Everything posted by nala4ever
Thanks @dhanuFB15
- 4 replies
- cr
- vehicle registration
(and 1 more)
ahhh Then nothing to worry about Thanks for the reply @aamarakoon
- 4 replies
- cr
(and 1 more)
Hello... Greetings! In my CR book, under the ORIGINAL text, There are some other text as well. " 010173.WHT.(T) " Any idea about what this might be ? This is not a permit vehicle. Thanks
- 4 replies
- cr
(and 1 more)
hehe.. yep.
Hi folks, I took it to the electrician today because i wasn't sure if its the pump because there's no miss or anything, he pointed out that the fuel cut off switch in the pump is faulty, so i got it replaced and all is well now
yep, Gonna service the pump ASAP. Ill keep you guys posted
yep, the pump becomes hard after several pumps. And even after i replaced the diesel filter, The issue still exists :S
hey shai, i changed the fuel filter in this one. Still the issue exists, I'm gonna try removing the tank diesel lines and use a diesel filled bottle or something with new hoses and all. Then i can check if the problem is the air in the system.
Awesomeness... Narrowed down the areas that i need to check Thanks a lot Don!
I checked for that too, But i think i this model doesnt have.. And Theres no miss or anything :S Update: When its fully heated up (Stopped the engine), I tried pumping the diesel filter, After pumping two three times, the engine starts back again with no issue. Any thoughts guys ?
hey tiv, Yeah i bought this recently and the previous owner has done nothing it seems. I'm sure the mileages is not what it shows on the clock either , I'll do the injector pump service too. Fingers crossed. And thanks for the info bro
Awesome, I thought it might be attached to the tank, like in some petrol cars.
Thanks don, if by any chance do you know where the fuel pump is located on a Ln65 hilux ?
yeahh.. my thoughts exactly :S
ohhh.. Alrighty, Lets hope for the best in my scenario :D thanks a lot Fixzit
If the engine is under compression, wont it be hard to start in the first place. This one starts from the first shot when its cold. And no power loss or something like that too, very confusing... sigh
thanks a lot for the info guys, Its better to have some insight before taking this to a mechanic @fixzit: yep engine cranks when i turn the key
No, It runs smooth. Theres no miss at all :S
HI All, I have a 1988 toyota hilux, And it starts perfectly at any given time. And i can even drive it long distances too. However if you stop the vehicle after it heats up, (5 mins after running or 2-3 hours of running) i cant start it until it cools down. Im guessing this is something related to the coolant temperature sensor. Can someone here please advice, Thanks in advance.
ah, cool. Thanks Guys
Hi guys, My FB15 's Air bag indicator light is always blinking. Previously it wasn't, but now it keeps blinking all the time. I wonder whats the reason. Any ideas ?
