varunatech
Everything posted by varunatech
  1. varunatech replied to ashan82's topic in MAZDA
    Friend, what I can do is guide you from my experience, and from what I see in as text in the forum. It is different from seeing your car and also driving and later having a preliminary look at your throttle body, air intake system etc... My point is, take the guidance, go to a reputed place, not to a maka bas. Even when you get to a reputed place, the guidance and your own common sense will help, I have seen reputed places doing worst than maka bass. By the way, if you are experiencing a knuck, knuck type of sound (as Ripper says not a Crrr Crr sound), (some yaka bass call it ignition gahanawa) and if it goes away with 95 Octane most probably you have a pre ignition knock issue due to chamber soot and the red hot carbon firing the fuel mixture before timing. Does this noise goes off if you apply more gas or shift to a lower gear and apply gas.........if so 99% it is the case. And if it is the case........you can remove majority of the soot by doing an fuel intake system cleaning........this works most of the time both 3M and BG does a good job while there are other brands as well. My experience is mostly with BG, where it has got dramatic results. But know that 3M and seaform works while I am yet to find seafoam in Sri Lanka. You can follow this with an injector cleaning with Ultrasonic (best way) or again using liquids from 3M or BG. For Ultrasonic go to D**O or An***su (search the forum). Above is the cheaper and practical way of doing this. Again, you need to identify the sound, it should go away when you apply more gas and with 95. Still............show it to someone with experience then he can listen and feel while driving. Secondly why 20W 50. The 50 is too high for your car...........I am surprised. When I checked, but not confirmed the 2003 q.5L engine is designed for RON 91 r above.
  2. varunatech replied to ashan82's topic in MAZDA
    Ripper, if the guys engine has chamber deposits, he may be experiencing pre ignition knocks. The pre ignition knocks goes down considerably when higher Octane is pumped as the higher Octane ignite bit slower. Would like him to explain more on the sound and the overall experience. The car might run well on 90, but I have a feeling it is designed for 91 or above and when you pump 90 for a long time the chamber deposits (soot ) is higher, all these time his knock sensor would have done a good job, but probably now the pre ignition is too high it cannot correct. Let us see what he has to say on the overall experience.
  3. FB14 and AE100 fits the equation and with manual transmission you will have 10+ kmpl. Ample spare parts and know how on repairs will be a comfort. When you get the car, take to a good mechanic, check all the oil conditions, rubber parts (belts, boots, bush, hose etc..). And if required replace them. Check the condition of the coolant and radiator, if fits do a full coolant replacement. If he is good he will inspect other systems (i.e brake, battery etc..). I do sincerely suggest the above that keep some money to spend on these needy adjustments and repairs. [Mind you, you need cash to but, transfer/register, insurance, emission test, license and also for above mention repairs.] Last but not least, do a cut and polish and an interior cleaning followed by a good wax. Cut and polish and interior cleaning if required only, but always try to wax at least once a month. You can do it yourself, do not pay for the unskilled at service stations. Then you will be with an old car but relatively in good condition. Enjoy and drive safe. P.S My personal view may not matter, I do prefer AE100 over FB14, but that is in my viewpoint based on spares availability and relative reliability.
  4. varunatech replied to ashan82's topic in MAZDA
    What is your engine capacity and the engine model. 1.5L ZY-VE seems to be RON 91 or above................
  5. varunatech replied to ashan82's topic in MAZDA
    Can you explain the sound a bit more. Is it only fast accelerating or even when you go slow but under a load. The point is under a load, climbing or trying accelerate when you have weight with you. My first hunch is a pre ignition knock, if so pumping 95 will help. But first explain more. I am not sure about your Mazda model, but as I have see cars manufactured in Japan are designed run on Octane (RON) 91 or above. Sometimes 92 or above. But many Sri Lankan do not read their manuals or if they are in Japanese do not bother to search for further information and just pump 90. I have met people whom seems to be pride and joke at others for pumping 95, while his engine is pretty evidently designed for higher Octane. You may search the forum, you will find more information.
  6. Malaka, I did reset the ECU the same way you have suggested.
  7. AC or non AC the issue is same and it only occurs after a prolong cold period. More than 24 hours. Else everything is pretty normal and the power up diagnostics and procedure goes well. Yes will connect this to a scanner and see and I am planning to check the ICV as well. Thank you for suggestions.
  8. Please see my post, I have reset the ECU and also this does not occur every day.
  9. Actually, not the same road, we went totally off way from Ohiya, Horton....this road leads to the base of Devils stair case.......rain washed and pathetic..... and my memories goes in few other places in other parts as well as some where in eastern part.......
  10. no machang, these are sharp obstacles...........you apply power and go over one and in a fraction you need to brake sharply to avoid hitting next or going to a ditch. Then you stop, turn the wheel, find the next grip position and apply power and move. It is like crawling from point to point in few inches distance. These are rain washed foot paths, even some lorries wont dare, sometimes we need to get down and adjust few boulders........mind you it is not a Jeep it is a low ground clearance car. Car gets a beating in low gears and sudden braking, but worth the fun and scenery.
  11. Thanks buddy, it will help. But I really would like to see where it comes from and to find out based on theory. What makes it does this only on long stops. What does change in long stops.Because the pattern is clear...............
  12. Sorry forgot to include.......did reset ECU......and mind you this is not recurring. I also have suspicions on IAC Valve. rather than jumping on replacing, I want to build a case and zero on with facts.
