CJPro
Everything posted by CJPro
  1. Did you bought????
  2. Check on the Ebay
  3. I think yes. but after changing the coolant you need to start and run engine without radiator cap. that time you can saw some water bubbles come out form the radiator.
  4. I have Renault Megane II and having some problem in my steering rack. when I turn there is a small sound come from the rack. then I went to BOSH service center. then they said need to change RACK and the rack ends. these parts are too expensive in the A*W. I need to buy these Renault spare parts. Is anybody know person who can import parts from UK?
  5. CJPro
    Renault Spare Parts
    I want a good mechanic with Renault scanner. anybody have idea about it? also I need power window motor with regulator.
  6. check it on the ebay. I think it will be cheaper than the local market.
  7. CJPro
    Reanult Spare Parts
    Their prices are too expensive. any other place???
  8. CJPro
    Reanult Spare Parts
    Hi any body know the place to find the Renault power window regulator?
  9. CJPro
    Rapaireing On Crc Kandy
    I want know it happen only for me or that's the way they do their job.
  10. CJPro
    No. I paint Buffer, right driver's door, floorboard and fender. but they remove all 4 doors. I don't know why they do it.
  11. CJPro
    These are some pictures of there damages. How can I add more pictures. error gives This file was too big to upload
  12. CJPro
    Is that the rear axle that you've taken a picture of with the ABS sensor ? Yes Did you get your power window switch back ? Not yet. I logged the complained. They mess-up everything. they did very poor paint job, lot of parts are missing and more scratches are in the body.
  13. CJPro
    they didn't do that for me. they get a inventory when I put it. and they didn't check it when it get back.They did lot of mess for my car. look at the paint is sparing every where and they fix the ABS sensor by using wire. They replays the rear axle coz it damaged by the accident.
  14. CJPro
    This is how they fixed the ABS Sensor. and the paint all over the Axel They stolen my power window switch. I have more evidence to show you. I'll add it soon.
  15. CJPro
    CRC means Collision Repair Center (past name is Formula World ). give me a time. Ill post with images.
  16. Any body know the quality of CRC kandy center. Coz I have bad experience of pure work done by them
  17. CJPro
    Renault Spare Parts
    Renault MaganeII Year 2004 sometimes service bulb and the air bag bulb turn on and after few second it disappeared. I think some loose connection in the wirering.
  18. CJPro
    Renault Spare Parts
    thanks guys. do u you know Renault mechanic with scanner?
  19. CJPro
    Renault Spare Parts
    thanks guys for your comments. Most of the smaller parts are can buy from the ebay. But body parts are cannot bought from it. coz they doesn't ship items to Sri lanka. And also I need a good mechanic for Renault with scanner. Pls help me.
  20. I have Mitsubishi Mirage CK2 Anybody know where to find original body kit for this?
  21. I have Mitsubishi Mirage CK2 Anybody know where to find original body kit for this?
  22. CJPro
    Renault Spare Parts
    I need Air filter and windscreen washer pump. Please anybody know good mechanic for Renault.
  23. CJPro
    Renault Spare Parts
    Please someone help me to buy genuine Renault spar parts except A*W
  24. First of all I appreciate you early response. In My case Tyre wasting out side in the wall edge. Yesterday I did alignment by MAG CITY. They said has to be done some repair in suspension system. How much you spend for that repair?
  25. Anybody know how to adjust camber in Nissan P11? coz this model come up with fix camber. it doesn't have a camber adjustment nut. anybody know how to fix that issue.
