BLu3HaZe
Everything posted by BLu3HaZe
  1. More than shielding, it's the 3 cylinder engine like in a minivan giving such, they're not under proper balance and therefore gives more vibration than a 4 cylinder. Eg. only -- It's like an Indian 4 cyl bus vs. Jap 6 cyl bus, you can barely feel it's diesel in the latter as it's in both primary and secondary balance. In your case, nothing to worry though it's quite irritating. Yes all 1.0L Vitz made after 2005 have CVT GBs only, and it's better to stick with the agent in these new cars as some service stations tend to mess up and put ATF in CVT boxes, which would be the end of the GB.
  2. Wow!! A plus side of a 3 over a 360 It's just so real, any such 360 or PC sim games, emulators, ports?
  3. Ah ok, that's what I also have seen, only unleaded. So OP needn't worry about the cat or petrol you pump in, just go the shed and fill 'er up
  4. Do we have leaded petrol now anyway?
  5. http://www.autolanka...car-for-25-3-m/ http://www.autolanka...18-million-slr/ http://www.autolanka...car-round-182m/ http://www.autolanka...ar-4-25-million http://www.autolanka...car-for-25-mil/ http://www.autolanka...18-car-for-25m/ http://www.autolanka...post__p__143060 Search the forum more and read through the threads, would get you results quicker than asking in most cases as these price brackets have been discussed before For your specific question, the facelifted Sunny called N17 and the Bluebird Sylphy you speak of are basically the same car from different markets, and they're both N16 Pulsers if I'm not mistaken. (Sunny had FB codes and Pulser had FN codes). Fit Aria is a decent car according to most owners, and a good budget car. F/C would be better off in the Aria than a 1.3L Sunny, try to stay away from the latter, as the engine is too small for that car and would tend to consume more fuel. If you decide on the Sunny, go for a 1.5L. Resale is hard to predict now.
  6. Good and bad news, the country is going to get into even more financial difficulty, but hey, SL getting a proper F1 track is great! If SL racing gets all advanced and hyped up, IMO there'd be better use of the 'GT' cars we have here... @Peri - Maybe they just mean a track which is 8 F1 cars wide?
  7. We might possibly get a Hybrid too as a JDM car is usually more comfortable, necessary when travelling with females as they throw up in every single trip now, so will post what prices are like later, and yes the Civic is much rarer than the Prius in auctions. Maybe because people don't want to sell them after buying, have fallen in love with Honda's?
  8. Now a brand new car is also less than 3.5 years old, isn't it? And as there isn't a way to buy brand new other than from agents and cuz many SL people calling Jap recons as brand new is wrong, yes you'd get 39.5% of the CIF as tax for the Civic and 53% for the Prius, the most common models which would be imported. But do the agents offer them at all to worry about brand new taxes??
  9. Yes so in that sense and repairability, the Civic Hybrid has the upper hand being a normal car and engine with a different flywheel, should any problems occur in these new cars and garage people will learn that quickly as it's very similar to the FD1. You're welcome!
  10. Your suggestion is valid for the Civic Hybrid but not for the Prius at this stage, as the transmission is also replaced by a motor which would end up the car with no drivetrain if both motors were removed. Also starting a Prius without the battery might prove difficult IMO due to the starter motor being the same as the transmission motor, requiring larger voltages not easy to supply with a common battery.
  11. We had brand new cars for permits only, not otherwise, and those agents are a greedy lot most of the time Trying to offer what they can rip off from most, and not making other options available, increasing CIF values given to customs for models they don't import, making the basic trim so basic that everything has to be paid for as an extra option. Ex: In the case of Sunny, even mud flaps and wheel covers on steel wheels were optional! Maybe you could get a better deal if you know someone high enough for that, and is willing to lower their profit
  12. If he's buying, guess it'd be cheaper to buy a Belta from Japan directly through a friend or so after putting your specs on it and getting in imported here as a recon. Though I doubt many will do that, it'd be cheaper as it'd have been a registered in Japan car, also getting 90% of CIF for taxes, and not to mention softer suspension giving more comfort and slightly better quality of interior, at the expense of having no warranty and getting a Jap manual. You should be able to save a few lakhs in the process anyhow.
  13. Yes those other taxes have been removed for hybrid vehicles, upto 1600cc. An extra 9.9% is added for 1600-2000cc hybrids, such as the Prius.
  14. Go for the Civic, it's quite a good car, and better looking than the torrents of Axio's, Allions, Vitz, Ist etc on the roads these days. Also as someone said, Impreza is a good choice. Tax depends on the capacity ofcourse. Example - 1.6L Civic normal tax is 159% approx. Therefore under permit 87.5% to be paid.
  15. It was mentioned somewhere in the forum that tax reduction is only for full hybrids, but if that is so, the Civic Hybrid will be the same price as the normal gasoline one, as the auction prices are higher though the engine capacity is smaller. As I said, this is assuming them to be treated similarly. For options, have to ring up the agents and ask, as they would provide all those tables, but it's common sense to use Hybrid basic to compare as the frame codes are different and that's how usual custom work happens. You found the tax tables from customs.gov.lk? It'd give more accurate info as they usually copy and upload docs they have and use. The HS code for 1.0-1.5L hybrids is 8703.22.51 right? Yes, 39.3% with taxes on taxes+CIF to be exact. Didn't check thoroughly earlier, sorry for the error. And you're welcome
  16. Faster than you? I mean the ladies' driving And what do you reckon would win, if you were driving the Z against the Z4 in a drag?
  17. True, their network is congested around Colombo. But atleast you get more than a max of 235kbps possible if you're in UMTS at 384kbps or HSPA at 3.6Mbps
  18. Are you buying or selling?
  19. Set it to UMTS or 3G only in network settings, won't go to EDGE then
  20. That's weird cuz I get very good download speeds with that, more than 100KB/s even during daytime, and around 180+ during night It's connected full time and line hasn't dropped for 3 days now. And Mobitel on the other hand is very slow in room but fast in the front of the house.
  21. Well you just got to give a few calls and get the proper tables, get a calc and punch away the numbers. I'll try giving some approx values, hoping there need not be so many new threads asking about tax... Not sure about the full hybrid only getting tax cuts, but as Civic hybrid seems to have gone down in price and also the custom tables say 'hybrid electric vehicles', taking both Prius and Civic in same category here. CIF - someone call T*y*t* L*nk* and St*ff*rd and post here, can't remember after I asked last time. Correct any figures if I'm wrong as I hate stats, tables, tax calculations, basically commerce stuff But hopefully this would provide some info to people who ask, and will update when someone provides other info EDIT - Corrected total tax
  22. Cuz of the new depreciation table, took it as less than 6 months old as he wanted a 2010 vehicle with less than 10k, and also the new models are 1.8L engines which mean they get a little bit more tax. Could be in the range of 3.8M I think Yup, the Civic is lower at auctions as initial price is less, in addition with the smaller engine meaning lower tax in SL too.
  23. Haven't heard of any new cars with the 3 stage variable cam timing system, do any exist? Even the new Honda Civic with the R engine has normal VTEC inverted, afaik, leading to higher petrol consumption in SL. So conclusion is - the OP should find a JDM EK3 Vi with the 3 Stage D15B engine if he wants a Civic with good F/C, right?
  24. Wired lines - yes SLT Wireless - quality and speed is offered by Mobitel at a high price, Airtel is giving comparable features at a much lower price. Yet shared network in the latter slows it down a lot during busy times. Dialog is nowhere, though many people are biased towards that. I've no experience with Lanka Bell but people say it's good.
