K11
K11's Achievements
  1. Congratulation on your purchase. If you were unable to find user manuals yet, I have uploaded it (both Mechanical land Wiring Manuals) to 4Shard and this is the direct links for the PDFs. http://www.4shared.com/office/XKKOGL-pba/ssangyong_kyron_manual.html http://www.4shared.com/office/1EI0bLbice/ssangyong_kyron_wirings.html If anyone has later versions than this please share. I normally do my service from “advancedcardiagnostics ” at Pannipitiya and it is a good place in terms of car care and chargers. http://www.advancedcardiagnostics.com/ (Amal- 077 762 6500)
  2. I have a NISSAN K11 year 2002 Auto model. I am having problems with the steering. It becomes really hard when parking (very slow speeds). I have try to get repaired this (Rack and column has replaced and cost me more than 50,000/- ) but failed. I cannot understand where the problem is. When I drive, the steering is alright but at low speed, it becomes very stiff. What could cause this? Dose Battery’s Ahr will effect for this? (Engine automatically accelerates slightly when this happen)
  3. K11
    K11 Eps Issue
    i think i got . but i added to this as benefit of others because this is categorized as NISSAN
  4. K11
    K11 Eps Issue
    I have Nisan March K11 YOM 2002 and this has come with EPS. I observed some noise from steering rack when I drive on a bumpy roads and replace the rack end bush (Fabricated with Nylon), after 3 months time again I felt its bit harder to do Right turn than Left turn So I went back to same place again and after a inspection they have replace the bush for the second time couple of days before. But when I’m going to park my car @ de office Steering become more harder than ever, I was really wonder what is happening and I’m guessing problem is with EPS motor or gearing unit, when I call to garage again they told that I have to replace the motor + rack and it is come as hall unit and can’t replace motor along, also it would be cost over 25k . Please help me to find a solution for this do I have to replace entire rack ? is this a common issue on K11 EPS ? I saw some Comments in de web about K11 EPS system and please share your expert knowledge and Experiences about this it would rather help all K11 users and those who are willing to buy.
  5. yap as you sad sm time problem could be in de sensor, have to check it. Is This Common Issue in K11 EPS ? I saw sm other post regarding Toyota 121, vios , ect they have explain the issue giving K11 EPS as a example by saying "As in Nisan K11 model ..... "
  6. Thank you very much about your comment, I’m also think about a method to overcome this issue without replacing the rack. I observe this harden after two days(Today morning) of replacing the bush for second time within 3 months time , I don’t have any idea about the original bush material and y they fabricate is using nylon most probably this might be a issue with quality of de nylon material that they use to lathe?. And also they told me original bush is not available to buy in the market and have to fabricate it. I’m really worry about, due to this hardness of the steering will effect to malfunction of the EPS motor. Car is in the car park now I dnt know whether I could be able drive it to home today evening.
  7. I have Nisan March K11 YOM 2002 and this has come with EPS. I observed some noise from steering rack when I drive on a bumpy roads and replace the rack end bush (Fabricated with Nylon), after 3 months time again I felt its bit harder to do Right turn than Left turn So I went back to same place again and after a inspection they have replace the bush for the second time couple of days before. But when I’m going to park my car @ de office Steering become more harder than ever, I was really wonder what is happening and I’m guessing problem is with EPS motor or gearing unit, when I call to garage again they told that I have to replace the motor + rack and it is come as hall unit and can’t replace motor along, also it would be cost over 25k . Please help me to find a solution for this do I have to replace entire rack ? how much it cost around? I saw some Comments in de web about K11 EPS system and please share your expert knowledge and Experiences about this it would rather help all K11 users and those who are willing to buy.
