flashmark
Everything posted by flashmark
Steering wheel not returning when turning into left side
flashmark replied to flashmark's topic in General Automotive
Yes. Now rack also replaced still issue is not completely resolved. When turning to left side steering not returning fully (half circle). According to the garage now I've replace the shock as well :(. No. No off-roading or similar events. -
Hi, I observed that my Suzuki Swift (Beetle) steering wheel not returning to center after turning into left side. Also there was some noice when drive in gravel roads. So after inspecting in garage, they replaced lower arms and links and aligned the wheels. After two days, exactly same issue came again. Again I went to the same garage and they were suspected that sound came from rack and they replaced it with recondition rack.But still issue is there. Still steering wheel not returning after turning to left side and noice coming when drive in gravel road. What could be the issue is? regards, Flash
Hi, Earlier I went to several service stations for the lubricant service. But I'm not satisfy with the work they had done.Can you recommend a good garage with service station near to Mount lavinia? Seems like this time, I've replace break pads and caliper pin too. May be razor as well. That;s why I'm looking for good garage+service station. Thanks,
Can I clean battery terminal while engine is ON?
After cleaning battery terminals properly, issue is resolved. Thank you all for the inputs -
As you can see in the attached YouTube video, battery icon also not displaying. -
corrected. -
This is the problem. Battery voltage ok. I checked with voltmeter. -
Thanks. Seems like a good idea. Thing here is I couldn't find a backup battery near by. Is it safe to drive with this problem? -
My 12v power bank automatically turn off when there is no output device. I'm not sure whether the power bank provide power as backup battery when the car engine is not running. -
Is that OK to use below steps.? 1. Start the engine using main battery 2. Connect 12v power bank to connectors 3. Remove connectors from battery terminals 4. clean the terminals 5. Put back the connectors to main battery 6. Remove 12 v power bank from the connectors 7. Stop the engine -
Suzuki Swift 2010 (Japanese beetle) -
Hi, My car dashboard lights flickering and all the meters in dashboard not working. I think this happen because of bad battery terminals. But I can not remove connectors which connect to the terminals because then my car player get reset. Can I clean battery terminals without turning off the engine? Or else Can I use car jump starter power bank to give battery power until I clean the terminals? Are there any other ways to clean battery terminals with support of power bank?
Hi,I got a problem in my Samsung 3D smart TV. When I power on the TV, red led blinks 5 times and then turn it off. This happened suddenly. But last 6 weeks we didn't watch the TV as usual because we were away from our home. I watched several vides but I couldn't find any bad capacitors (I'm not good at electronics).Any help would be appreciated. thanks
Hi, Anyone have experience in smart key programming for cars? My car smart key is malfunctioning so I called several places/persons and it will cost around Rs 18500. When I checked the ebay there are car key programming units available around 12k (I search for one, which is compatible with my Suzuki Swift 2010). Can we do it ourselves? If I purchase car key programmer unit, I might able to start part time job to program these smart keys at cheaper price. What are the risks associated with it? According to youtube videos, key programming is not a difficult task. But reality is that the same? thanks
- 3 replies
- 1
- smart key
- key programming
(and 1 more)
player How do I select correct multimedia player to Suzuki Swift?
Thank you -
Thanks. Do I need 2 din player or single Din player? -
Hi, I want to fit new android multimedia player to my car since the model I'v is not supporting for video and usb. I'm going to buy it for ebay or aliexpress. Before buying one I need to confirm the below things 1. The existing player screen size is around 7.3 inch. But it seems (not sure 100%) 7.5 inch player will fit to the existing slot. So is that OK to buy 7.5 inch player? (Please see attached image) 2. As you can see in the attached picture, there is a large panel (Around 9 inch - top side and 8.7 inch bottom) also available. Can I remove it to fit large player? Thanks
Hi, I didn't use my car for about 6 weeks and when I opened the doors noticed that some mold (fungus) growth in car seats. Anyone know how do I remove these? (I have vacuum cleaner but it doesn't support for wet vacuuming) thanks
Hi, Yesterday I noticed that there is a mango tree sap in my car bonnet. I tried to remove it using car wash and then using compound. But those options failed. What shall I do? thanks
Dashboard lights flickering when AC is turn ON
Thank you for your assistance. After cleaning the battery terminal, that issue got disappeared -
Hi, I observed that my car(Suzuki Swift 2010) dashboard lights flickering when turn on the AC. Also heat meter goes to danger(red) level when it turn on. Also that flickering comes when the fuel level go down to the "E" level. Seems like when some indicator light is turn On (when AC is turn on or fuel level) in dashboard these flickering occurs. Where should we need to check? Thanks p.s : I'm rarely using the car. Last time I drove it after 3 weeks.
Hi, In my annex I don't have a proper indoor location to park my car. Due to rain season car is always wet. Even the sun comes car doesn't get dry because of trees around in my parking location. I saw some tiny rust in inside the door edge. Do you know any options to prevent from rust or dry car? thanks
Hi, During this weekend I need to service My Suzuki Swift (71S - Japanese). Seems need to replace AC Filter and Air filter. Anyone know exact models I need to buy? Beacuse the prices of both filters too high in the service station.Also please send me a messag regarding the places to buy Thanks
Anyone know about Anoj motors- Dehiwala?
