safraznawaz
Everything posted by safraznawaz
  1. Purple
  2. Hi, please advise as some says not to drive this hyper cvt m6 as an normal auto, they say not to put the pressure on peddle Av once mr suddenly since it is bad for the gear box, as it will put more weight on the gear ratio with high trouq,.... so driving smoothly pushing the peddle gradually as it will shift the gears accordingly to the sped which will not harm the gear box,.....? And some says don't use the triptronic, once we start using the triptronic only the problems starts, as we put more weight on the gear ratio as the patten of the driving changes,and some says you need to use the triptronic once in a way which you need to get that part also to be function, only if you don't drive on triptronic it will get stuck as the oil will be not pumped to the triptronic side which will harm the gear box....., please advise I'm so confused.... thank you
  3. All the windows re working from the rekvent individual switches from there owne doors, from the drivng side controll the rear windows are not worki but it dose answer as the driving side rear right window switch answers to the rear left window and from the driving side rear left window switch answers to the rear right side window, (Answers mean when we try to lift the window up and when we press the switch in the driving side rear to down it stops,) Please help Thank You
  4. Hi I go the car P11, excelent condition thank for your help
  5. Hi i am need of an reliable good car to buy in the range of 19 what would be the better? As i had an look at a HP11 the red one on the site for sale and another one which is with an higher spoiler modified by nismo dark purple, Both the cars are hyper CVT M6 gear box, most of told this has a problem, please advice? i really like the TP 12, but most told me the 11 is better than TP12, as the TP 12 has more common problems including the gear box? i am bit confused, apriciate all of your advices as if i buy a car i would have to use it fir a long time and i cant afford to loos time and money in the garrage? i was using a Carina GT and before the Mazda Hatch, both the cars are good cars, Thank you
