rar.html http://rapidshare.de/files/29731926/GM1A.part28.rar.html General Motors DVD1B (~3.3GB ISO in 100MB rar's) http://rapidshare.de/files/29819722/GM1B.part01.rar.html http://rapidshare.de/files/29821229/GM1B.part02.rar.html http://rapidshare.de/files/29822991/GM1B.part03.rar.html http://rapidshare.de/files/29824836/GM1B.part04.rar.html http://rapidshare.de/files/29826690/GM1B.part05.rar.html http://rapidshare.de/files/29828786/GM1B.part06.rar.html http://rapidshare.de/files/29830880/GM1B.part07.rar.html http://rapidshare.de/files/29833213/GM1B.part08.rar.html http://rapidshare.de/files/29835701/GM1B.part09.rar.html http://rapidshare.de/files/29838237/GM1B.part10.rar.html http://rapidshare.de/files/29841173/GM1B.part11.rar.html http://rapidshare.de/files/29844189/GM1B.part12.rar.html http://rapidshare.de/files/29847209/GM1B.part13.rar.html http://rapidshare.de/files/29850399/GM1B.part14.rar.html http://rapidshare.de/files/29853560/GM1B.part15.rar.html http://rapidshare.de/files/29856726/GM1B.part16.rar.html http://rapidshare.de/files/29860000/GM1B.part17.rar.html http://rapidshare.de/files/29863769/GM1B.part18.rar.html http://rapidshare.de/files/29867251/GM1B.part19.rar.html http://rapidshare.de/files/29870594/GM1B.part20.rar.html http://rapidshare.de/files/29880928/GM1B.part21.rar.html http://rapidshare.de/files/29894243/GM1B.part22.rar.html http://rapidshare.de/files/29904433/GM1B.part23.rar.html http://rapidshare.de/files/29913976/GM1B.part24.rar.html http://rapidshare.de/files/29916877/GM1B.part25.rar.html http://rapidshare.de/files/29919469/GM1B.part26.rar.html http://rapidshare.de/files/29926482/GM1B.part27.rar.html http://rapidshare.de/files/29928520/GM1B.part28.rar.html http://rapidshare.de/files/29806689/GM1B.part29.rar.html http://rapidshare.de/files/29808529/GM1B.part30.rar.html http://rapidshare.de/files/29810267/GM1B.part31.rar.html http://rapidshare.de/files/29930385/GM1B.part32.rar.html http://rapidshare.de/files/29812176/GM1B.part33.rar.html http://rapidshare.de/files/29813705/GM1B.part34.rar.html http://rapidshare.de/files/29815148/GM1B.part35.rar.html http://rapidshare.de/files/29816018/GM1B.part36.rar.html General Motors DVD2A (~3.8GB ISO in 100MB rar's) http://rapidshare.de/files/29697797/GM2A.part01.rar.html http://rapidshare.de/files/29701431/GM2A.part02.rar.html http://rapidshare.de/files/29705470/GM2A.part03.rar.html http://rapidshare.de/files/29709924/GM2A.part04.rar.html http://rapidshare.de/files/29715085/GM2A.part05.rar.html http://rapidshare.de/files/29720303/GM2A.part06.rar.html http://rapidshare.de/files/29726033/GM2A.part07.rar.html http://rapidshare.de/files/29959800/GM2A.part08.rar.html http://rapidshare.de/files/29962350/GM2A.part09.rar.html http://rapidshare.de/files/29965062/GM2A.part10.rar.html http://rapidshare.de/files/29967571/GM2A.part11.rar.html http://rapidshare.de/files/29970076/GM2A.part12.rar.html http://rapidshare.de/files/29973223/GM2A.part13.rar.html http://rapidshare.de/files/29976435/GM2A.part14.rar.html http://rapidshare.de/files/29985018/GM2A.part15.rar.html http://rapidshare.de/files/29994677/GM2A.part16.rar.html http://rapidshare.de/files/30054490/GM2A.part17.rar.html http://rapidshare.de/files/30056017/GM2A.part18.rar.html http://rapidshare.de/files/30057519/GM2A.part19.rar.html http://rapidshare.de/files/30058908/GM2A.part20.rar.html http://rapidshare.de/files/30060392/GM2A.part21.rar.html http://rapidshare.de/files/30062191/GM2A.part22.rar.html http://rapidshare.de/files/30063742/GM2A.part23.rar.html http://rapidshare.de/files/30065232/GM2A.part24.rar.html http://rapidshare.de/files/30066875/GM2A.part25.rar.html http://rapidshare.de/files/30068919/GM2A.part26.rar.html http://rapidshare.de/files/30070903/GM2A.part27.rar.html http://rapidshare.de/files/30073077/GM2A.part28.rar.html http://rapidshare.de/files/30075239/GM2A.part29.rar.html http://rapidshare.de/files/30077519/GM2A.part30.rar.html http://rapidshare.de/files/30079943/GM2A.part31.rar.html