Everything posted by Sifaan
Hybrid Cars
but you can get additional cover for specifics; I don't know how this varies with different companies, but in case of airbag deployment my policy covers 50% of the replacement cost (airbags, dash, etc) - I could have got 100% cover by paying an additional premium. And there was some option for the windscreen as well... so not too surprising that there's an option for the battery. Mmaybe AbeysinghE can share what the additional battery cover actually covers?
Alfa Romeo Reliability. An Unjust Myth Debunked.
Loving it it's been behaving itself pretty nicely for a while now (after all the brain damage getting it fixed up the first time around)... only recent problem was the rear view mirror leaking its fluid out :S Got down a cruise control stalk cos supposedly it's just a case of plugging it in the steering column and configuring it in Lexia... I know it's possibly the most useless upgrade I could make, but it seemed a fun and cheap thing to try out!
I saw the ad and the "new starter motor" caught my attention (since you had mentioned it on some posts) and thought it was yours - and the phone number confirmed it
Finance / Leasing For A Vehicle
I don't know if the following will still be valid from tmrw (because there were some changes outlined in the budget) but the problem is that VAT has to be charged on the lease installment and if you are an individual you can't claim that VAT. So for an individual a loan is usually cheaper. However people who can't get a loan big enough to buy the car (e.g. if salary is too low) then they go for lease. that is the explanation I got from few places when I was looking out for a loan/lease a few months ago. and there was no difference (at least no significant difference) in the interest rates between loan/lease from the same provider.
Blue Color Hid
there really isn't much point to get a higher colour temperature HID because it's going to give less light output (and illuminate less road area) - however some people think the blue/purple colour is cool (a carryover from blue neons?) so that's probably why there's a market for it. the glare problem is less to do with the colour temperature, if at all. it's mostly because of cheapo HID conversion kits that only change the bulb: the light distribution pattern in a HID is different from halogen, so when a HID bulb is stuck in a headlamp designed for halogen, the beam pattern is all screwed up. also - in Europe (and few other markets) it's only legal to have HID if the headlights are self-levelling (otherwise a car loaded at the rear will shine light upwards - eye level for oncoming drivers) and have headlamp washers (not sure if this is to do with dirt on the lamps or water) - such legislation doesn't exist here and people who go for cheap upgrades don't care and/or are not aware. http://en.wikipedia.org/wiki/Headlamp#Lack_of_backward-compatibility
2 In Auto Gear Box
What the manufacturer intended it for, and what people use it for, are not necessarily the same thing...! I was travelling in an X-Trail from Colombo to Badulla sometime back and the driver kept switching to 2 to overtake.
Bigger Rear Tyres
what's the difference ?
Bigger Rear Tyres
My understand is that grip and rolling resistance is two different things; it seems like that is also what you are saying here so getting back to the question about wider tyres => more grip => less fuel economy... there are many places where static friction has to be overcome before the car will move (e.g.at the bearing of any rotating part) but that doesn't (?) include the contact between the rubber and the road. if that static friction is overcome, then the tyre will spin without gripping (like what happens on mud; because the static friction is very low there). so more grip (e.g. because of softer rubber in the wider tyre) should not adversely affect economy. if the above is incorrect, I would appreciate if someone can point me to an article that explains otherwise (e.g. that the friction between rubber/road has to be overcome by the engine) (BTW wider tyres may well give poorer economy because of the increased weight / moment of inertia or some other reason; what I am trying to understand is the "grip" part of the story)
Bigger Rear Tyres
BTW I'm quite happy to stick with recommended tyre specs; however, those are a balance of many factors (price, comfort, handling, economy, looks, etc.) so some people do prefer a different balance - like upsized tyres for better looks and cornering but less comfortable and more expensive
Bigger Rear Tyres
I've been searching a bit to try to understand this better; what the engine needs to overcome to move the car is the rolling resistance of the tyre (and air resistance, but that's not the topic here) the main contribution to rolling resistance in a car is the deformation of the tyre (surface can also deform; and there are a few other contributors)... low rolling resistance tyres (like Michelin Energy) have some silica mixed in to reduce the deformation. BTW steel wheels (like in a train) have a much lower rolling resistance (because they don't deform). I can't find comparisons on rolling resistance vs. width for car tyres, but there are several sites about bicycle tyres that say that, for the same pressure, a wider tyre has less rolling resistance than a narrow tyre because the sidewalls flex less. however, racing bikes have narrow tyres because they can be inflated to higher pressures (don't know why that is so) which means lesser resistance, there's also less wind resistance (more significant in a bike than a car), and moreover the tyre itself weighs less (which is also important for cars) I also can't find a connection between the rolling resistance and the "grip". It's also not clear why a wider tyre would give a better grip (assuming the pressure, tyre material, tread, etc. are unchanged) because the size of the contact patch does not change (pressure = force / area; in this case force = weight; so area = weight/pressure) - only the shape will change (wider and shorter for a wider tyre). maybe there's something else at play here (like a softer rubber?)
