Hyundaisantro
Everything posted by Hyundaisantro
  1. Thanks a lot guys for your valuable ideas. As far as considered i think its better to see Mr.mechanic@ Hyundai Lanka, since i'm not much familiar with those things. Will definitely inform the solution. Thanks. Regards Shrimal Hyundai Santro EFI / Manual / BRNew -2002
  2. I've adjusted the accelerator cable to minimum but the speed remains same.. I think i should clean the throttle again...
  3. I have a Hyundai Santro (1100CC EFI- Manual ). Although the idle speed is set to a certain value during the engine tuneup, its seems too much for me . So needs to slow it down. Tried to adjust air/fuel ratio lever in the throttle body but its already turned to minimum. so how can i slow it down? And also what are the best adjust limits for maximum fuel efficient run? Needs experts help please.. Regards
  4. Thanks guys. Sorry for the late reply and now i know where the problem is. It was the switch. So need to check it with a mechanic. Thanks once again.
  5. My car,s reverse light is not turning on even though i shift to the reverse gear. I have checked the bulbs and they are working fine. Does anybody knows, where is the switch/contact, connected to the reverse gear indicator lights?