http://rapidshare.de/files/30082434/GM2A.part32.rar.html http://rapidshare.de/files/30091855/GM2A.part33.rar.html http://rapidshare.de/files/30094796/GM2A.part34.rar.html http://rapidshare.de/files/30104186/GM2A.part35.rar.html http://rapidshare.de/files/30114110/GM2A.part36.rar.html http://rapidshare.de/files/30122832/GM2A.part37.rar.html http://rapidshare.de/files/30132670/GM2A.part38.rar.html http://rapidshare.de/files/30142474/GM2A.part39.rar.html http://rapidshare.de/files/30149982/GM2A.part40.rar.html http://rapidshare.de/files/30157738/GM2A.part41.rar.html General Motors DVD2B (~2.8GB ISO in 100MB rar's) http://rapidshare.de/files/30160040/GM2B.part01.rar.html http://rapidshare.de/files/30161911/GM2B.part02.rar.html http://rapidshare.de/files/30167475/GM2B.part03.rar.html http://rapidshare.de/files/30169173/GM2B.part04.rar.html http://rapidshare.de/files/30170750/GM2B.part05.rar.html http://rapidshare.de/files/30172197/GM2B.part06.rar.html http://rapidshare.de/files/30173585/GM2B.part07.rar.html http://rapidshare.de/files/30175072/GM2B.part08.rar.html http://rapidshare.de/files/30176628/GM2B.part09.rar.html http://rapidshare.de/files/30178152/GM2B.part10.rar.html http://rapidshare.de/files/30179729/GM2B.part11.rar.html http://rapidshare.de/files/30181658/GM2B.part12.rar.html http://rapidshare.de/files/30184212/GM2B.part13.rar.html http://rapidshare.de/files/30186505/GM2B.part14.rar.html http://rapidshare.de/files/30188888/GM2B.part15.rar.html http://rapidshare.de/files/30191337/GM2B.part16.rar.html http://rapidshare.de/files/30193823/GM2B.part17.rar.html http://rapidshare.de/files/30196291/GM2B.part18.rar.html http://rapidshare.de/files/30198998/GM2B.part19.rar.html http://rapidshare.de/files/30201827/GM2B.part20.rar.html http://rapidshare.de/files/30204930/GM2B.part21.rar.html http://rapidshare.de/files/30207957/GM2B.part22.rar.html http://rapidshare.de/files/30212448/GM2B.part23.rar.html http://rapidshare.de/files/30215548/GM2B.part24.rar.html http://rapidshare.de/files/30227873/GM2B.part25.rar.html http://rapidshare.de/files/30240255/GM2B.part26.rar.html http://rapidshare.de/files/30250287/GM2B.part27.rar.html http://rapidshare.de/files/30261472/GM2B.part28.rar.html http://rapidshare.de/files/30269736/GM2B.part29.rar.html http://rapidshare.de/files/30272623/GM2B.part30.rar.html http://rapidshare.de/files/30273263/GM2B.part31.rar.html Chrysler DVD1A (~2.4GB ISO in 100MB rar's) http://rapidshare.de/files/30273693/ChryslerA.part01.rar.html http://rapidshare.de/files/30281187/ChryslerA.part02.rar.html http://rapidshare.de/files/30287401/ChryslerA.part03.rar.html http://rapidshare.de/files/30292214/ChryslerA.part04.rar.html http://rapidshare.de/files/30293803/ChryslerA.part05.rar.html http://rapidshare.de/files/30295713/ChryslerA.part06.rar.html http://rapidshare.de/files/30297512/ChryslerA.part07.rar.html http://rapidshare.de/files/30299676/ChryslerA.part08.rar.html http://rapidshare.de/files/30302337/ChryslerA.part09.rar.html http://rapidshare.de/files/30305086/ChryslerA.part10.rar.html http://rapidshare.de/files/30308683/ChryslerA.part11.rar.html http://rapidshare.de/files/30311622/ChryslerA.part12.rar.html http://rapidshare.de/files/30314033/ChryslerA.part13.rar.html http://rapidshare.de/files/30316529/ChryslerA.part14.rar.html http://rapidshare.de/files/30319341/ChryslerA.part15.rar.html http://rapidshare.de/files/30321983/ChryslerA.part16.rar.html http://rapidshare.de/files/30324733/ChryslerA.part17.rar.html http://rapidshare.de/files/30327503/ChryslerA.part18.rar.html http://rapidshare.de/files/30330602/ChryslerA.part19.rar.html http://rapidshare.de/files/30333595/ChryslerA.part20.rar.html http://rapidshare.de/files/30338014/ChryslerA.part21.rar.html http://rapidshare.de/files/30348524/ChryslerA.part22.rar.html http://rapidshare.de/files/30359580/ChryslerA.part23.rar.html http://rapidshare.de/files/30370958/ChryslerA.part24.rar.html http://rapidshare.de/files/30383326/ChryslerA.part25.rar.html