  13. Fully agree, next time these folks will try their left foot in E01 as well.
  14. And to tell you one example.......... Location was off Ohiya in a teas estate........a so called road inside the tea estate.......we took a Auto Toyota 121, for about 5kms of stretch spending good 45 minutes. A 400ft drop in the left. and few very narrow hair pin bends. And the torrential rains has left only rocks and all and climbing. We had not a single bump or under body scratch. Later a Van with ground clearance followed the same path with other guys. He had light load compared to us as well. The driver was lamenting saying 10 times or "Yata Vaduna" and his eyes went into sky when he saw the Car has gone before him. By the way need to mention we use the Parking brake as well. Again no way on roads, I am more than happy only to use my right foot.
  15. No man, it was not taking care of the car actually, but due to the toughness of the road with obstacles and steep climb........... and I never recommend what the OP say.................never in Roads........
  16. Friend, you did not get what I was trying to explain........you cannot have both Power and Braking same time, but switching between the two very fast. The roads I am mentioning here are very bad off road conditions. A normal Auto car user will not eve a dream of. We just do that for the fun and when we take off routes in normal trips. The uneven climbing and too many obstacles require to brake suddenly as well as immediately apply power. So we do this. By the way I am No Way Supporting or Seconding the OP's way of doing.......
  17. Experts, I am trying to zero down on a problem shown by a Toyota 1NZ-FE engine at cold starts. Following is the background. Engine: 1NZ-FE 1.5l YOM 2003 110k kms. Air Filter: New Tuning: Recently done Throttle Body: Clean MAF Sensor: Clean and ok Plugs: Good Fuel Consumption: Normal and Good Engine Oil: Toyota, good condition Overall: Well maintained Fault Codes: No Fault Codes Symptoms: "ONLY" on "some" cold starts, the engine revs to 2200 to 2400 RPM. And get settled after warm up. Mind you this is NOT the usual engine warm up and self diagnostic routine, where RPM goes to 1800 and later settles. Please rule out that. This high RPM is beyond that. And I detected a pattern after reviewing that this happens when and only car sits for more than 24 hours. If the car runs everyday and long distance, everything is ok. Beyond this the user says at rare intervals and in traffic the engine try to go lower than 600 RPM and then kicks back. And this is rare. Please comment.......with your views.
  18. I never use in normal driving, but at times..........when myself and a friend of mine......at times take Auto transmission cars on rough roads and when climbing at snail speeds (due to rough road, gal and mul) I do use left foot braking. Mind you at very slow speeds where I need power and braking just to get over obstacles. That helps and has practiced in many times. Mind you these are off roads, Tea plantation up country...... But in road..........too bad..........
  19. Same here, awaiting your comments.
  20. Really agree.......there was a time the Randenigala Rantambe was in good condition. We used to travel through that just for the fun of it. The san carrying trucks ruined the road. Hope the authorities will put that road in shape as well. Will be a good strategic connectivity for the Eastern side of the country through Mahiyangana and Bibila
  21. Mirrors in every corner..........very good safety device. And there are stretches where you can overtake where center marker clearly showing...........and yes your vehicle should have the power to do so.......any average Toyota, Nissan, Honda or Suziki with 1.5L engine can do that.............so what to whine about.............enjoy.................
  22. True, yet compared to the previous state of the same road and the way it has been widened and given that this is one of the toughest decent with unforgiving terrain............this is a remarkable achievement. Secondly imagine the finance cost of building two lanes..........if you need to speed go early in the morning or at night......then you will lose the beautiful scenery.Looking at the practical side, we need to say kudos when it really is, rather than complaining for every thing............
  23. Guys, the change of temperature has an effect on the volume you pump, it is correct. But the issue is how significant............specially for a country like us where the day to night temperature change is not that significant. Mind you the underground tanks has more stable temperature due to the fact they are shielded by the soil working as an insulator. The issue becomes realistic when the pump pushes the fuel out and reaches the ambient temperature. The following link shows a study done by Australian government to see the actual realistic effect. The conclusion is that the effect is minimal across the vast continent and across different temperature changes. And it is not cost effective to install correction devices. http://www.energy.ca.gov/transportation/fuel_delivery_temperature_study/documents/Australian_Study_1996.PDF Fuel vapor does not get leaked to the environment in significant quantities as all fuel circuits in modern vehicles are closed circuits. The vapor trapped in the tank is circulated through charcoal canisters and recirculated. There is some truth to the last point, where the under ground tank content get stir when a bowser unloads. The pumps has good filters to make sure the contaminant which are floatable does not come out. But things can reach your tank. After reviewing these facts.........my personal view is I do pump when it is needed or convenient. But I do try to avoid to pump from just after bowser unloads. Rather worrying about the vapor and all, I try to keep the engine in shape (air filter, throttle body etc...), tyres with correct pressure, boot clear from junk, and avoid jack rabbit driving styles. And do Italian tuneup time to time
  24. These rear fogs are never meant to be kept ON, in traffic and city driving. They should be used in highway or out of city when and only rain, fog or snowing happens. If a usual moron decide to use it in bumper to bumper traffic or city driving, he shows his level of understanding. Usually the rear fogs are not mounted high, they are the same height as brake/parking lights. Only difference is they are relatively brighter...........making them visible from a long distance, the brightness is required when you are in fog or rain and also when in a highway and the vehicle from the back come at highway speeds. I also noticed that some Indian vehicle advertised rear fogs. I am not sure where they are mounted, but I am sure of one thing, the owner will use it as a show off in city traffic.
