Before you do anything, Download the file (80 mb ++) and read all the instructions before hand. It’ll help you to visualize the process.
Download file contains
• GarminMobileXTforSymbianS603rdEdition_50040.exe
• GarminMobileXTFreeBasemap_4xxxx.exe
• GarminMobileXTSupportFiles_4xxxx.exe
• gmapsupp.img (Malaysian Map, with DUKE highway)
• garmin_kgen.exe
• 5800_manual.pdf
• GarminMobile20_GarminMobileXTOwnersManual.pdf
Installing GarminXT on Nokia 5800.
1. Once you’ve downloaded, unzip the files to someplace accessible preferably on your desktop. Connect your phone via USB and select ‘Mass storage mode’.
2. From you PC, double click “GarminMobileXTforSymbianS603rdEdition_50040.exe” to install and wait.
3. Double click “GarminMobileXTFreeBasemap_4xxxx.exe” to install. Wait..
4. Double click “GarminMobileXTSupportFiles_4xxxx.exe” to install.
5. Remove USB connection between PC and phone. When prompted ‘Launch GarminXT’ do not click Yes, just Cancel.
6. From your phone, go to Menu > Settings > Application Manager > Installation files. There should be GarminXT.sis file. Install it.
Cracking GarminXT on Nokia 5800.
1. Run GarminXT from your phone at Menu > Application > Garmin. It will prompt you with some settings. Choose your preferable.
2. Select “Use other device” when it prompts you to buy or trial. You will get a screen, “Where To?” and “View map”
3. In GarminXT, go to Tools > Settings > About. Jot down “Card ID”, you will need it. Exit GarminXT
4. On your PC, run “garmin_kgen.exe” and enter the “Card ID” from previous steps.
5. Generate it and you will get a string of codes. Copy the codes to Notepad and save it as “sw.unl”. *Be sure you don’t save it as sw.unl.txt”*
6. Connect your phone to PC and select “Mass storage mode”.
7. Copy “sw.unl” to Garmin folder. Usually located at E:/Garmin.
INSTALLING MAPS
1. Download Sri lanka Map From http://rapidshare.com/files/61579171/SriLanka.img
2/ ONLY three names are available so as to be recognized by Garmin: gmapprom.img gmapsupp.img or gmapsup2.img. (Gmapbmap.img is the base map of whole world so don't use this name except if you don't want a base map). so use one of these names for the maps. So only three different named maps can be used at the same time. Rename Supplied Sri Lanka Map to gmapprom.img
3) Then copy gmapprom.img file to E:\Garmin folder which is located inside your mobile (Make note: E: is your Mobiles MMC, it might be different in your phone)
Setting up GarminXT on Nokia 5800
1. You don’t need your PC anymore. Shut down and conserve energy.
2. Run GarminXT on your phone.
3. Go to Tools > Settings > System > Remote GPS. Change to “Use Attached GPS” by disabling the “Bluetooth GPS”.
4. Go to Tools > Manage My Data > Map Sets > MapSource. Make sure all maps are enabled.
