godwinAmila
Everything posted by godwinAmila
  1. Hi nano31, Thanks for the reply. Do you know any place that I can get done this work ?
  2. Hi All, I have Toyota Passo, there is a problem with the Key (I exactly don't know weather problem is with the Key) problem is, when I switch off totally then I cannot switch on back,I have to put some big effort to switch on that, even I switch on when dashboard indicate the light (Horizontal car), then engine is not starting. Then I have to switch off and try, when that particular dashboard light is switch off then I can start the Engine, I need to fix this problem immediately, If someone can give me a advice it'll be helpfull. Regards Amila
  3. Ok. I'll do it and let you know that.
  4. Hi Thank you very much for the advice. Do you know any kind of place other than Toyota Lanka for fixing on this ?.
  5. Yes.
  6. Hi All I have a Toyota Passo. It indicate the EPS and it has became a real problem for me. I made a scan from one place and it showed a fault as Relay failure. Can anybody give me a advice for this to sort out. Thank you Amila
