Everything posted by Sifaan
Volkswagaon Passot 2002 And Scoda/bora
What an accurate prediction...
Importing Car
not tried, but did check out the options... if you buy from a VAT registered business, you don't need to pay UK VAT (17.5%) if you say it's for export - have to export within 6 months (I think). Have met couple of people who imported used 406s and they had gone to UK and bought personally. the paperwork doesn't seem to be that difficult (and at least the info is available in english). overcall can be well worth the cost and hassle for a luxury car due to the high depreciation in market value in UK. and used Prius seems quite cheap as well
Warning About An Agent And Some Advice
Is it worth to try complaining about this to the carmart management?
Vehicle Import Taxes Reduced To 25% What Will This Do To The Market?
there's a light blue one that I used to see on madinnagoda road (last year, when I lived there) and about 2 months back saw a new black one (didn't even have license plates) near slave island (going past burgers king!)
wikipedia is your friend http://en.wikipedia.org/wiki/Full_hybrid#Types_by_degree_of_hybridization
Vat
not quite as simple as that... even if you paid 20% VAT you can only claim 12% as input VAT. and even that depends on what the vehicle is for... usually for commercial vehicles (+ cars if you are taxi company) you can claim upto 50% (i.e. 6%) as input VAT
where does it say that excise duty on vehicles has increased???
it is disclosed. there was an adaderana link with the entire budget speech by MR. but there isn't a section titled "for autolanka users" so the information related to vehicles is in several places (revised depreciation tables, exemption of VAT on various classes of vehicles - tuk tuks in 1 place, electric/hybrid in another, etc.) and it's sometimes not clear for us non-economists in theory it's also possible that some aspects may be changed as a result of debate in parliament, but that would be very unlikely
you haven't seen 28+ people in a 3-wheeler ? but seriously, the concession for 3-wheelers is not connected to the reduction in tax on passenger vehicles...
those were the biggest components; some of the taxes actually applied on the excise duty (e.g. the 15% surcharge that used to apply before mid-year reduction was calculated on the excise duty amount) so getting rid of the excise duty may knock off a few others as well.
that's when you paid > 250k/year as income tax for 5 years, when you import a car you could get 25% duty waiver (on the entire tax amount)
Does it say anywhere that vehicle VAT is going to reduce? The only part I saw about VAT reduction 20% -> 12% was for financial services - but at least if you take a lease then the VAT you pay on the lease should reduce edit: on page 53 it says "The present 20% rate will be reduced to 12%. Accordingly, there will be only one rate applicable other than the Zero Rate. (Section 2 of the Act will be amended)."
Random Automotive Related Rant Thread
well.. there's only so much you can check otherwise you'll never end up buying a car... One of the issues I faced was a front disc had cracked and had been welded/soldered (instead of being replaced). it was only visible when I got around to replacing the brake pads - certainly not noticeable with the wheel in place; and on 90000km usage I didn't even expect the discs to need checking. (actually the problem had probably occured because of brake binding from hand brake (it's on the front wheels) not releasing due to a problem in the caliper -> disc overheated -> crack. subsequently rather than fix the caliper (clean, maybe caliper repair kit) and replace the discs what had been done was to repair the disc and disconnect the hand brake cables) but the biggest makabass job was this "expert" replacing some lost LDS fluid with ATF fluid, which required all LDS to be flushed and replaced, plus buggering up some other parts.
Leather Seat Restoration
I found this and similar (see my earlier posts on this thread); when I asked about this from dynamixdyes the guy replied "Heat will expand leather and stretch wrinkles. Filler is really designed for cracks/lines in leather and not to repair folds" if heat expands the leather it'll make things worse if heat shrinks the leather it'll remove wrinkles (but the only way I can imagine heat shrinking something is if "burns" the material in some way) two contradicting opinions.. possibly due to the difference between natural/artifical leather? (@Bugatti: I thought natural leather was used only on few ultra high end models - e.g. some audis - where they would use it in their marketing as "natural leather" seats) I guess the only way to figure it is to cut out a small sample (under seats, etc), measure it precisely, hold an hair dryer for some minutes and see what happens however, if the heat treatment was a viable option I would expect that the upholstery people would be offering it as a service... it's not like it's top secret or proprietary technology?
Vehicle Windo Tint
thanks... and checking through the benefits of AAC membership (related to my question on whether it's worth to renew) they do say there's a 7% discount on 3M tints @ Kleen Park. If the discount is valid then the membership could well be worth while
once a week? the guy I met today recommended to use their product once a month. does your product say once a week? from what I understood from Upul, leather will get loose with age (and therefore wrinkle) and there isn't anything you can do about it (although reducing exposure to sun would slow it down). but as long as it is kept moist it would not crack. I have a few light cracks and they can be filled in... but if it left unattended it would eventually tear and then it's a bugger. btw he showed me how his cleaner works by doing a small patch on the rear seat - quite impressive. you might want to get something like that done every 6 months or so.
Vehicle Windo Tint
thanks for the info... anyway for the windscreen the darleyroad stuff is anyway not an option (except for a strip at the top), so the only option for the windscreen proper is the 3M... any idea if they can do it in segments? i.e. a dark strip for a few inches at the top and the clear film for the rest? and re. windscreen reflectors, the conventional size available in darley road is too small for me, but there's a place in wattala that said they can do custom sizes... will get that done soon, maybe for front windows as well.
Vehicle Windo Tint
Since you got this a year ago and are still promoting it, I guess you must be very happy with the result.. do you have any kind of measure of how effective it's been - e.g. when the car is parked in the sun it doesn't get as hot inside as it used to, etc.? and do you also need to use a windscreen reflector when parked or is the 3m stuff good enough?
I went to this place to get an estimate on the work, to clean, fill cracks (I don't have any tears, yet!) and paint/dye, and he (Upul) quoted: ~25k for the 2 front seats (e.g. if I only wanted the rear seats cleaned), takes 6 days ~55k for all seats, takes 8 days I'm just curious how the results of the dye kits (dynamixdyes.com etc.) compare to this cos they seem to be few hours worth of a job? I doubt if they would artificially inflate the amount of time taken the work... or do they?
Vehicle Windo Tint
well, the enforcing is not exactly consistent... recently I've seen two vehicles with very dark tints on front windows (with a cutout to see the rear view mirror) in Colombo; one was a 407 and the other was a Kyron. on the other hand a friend's March was copped and she had to go show the car to cops after removing the tint.
Vehicle Tax To Increase In The Budget ??
don't cars already have "odo"meters?
Automobile Association Of Ceylon
I was getting it in a hurry and the impression they gave me was that I had to become a member; tend to agree with Watchman's view that it's a cheap trick to get in some extra membership revenue. Anyway, what I would actually like to know is if there is any benefits in the membership - the legal advice, the discount on the towing, whatever?
Hi! I got membership of AAC when I wanted an International Driving License earlier this year; at the office they said I had to become a member of AAC to get the IDL (although after reading this I think I could've been ripped off) I've got a reminder saying my membership is due for renewal at the end of the year and am wondering if there are any AAC members here and if they feel the membership is worth the money?
it's part of the government strategy to reduce unemployment... this will create lot of jobs for fart inspectors.
Mitsubishi L200
great... vigorcomp's brother can finally go buy the L200 now...
