vajz
vajz's Achievements
  1. Thanx guys for extending ideas on this..
  2. Nope. did not face. At the second time all of a sudden after riding 4 - 5km again felt something like knocking when gets slow (when is not accelerating). at the same time heat meter also moved towards upward from the middle position. So stopped the car and let the radiator to get cool and luckily there was a garage near by that area. After test ride and all it was identified as the issue with thermostat valve. So unplug the valve and again had a test run. While having the the test run something happened funny which was heat meter went up and down like nothing and finally figured out that sensor's jack also broken.
  3. Well this is a automatic one. every time used the coolant (except for one week after the first fix). At fist time it was indicated as an engine knock and less pulling power and that was the time I realized something went wrong. At first time did not notice any white smoke thing but oily air bubbles coming up when open the radiator cap at start mode. At the 2nd time initially identified as the thermostat is not properly functioning and later identified the heat sensor also not functioning.
  4. Hi, Please advice me on what should I do when I came across 2 times in changing gasket (I have nissan N16 super saloon, YOM - 2000, 1.6L) either to go for a new Engine HEAD or New Engine? 1st Occasion - My careless driving (I never came across such a situation and didn't know what to do..but i was checking regularly the water level of over flow tank and the radiator) - No cracks found in Engine Head and did not pace the head surface (after checking from a leading workshop which is located at Maradana) - Replaced the gasket with a genuine nissan one. - There were no any leaks found and however cleaned the radiator to make sure there are no longer any blocks (whether existed or not). - Replaced thermostat valve with a genuine one, because there were no clue that the old one was functioning properly. - Replaced Radiator Cap with a genuine one because there were some scratches at the rubber cap of old one. - All of the mechanical part done by a experienced mechanic. 2nd Occasion - Regularly monitored the engine heat level while driving and checking the water levels of radiator and over flow tank in daily basis. - Replaced thermostat valve with a genuine one, it is not opening the valve at the correct temperature. (replaced with a genuine one) - Replaced sensor which brings the temperature level of engine to indicate at the dash board temperature meter. (replaced with a genuine one) - Both occasions, - No any leaks found (Radiator and hoses) - Replaced genuine thermostat valve. (both occasions) Now i'm in the 2nd occasion and according to the mechanic (the Nissan agent in Sri Lanka which located at peliyagoda),they said, after proper scanning and testing this time also found that there is a issue pertaining to the gasket or engine head. First occasion occurred in last December and again it happens now. Feel that if I fix the thing with existing engine / engine head from the agent it will cost me a lot because their labor charge is very high and if the thing happen again there is no point. Please advise me what to do next?
  5. vajz
    Fb13 Fuel Consumption
    -- Thanks bro.. I'll get done ask garage person to do the thing with the repair kit. many thanks...
  6. vajz
    Thanx bro, So far, 3 times I brought the car to the garage person(at kosgas handiya - grandpass u may know the place ) and last 2 times, what he did is changing the petrol jet inside the carburetor and asked me to run some distance and see whether how the fuel usage is good or bad. so If your thing was success after fitting the carburetor repair kit, please give me the details of the garage via an email, that'll be a great help for me (only if not violating this forum) my email is [email protected]
  7. vajz
    bro, Thanks for the advise. can u please tell me how much would I cost(roughly) to do so..
  8. Hi, Can anyone help me out to know about the fuel consumption of FB-13. Km/l? Recently I got tuned my carburetor due to knocking and stop the engine when slower..etc after tuned up now its doing 7-8 per Litre. Thanks, Vajiranath
