flashmark
Everything posted by flashmark
Hi, Anyone know good accident repair workshop around Mt.lavinia, dehiwala or Rathmalana? Thanks, Flashmark
Suzuki Swift (Japanese) Tyre Pressure ?
flashmark replied to flashmark's topic in General Automotive
If Vitz max loading capacity is 275kg, then Its a big problem. 4 people avg weight is 280kg (without any extra weights - bags). -
Max. Loading Weight 460kg -
thanks All. According to that recommended air pressure is 33/30(front/rear. See attched). But when the car loaded with 5 passengers ( 2 front/ 3 rear) and 100kg of load, what is the recommended tyre air pressure front and rear? -
Yes. I coudn't find it -
Hi, Can I know the recommend Tyre pressure for Suzuki Swift(Japanese beetle) 2010? The car has alloy wheel 15". I saw below in the web but not sure this is correct or not. http://www.puretyre.co.uk/suzuki-swift-tyre-pressure-placard/ Please give your advice. Thanks
Is it OK to switching to new engine oil?
After another 300+ km, I didn't notice any significant changes(only 2-3 mm) in oil level. So I hope nothing wrong with the compatibility. Thanks for your advises. -
Thank you for all. A separate question : I compared Mo*il 1000 Vs 2000. According to that mobile 2000 recomonded for a vehcile which ran over 120,000 km. Don't we need to switch oil to 10W-40 after running 120k but switching to mo*il 2000? (http://www.mobil.ca/Canada-English-LCW/carengineoils_products_mobil-super_2000-5w30.aspx#) -
Sorry. I forgot to mention the mileage. Car mileage is 49,000Km. Previously I used 10w40 but it is bit more thinker to k12B engine. (I used the oil grade which recommended by A*W.) So this time I used 10W30. What is opinion? Shall I continue using this until next service (with top up)? -
Hi, I recently changed my Suzuki Swift engine oil to Mo*il 1000 (10W30). Earlier I used Ca*trol 10W40 magnetic. I noticed that little bit of oil level change after 250Km ran. I refilled it. Is this normal? One mechanic said sometime I will have to go back to previous engine oil. Is that true? Thanks
Hi, Currently I'm using ca*trol 10w40 for my Suzuki Swift beetle (Japanese 2010). But when I asked fro Au*oMir*j they recommend Mob*il 10w40 (which is cheap in price). Mileage around 50,000Km. What is your opinion on this? Thanks
Hi, I replaced my suzuki Swift remote intelligent key battery 4 days ago. I used Engizer battery for best performance. At that time remote key worked fine within 10m range. But now it is work only if the key is very close to the car (1m). I got the same experience with the old remote key battery. Seems this is not related to key battery. Any suggestions? thanks
Today I replaced the steering wheel from AM*. Since they don't have b/n one I went to Delkada and bought one from there. There were same item in several places. Ja*pan La*ka said it would cost Rs 12,500 (B/n price Rs 17000.00) Ni*on La*ka Rs 6500 but it was looks very old and dirty. Sha* Mo*ors Rs 6000 and it looks new. If anyone want contact no, please PM me. Most importantly this very common problem.If Airbag indicator stays ON, then better you check the ribbon in steering wheel.
Place To Buy Seat Belt And Airbag Ribbon - Suzuki Swift
I don't know about others, but personally I go inside to a partcular topic if is interest to me. You may don't know about the mechanical questions but you may know about the popular spare parts shops.Don't you? -
But under different topic -
They don't have it. Do you know any other place to look into?
Today my car scanned from Au*o M*raj and foud that fault in driver side seat belt . I don't know how it happened. Today Morning I noticed that the car hron doesn't work (Yesterday I did underwash). Au*o M*raj suspected that the ribbon of the steering wheel damaged and they removed the steering wheel to find out.Now car horn doesn't work at all. They said I have replace both and it will cost around Rs 28k. Is that true? Unfortunately I couldn't find driver side seat belt and ribbon from spare part shop.Do you know any shop to buy them (I checked it with A*W but they don't have it. To get them will take 3 weeks.I can't drive 3 weeks without horn )
Hi, Yesterday evening had under-wash to the car from Au*o M*raj. Also as per my request they spray the "break cleaner" without removing break pads (just removing two front wheels). But Today morning I observed that when I press the brake it make noise(It is difficult to explain the sound. But its bit similar to whistle).When I checked the break pads 3 months ago they were good. What could be the problem? thanks
Hi, Do you have any experience about petrol system treatment? Does it actually work? Does it safe to use?
I asked from A*W Technical and they said "General Scanner" will find the problem and he asked me to go any dealer. According to your exp. waht is the best place to check this ? (Around Mt. lavinia). Au*o Mi*aj? Kl**n Pa*k ? What do you recommend? What do you think about German Tech?
Hi, Today I noticed that in my suzuki Swift Airbag indicator stays ON. I didn't do anything to the car. What could be the problem?
Do you recommend "X-*R Auto Transmission Treatment" ? https://x1rcorp.com/product/automatic-transmission-treatment/ Please share your expedience.
Do you know a place to buy door visors for Suzuki Swift (2010,ZCS71s model)? I check it in S*n Lan*a. But the model they have not suit for 71S model I don't like to go to Darley road.
