ANUSH
Everything posted by ANUSH
Thank you very much Brothers... for all the advices, and those information cleared most of the doubts I had in my mind.. I will get this thing sorted out in the weekend and will let you know the results... Once again thanks for your time and valuable information. :)
Thanks for the information..bro..I think mine also having the same issue...any way will first do a complete service of the fuel system and if it still fails, will go for the Throttle Body Sensor. One more thing..From where did you buy this Throttle Body Sensor?Is it reconditioned part or New one? and what was the price like?
Yes ,This was imported from singapore.It has full digital meter including the speedometer.
Friends, Also note that this car is with manual transmission....
No..This is EFI and has the same engine of Suzuki Swift(2001-2002).
Hi, I recently bought a Suzuki Liana 2002 Sedan (M 13 Engine) car. Even after it comes to the running temperature and when I keep the car at idle, the rpm remains at 1400.(With A/C 1200.) I went to A*W and they did a throttle body clean up and enjector cleaning.But still the problem remains the same.Throttle door also was adjusted to it's minimum level. Pluged to the suzuki scan tool (at A*W) but, no issue indicated. can someone please tell me what could be the reason for this problem.
I don't think the shocks are adjustable ones.Present shocks are recondition japanese demio shocks(According to Mag city) and they confirm that the shocks are in order. My Tyre size is 175/70/14 and not low profile. You can look in to the picture and I'm referring to the 19mm nut which holds the coil spring.If I loosen it,will the shocks be more smoother.(photo is not the actual one)
Hi friends , I have a mazda demio (2001 DW3W) car and it is very uncomfortable on drive.So I checked it with the Mag city and they said nothing is wrong and shocks(With coil springs) are also in good condition.But definitely the car is very harsh and really difficult to drive on average roads.What I feel is that coil springs are too stiff and it does not absorb a normal shock. Is there any possibility to adjust the tension of the coil springs by loosening the upper bolt of the shock. Please help me on this since non of the garage people are advising me correctly. thnx
thanks kumudug for the information. I found that the thermostat sensor is working fine.I heated the engine and checked the wire harness of the sensor,when the engine is hot the sensor connects those two wires of the harness together making the current flow.further it is a Negative current which passes through the sensor. but when i checked the relay,it is getting the current when you switch on the car(Dash lights on)and makes the fan works irrespective of the heat.I went through the wire harness(connecting to the relay) but could not locate any point where they have shorted those wires or any sort of alteration made. I really could not understand this and thought of showing to a professional mechanic/repair center. Pls tell me if there is any electrical repair center with talented mechanics you guys are aware.... . I saw in a foreign auto forum that this fan issue may be something related in ECU and it can be simply rectified by connecting to a scan tool...Any comments on it... . Desperately need your information and advices... . kumudug if you can let me know how your wiring was altered and where it was would help a lot. Many thanks
Thank you very much for the reply. I was able to find the fan relay.When I disconnect the wire harness frm the relay fan stops and when connect it works.I'm not 100% sure about the sensor.I found one just over the alternator with two wire connector clip(ash colour) and hoping that it is the one, disconnected the clip,but still the fan is running. . Do you have any idea about the situation? . what current does this sensor breaks(+ or -) ?
HELLLLLP...................
Dear All, Please help me to locate the Thermostat plug(sensor) of my Mazda Demio 2001.The radiator fan is directly run by main supply and I want to get it fixed.I saw kumudug was having the same issue too. *Kumudug please let me know the place you bought the sensor and the price of it. . Many thanks, Anush
My Mazda Demio(2001) too having the same problem. Please help me to locate the thermostat plug.I tried my best to find it,but could not. . Many thanks
got it fixed....Replaced the Speedometer.(Full unit).Many thanks for your kind advices. Regards, Anush
Thanks for the quick responds.. The wheels and the balloon size of the tires are matching with the Certificate of Registration. So..Masterdon you have any other guess?
hi friends, Last week I bought a Suzuki Wagon R(Japanese) mfd 2002(advertised on AL). It has a issue with the speedometer.When I'm driving at 60kmph it shows only 40kmph.(shows less speed than the actual at all speeds).but the trip meter,RPM and the odometer works perfectly. Can anyone please tell me what has gone wrong and any solutions which I can try out myself. I think the sensor at the gear box works fine since the odometer and trip meter are in order. . Many Thanks.
Most Suitable Car For Damaged Roads????????????
ANUSH replied to pereraprr's topic in General Automotive
I feel like Toyota SOLUNA is the best. Though it lacks in the shape a bit definitely it is one of the most reliable cars in the market.It is fuel efficient,Comes with options,very hardy(bit uncomfortable),lower in price(YOM 2000 around 13.5lks). . Just my personal view. -
145kmph on a 1996 Toyota Tercel 1300cc ignition advanced to 13 deg on LPG.It was near Kurunegala .
I think there is nothing to do with power shutter repairing..Just see a good electrician.
the price for the toyota tercel 1997 is bit high..rather you can go for 1998 tercel or corsa for 1.2mio easily.Considering your budget and other requirments I think Tercel or Corsa is a good option.Tercel is one of the most reliable and hardy cars made by Toyota even though they have comparatively lower resale ability.But still definitly you can sell it without a loss.It is a very economical on fuel and spares and I have been using it for nearly 5 years(80,000km)without any mechanical repair.(1996 model) . but it will be much better if u can go for a corolla 110 which will more options and comfort plus resale ability.
thnx for your reply.I realy changed my mind and decided to look for a wagon.Will go for a Nissan AD wagon(Y-11) which is in the same price range.Many thanks again for all the replies and all of u friends.
Hi Guys, I posted the same thread on Specific makes[/b]"other" forum of Al but could not get much response other than from Jaga.. I'm hoping to buy a Hyundai Matrix,but have some doubt in the mind.Searched through the net...most of the australians and europeans are claiming that it is good enough for the price we pay,but don't know whether we(Sri lanka) importing the same quality stuff. Desperately need your responses machan..
Hello Guys, . I need some advice on buying s Hyundai Matrix Manual Tranmission MPV. . How will be the overall quality of the car..........Any Comments ...