Bigger Rear Tyres
I get that manufacturers recommend particular tyre sizes for certain reasons; what I don't get is, why is a tyre with more grip bad for fuel consumption?
Bigger Rear Tyres
that doesn't make sense... it is because of the friction between the tyre and the road that the car moves at all; less friction would mean more slipping
Bigger Rear Tyres
how does too much grip lead to poorer fuel economy?
Leather Seat Restoration
didn't ask about that, but I presume they would be able to do it.
Going On The Left
probably monthly target for fine collection has been increased
Peugeot 504 Restore
you restored a 2CV? Awesome.. do you still have it? (And BTW do you know Ray Welaratna?) PS Tried to send this by PM but seems you can't receive them :S
Most Comfortable Tire Size
the manufacturer spec is a balance of comfort, handling, fuel economy, looks etc. as per the intended market of the car (e.g. a sports car would be biased towards handling than comfort). Going from 13" to 12" (assuming same overall tyre diameter - less steel, more rubber/air) would generally mean more comfort at the expense of handling (how quickly the tire responds when you turn the steering) and fuel economy (more rolling resistance - how much the tyre will deform before it starts turning). But as comfort is your priority you could probably stay with 12", especially as moving to 13" will cost you for the wheels. if you stay with R12, 155/65R13 closest match is 155/75R12, or you can go for a wider tyre (e.g. 165/70R12) but that would be a bit more expensive (on the other hand it should last a bit longer too). Don't go too wide or the tyre will rub on wheel arches when turning 73S is load/speed rating; http://en.wikipedia.org/wiki/Tire_code generally not worth to go for higher speed rating (costs more, lasts less) on a car like this; given Sri Lankan typical driving conditions you can probably go with a much lower speed rating if available. BTW the ride will be more comfortable if you under-inflate the tyres a little, but I don't recommend this as this reduces the life of the tyre and could result in a blowout
- Nissan March K11
Is It Possible To Repair Auto-Dimming Rear View Mirrors
Hi all! 2 nights ago I noticed a patch of lighter colour on the rear view mirror (oval shaped, slightly above the middle) and on further inspection it looked like there was some dark colour fluid in the rest of the mirror that was missing in the patch. The next evening (i.e. yesterday), the mirror was almost totally clear, but there was some fluid on the lower quarter or so of the mirror, and further more there was fluid slowly dripping out of the bottom the auto-dimming function is normally ON, but was OFF when I noticed the problem and the leaking (which seems to be from the switch) Does anyone know if this kind of thing can be repaired (refill the fluid and seal the leak) or does the mirror need to be replaced? Thanks /Sifaan
generally, the lower the profile, the less comfortable it will be (because the sidewalls are stiffer); but, for the same width, higher profile => bigger tyre, which will reduce the clearance between the tyre and the wheelarch. what is the stock tyre size?
Professional Photography
few years ago 2 friends (europeans) were finding it very hard to find a photographer: they wanted someone who could take candid, natural shots (they didn't want to do hours and hours of posing on their wedding day) and plus they just wanted all the photos on dvd (no printed album) most places they checked were either not willing to work on this basis and/or wanted some exhorbitant prices to release the soft copies in the end, through some contacts, I was able to find a commercial photographer and they were very satisfied. 2 years ago we used the same guy for our wedding and very happy with the results: we gave him one hour for posing shots before the ceremony; and for the ceremony/reception it was all candid shots... maybe we missed out on some photo opportunities here and there but on the other hand we have loads of very natural, authentic photos plus it worked out a lot cheaper as well
Peugeot 406 Or Corolla 121
While I also agree that a 406 is a better choice (esp. as the OP cares about comfort, looks, handling, etc), this kind of calculation is correct only if the car is used until it dies. If we consider a more likely scenario of selling the car in few years, it will be possible to recover some of the 1m premium paid for the 121.
Civic Hybrid
no, because city driving wastes a lot of energy (stop and go; idling) and this is reduced by hybrid technology => more benefit for city driving
Nissan Fb15 New Shell Vs Carrina Ti Myroad
I also can't imagine any modern car not having a backlight on the instrument cluster - I've pretty much taken it for granted that it comes on with the parking lights (and even our K11 March had it, so it would be very strange for Nissan to not put it on the FB15!) I think the term actually refers to the illumination of other dials/buttons on the dash - A/C, radio and such like. In any case, I find it hard to believe that someone would evaluate this when considering a 10 year old car!
Civic Hybrid
and how is that different to X times 1.63?