http://rapidshare.de/files/30390850/ChryslerA.part26.rar.html Chrysler DVD1B (~2.5GB ISO in 100MB rar's) http://rapidshare.de/files/30392981/ChryslerB.part01.rar.html http://rapidshare.de/files/30401927/ChryslerB.part02.rar.html http://rapidshare.de/files/30408574/ChryslerB.part03.rar.html http://rapidshare.de/files/30410300/ChryslerB.part04.rar.html http://rapidshare.de/files/30412076/ChryslerB.part05.rar.html http://rapidshare.de/files/30413863/ChryslerB.part06.rar.html http://rapidshare.de/files/30415575/ChryslerB.part07.rar.html http://rapidshare.de/files/30417131/ChryslerB.part08.rar.html http://rapidshare.de/files/30418579/ChryslerB.part09.rar.html http://rapidshare.de/files/30420131/ChryslerB.part10.rar.html http://rapidshare.de/files/30421879/ChryslerB.part11.rar.html http://rapidshare.de/files/30423476/ChryslerB.part12.rar.html http://rapidshare.de/files/30425152/ChryslerB.part13.rar.html http://rapidshare.de/files/30426855/ChryslerB.part14.rar.html http://rapidshare.de/files/30428603/ChryslerB.part15.rar.html http://rapidshare.de/files/30430619/ChryslerB.part16.rar.html http://rapidshare.de/files/30432677/ChryslerB.part17.rar.html http://rapidshare.de/files/30434875/ChryslerB.part18.rar.html http://rapidshare.de/files/30437353/ChryslerB.part19.rar.html http://rapidshare.de/files/30439782/ChryslerB.part20.rar.html http://rapidshare.de/files/30442773/ChryslerB.part21.rar.html http://rapidshare.de/files/31011723/ChryslerB.part22.rar.html http://rapidshare.de/files/31013630/ChryslerB.part23.rar.html http://rapidshare.de/files/30447557/ChryslerB.part24.rar.html http://rapidshare.de/files/30459139/ChryslerB.part25.rar.html http://rapidshare.de/files/30469768/ChryslerB.part26.rar.html http://rapidshare.de/files/30472806/ChryslerB.part27.rar.html Ford DVD1A (~3.7GB ISO in 100MB rar's) http://rapidshare.de/files/30489880/FordA.part01.rar.html http://rapidshare.de/files/30496963/FordA.part02.rar.html http://rapidshare.de/files/30508641/FordA.part03.rar.html http://rapidshare.de/files/30518598/FordA.part04.rar.html http://rapidshare.de/files/30526497/FordA.part05.rar.html http://rapidshare.de/files/30532086/FordA.part06.rar.html http://rapidshare.de/files/30535780/FordA.part07.rar.html http://rapidshare.de/files/30537743/FordA.part08.rar.html http://rapidshare.de/files/30539385/FordA.part09.rar.html http://rapidshare.de/files/30543445/FordA.part10.rar.html http://rapidshare.de/files/30545120/FordA.part11.rar.html http://rapidshare.de/files/30547072/FordA.part12.rar.html http://rapidshare.de/files/30549053/FordA.part13.rar.html http://rapidshare.de/files/30550987/FordA.part14.rar.html http://rapidshare.de/files/30553140/FordA.part15.rar.html http://rapidshare.de/files/30555859/FordA.part16.rar.html http://rapidshare.de/files/30558218/FordA.part17.rar.html http://rapidshare.de/files/30560382/FordA.part18.rar.html http://rapidshare.de/files/30564507/FordA.part19.rar.html http://rapidshare.de/files/30573812/FordA.part20.rar.html http://rapidshare.de/files/30583593/FordA.part21.rar.html http://rapidshare.de/files/30593824/FordA.part22.rar.html http://rapidshare.de/files/30604567/FordA.part23.rar.html http://rapidshare.de/files/30615621/FordA.part24.rar.html http://rapidshare.de/files/30630778/FordA.part25.rar.html http://rapidshare.de/files/30642526/FordA.part26.rar.html http://rapidshare.de/files/30650350/FordA.part27.rar.html http://rapidshare.de/files/30656483/FordA.part28.rar.html http://rapidshare.de/files/30658172/FordA.part29.rar.html http://rapidshare.de/files/30659901/FordA.part30.rar.html http://rapidshare.de/files/30661818/FordA.part31.rar.html http://rapidshare.de/files/30663679/FordA.part32.rar.html http://rapidshare.de/files/30669080/FordA.part33.rar.html http://rapidshare.de/files/30670541/FordA.part34.rar.html http://rapidshare.de/files/30672353/FordA.part35.rar.html http://rapidshare.de/files/30674694/FordA.part36.rar.html http://rapidshare.de/files/30677070/FordA.part37.rar.html