Everything posted by varunatech
Y Does Hybrid Vehicles Sells So Soon?
In the first place, a low power engine does not mean low fuel consumption. The correct power should be there to operate efficiently. Let us compare the Prius and a similar engine from Toyota. Prius 2008 Horsepower 110 @ 5000 RPM Torque (lb-ft) 82 @ 4200 RPM Allion 1.5L 1NZ-FE Horsepower 110 @ 6200 RPM Torque (lb-ft) 103 @ 4200 RPM We do not get a good comparison, because the Allion produce 110 at 6200 and it does better on Torque at 4200. Ina addition consider that, when the Prius need more power, it operates both engine and battery power together. Hence even if we see that Prius engine looks low in power, that is intentional. The remaining is powered by the battery. I cannot agree with that lighter materials are not safe. Firstly there can be lighter material which are higher in strength and good is energy absorption. Actually the "papadam feature" of the modern day cars save our lives. Life is more important that heavy metal body and less damaged car. The soft materials will absorb the energy and minimize the damage for passengers and also to the other vehicle or pedestrian. Other issues, I cannot comment as I have no first hand experience or factual data.
Fuel System Cleaners - Bg 44K Vs Chevron Techron
My experience is Pre Ignition knocks at low RPM under load. This is mainly due to carbon deposits on piston crowns. Wurth did not help here. By the way, Wurth is a very good brand which is professional grade. If you just need injector cleaning this would be good. For Injector cleaning, the other method is Ultrasonic. I got the same done from D*** recently and they did a decent job. From my research, this is the best way to do Injector cleaning. But mind you this does not clean the intake, valved, piston heads and piston chamber. Usually you need to clean all these after sometime. Thank you for the BG tip, I will contact them.
Where can you buy BG Products in Sri Lanka. I am looking forward. I have not used Valvoline.
Recommended Octane Grade For Premio Nzt 260
I do also beg to differ, 1NZ-FE and 2ZR-FE engine manuals state to use RON 91 or above. The RON is the value we see in our pumps at gas stations. Please check the Ceypetco and IOC web sites (Ceypetco) one has errors though.they have mistakenly mentioned few things in their detail fuel specifications.
The 1NZ-FE and 2ZR-FE (the engines used in Belta, Vios, 121, Allion, Premio 240, 260)....The engine manual clearly state to use RON (Research Octane Number) 91 or above. In Sri Lanka we have RON 90 from Ceypetco and IOC. RON 95 from both again. IOC Claim XtraPremuim is RON 93. So, the clear option available is RON 95 from Ceypetco and IOC. And if IOC confirms RON 93 is in XtraPremium. These information is based on Toyota Engine Manuals. Where they state anything below RON 91 for these engine will cause engine knocking and does not advice at all. Hope this helps. Frankly I did research the issue for a long time, referring engine manuals, and taking advice from multiple sources.
Premio 260 NZT260 has a 2ZR-FE engine. Engine manufacturer specify to use RON (Research Octane Number)91 or higher. So very simple, in our country we have RON 90, RON 93 (According to IOC XTra Premium)and RON 95. Your options are IOC Xtra Premium (RON93) or RON 95 from Ceypetco or IOC. Your engine is not designed for RON90 (Or 90 Petrol). By the way same goes for 1NZ-FE engines (Belta, Vios, Allion 240, Corolla 121 etc..). The above data is after referring to the Toyota engine manuals. Hope this helps.
Is It Advisable To Go For A 2008 Toyota Belta? Experts Please Advice
Thank you for your view. When we say investment, the result can be + or -. The effort was to see how minus it is. Yes models are very fragile, but we need some frame work to work on. Probably the results may be far from truth at the end of 4 to 5 years. But there is fun and enjoyment in doing this. Will see how I can share the calculations. Txs.
Calculations are multiple equations. If possible I will share the excel. For Fuel economy it is simple. If 1300cc does 12km/l in CMB city and 1000cc 10.5km/l, you know how much you pay more for the 1000cc per km and for an average month. Then you can get the cost of having 1000cc vs 1300cc for four or five years just on fuel cost. Do the math and see after entering realistic figures based on your expected driving pattern. You will see whether the saving is worth or not. You may need to add inflation parameters if you compare against the capital cost difference at the time of purchase. ROI can be +/-. You know your investment (capital cost), you know the expenses on maintenance you incur for a given period of time. You can judge the value of your car at the end of the said period (based on prior data on similar cars, growth in economy, and using gut feeling and rule of thumb). Then at the end of the said period you know whether you gain or loose. Can calculate and see what is the best outcome. Usually unpopular options like 1000cc is lower ROI than 1300cc. But the buyers current finance pressures may call for a 1000cc. Multiple factors, kind of fun to analyze.
Mate.......the answer was targeted to envision him to think more on his actual requirement. Do a full TCO and ROI calculation and see whether the fuel saving of the 1300cc will fill be a factor after 3 to 4 years. I have done detailed calculations on different vehicles using realistic data. My view is based on that. Again the point is, every individual has different requirements......can be Prestige, just move from A to B, Off Road, long distance travel, large family etc.. The intention is to help him to see that. There are enough engine, model, brand, new, recon, used options in the market. Once the fellow know his requirement he will choose the right fit.
Toyota 121
If you need advice, help or tips. Kindly state what you are looking for. This open ended question can be answered in many ways. Dude you are not helping yourself, how can we help you.
Agree with you that 1000cc is not VVTi hence the engine is not efficient compared to 1300cc for the same weight to power ratio. Following are things to think......before concluding. Do we have any figures for 1000cc fuel hungriness. And what are the facts that 1300cc is "not good" for a Sedan like Belta. My experience with 1NZ-FE engines, Beltas, Vios, Vitzs is that 1300cc engine is pretty decent with the weight and the CVT of the Belta/Vitz 1000cc is mathematically low power and will burn more fuel to produce the same energy required to beat the road, air friction etc.. But can be a good choice for a price sensitive, City commuter. Txs.
Allion 240 Engine, Color, Chassis No Information Plate Location
When you open the front passenger side door, you will see a sticker pasted in the door well (as we call Dora Kata). It has the required info for you. By the way engine is 1NZ-FE VVTi.
It all depends on your requirement. Toyota Belta is designed to run with 1000cc and 1300cc engines (kind of same frame with 1500cc in Vios). With the linear power output of the VVT-i engine, efficiency of the CVT transmission and with the overall light weight of the car, a 1300cc engine is just fine. A 1000cc engine lacks the VVT-i but the other qualities are the same. Therefore, if your requirement is to have a compact Sedan which has good build quality and enough power to quickly accelerate (even with four people and luggage) 1300cc is the option. But if you are just a office commuter and use the car mainly in City, a 1000cc will do. You may need to sacrifice a some quick acceleration under load. again this is a relative thing and may probably suit your life style. One thing to note with 1000cc is that Sri Lanka car community does not like 1000cc engines. You may have a tough time in resale and resales value. But again if your current concern is low capital cost and City commuting in a Compact Sedan.......Belta is a good car with good quality.