http://rapidshare.de/files/30679576/FordA.part38.rar.html http://rapidshare.de/files/30681936/FordA.part39.rar.html http://rapidshare.de/files/30682894/FordA.part40.rar.html Ford DVD1B (~2.9GB ISO in 100MB rar's) http://rapidshare.de/files/30691955/FordB.part01.rar.html http://rapidshare.de/files/30694994/FordB.part02.rar.html http://rapidshare.de/files/30697789/FordB.part03.rar.html http://rapidshare.de/files/30700587/FordB.part04.rar.html http://rapidshare.de/files/30711074/FordB.part05.rar.html http://rapidshare.de/files/30722350/FordB.part06.rar.html http://rapidshare.de/files/30732707/FordB.part07.rar.html http://rapidshare.de/files/30735967/FordB.part08.rar.html http://rapidshare.de/files/30746631/FordB.part09.rar.html http://rapidshare.de/files/30756857/FordB.part10.rar.html http://rapidshare.de/files/30766450/FordB.part11.rar.html http://rapidshare.de/files/30773594/FordB.part12.rar.html http://rapidshare.de/files/30775368/FordB.part13.rar.html http://rapidshare.de/files/30778240/FordB.part14.rar.html http://rapidshare.de/files/30780017/FordB.part15.rar.html http://rapidshare.de/files/30781837/FordB.part16.rar.html http://rapidshare.de/files/30783478/FordB.part17.rar.html http://rapidshare.de/files/30785117/FordB.part18.rar.html http://rapidshare.de/files/30786772/FordB.part19.rar.html http://rapidshare.de/files/30788317/FordB.part20.rar.html http://rapidshare.de/files/30789817/FordB.part21.rar.html http://rapidshare.de/files/30791350/FordB.part22.rar.html http://rapidshare.de/files/30796635/FordB.part23.rar.html http://rapidshare.de/files/30798587/FordB.part24.rar.html http://rapidshare.de/files/30800496/FordB.part25.rar.html http://rapidshare.de/files/30802681/FordB.part26.rar.html http://rapidshare.de/files/30805056/FordB.part27.rar.html http://rapidshare.de/files/30807333/FordB.part28.rar.html http://rapidshare.de/files/30809917/FordB.part29.rar.html http://rapidshare.de/files/30812597/FordB.part30.rar.html http://rapidshare.de/files/30815211/FordB.part31.rar.html http://rapidshare.de/files/30816330/FordB.part32.rar.html
  11. Hey bro. I found service manuals for Sentra ( B14 series ) ( 40MB pdf file ) It contain these 01 GI Genaral Information 02 MA Maintenance 03 EM Engine Mechanical 04 LC Engine Lubrication & Cooling Systems 05 EC Engine Control Systems 06 FE Accelerator Control, Fuel & Exhaust Systems 07 CL Clutch 08 MT Manual Transaxle 09 AT Automatic Transaxle 10 FA Front Axle & Front Suspention 11 RA Rear Axle & Rear Suspention 12 BR Brake System 13 ST Steering System 14 RS Restrain System 15 BT Body & Trim 16 HA Heater & Air Conditioner 17 EL Electrical System
  12. Hah very funny
  13. Ur welcome bro.
  14. Are they sick
  15. Wow ur the man machan. I love RC helis Very much
  16. Hey guys do u have FB14 manuals ( PDF or CD ).
  17. OOoooooops. Im very sad about that.
  18. Hello friends, I want to buy mini RC car. Where can i buy one? And how much it will be cost ?
  19. Hello friends, I want to buy mini ( micro ) RC car. Where can i buy one? And how much it will be cost ?
  20. Try this link ftp://195.242.215.248/ It will work
  21. Oooops Sorry this is the server pass The username is: finalgear The password is: gearhead Have fun Thais link is working. Im downloading videos from it now.
  22. Code: This includes: Top Gear. Season 1-8 Fifth Gear: Season 1-9 Jeremy Clarkson videos: Extreme Machines Head To Head Hot Metal No Limits Shootout Top 100 cars Most Outrageous Stars In Fast Cars Apocalypse Clarkson Jeremy Clarkson motorworld:Australia, Cuba, Detroit,Dubai,Iceland,India,Italy,Japan, Monaco,Switzerland,Texas and Vietnam. 5 episodes of a series called: Overhaulin Jeremy Clarksons Heaven and Hell Clarksons Years Supercar Years Code: ftp://finalgear:[email protected] I got this from warez-bb.org
  23. Ur damn right bro.
  24. Errrr.. What is that ugly design . Front side its looks like a devil. But i dont know how about the performance.
  25. Ah that is totally bulshit. Dont even think about that shit.
