Everything posted by kmcsb
Help With My Eg8
still no vaccum from #20 when switching on headlights...i chked tht both alve are connect to the solenoid valve.. oops tht means i have to laofed more to sech tht air filter..ohh..its coded C422 on top of filter..but no brand..
Help With My Eg8
OK I finally I chekd both (idle solenoid valve and eacv valve)got voltage..I ckecked by electrican... So I replaze new hose to eacv and start engine..but car got poor idle(rpm goes up and down)..so I replazed with old hose again..now idle is came back to normal.. Then I remove the vaccum box however..I saw that air filter is full of junk and half of paper is damaged to..is it difficult to find that air filter?? I cleaned it by vaccum cleaner.. I saw the idle boost solenoid valve but its far inside..unable to see it completely..but I inspect wheter there broken hose..but not..all are seems OK.. So I reset cover and start car..still same rumesh.. Idle is OK.. Ac idle is OK..but only issue is when turning on hedlights,blower,apply brake rpm goes down to low(500,300)..
Help With My Eg8
OK that's a relief..now i trying to remove box.and I have no I idea its stuck somewhere.and I'm unable to remove the lid...and where is the filter?? How am I clean it?? For eacv ..yes some one has block eacv to air filter hose.when i inspect i saw some rubber ball inside tht hose...so I'm going to replazce with a new hose..thanks...
Help With My Eg8
Hi rumesh I tried to remove that control box (vacuum box) but I'm unable to do..I need to figure out why is idle boost solenoid valve is... I think it is the issue..is it easy to find replace part..do you have its OEM number.. Also I chked my air idle valve vaccum(eacv) hose has blocked by some maksbaas.. I cked it by removing its connector plugged and unplugged.. At that moment I heard some pop sound coming from that valve..is that mean it's working right...and I feel there's a vacuum coming inside of it...but I don't know why they blocked it...it it OK to replze new vacuum hose for that...
Help With My Eg8
first i chked #20 vacuum hose by hedlight/bower/ac off......then ther has no vacuum after tht i swich on blower and headlight only ... still no vaccum got... ( it think if valve is working ,then there should be vaccum when headlight and blow on)..is it ??
Help With My Eg8
- Help With My Eg8
rumesh i read you pdf top to bottom and diagnosost my problem i think.. i found out tht #20 vaccum line has no vaccum.... only got outter hose( tht goes to a/c idel boost soloneid valve )..when ac is on.. idle boost throttle controller has both vacuum..it means controller is working right?? #20 vaccum hose no vaccum mens there a problem in idle boost soloneid valve (in cotrol box)..isnt it ??? i tried to remove top cover of contol box but im unable to do it... if it is tht issue will tht valve able to find it in local market...??- Help With My Eg8
my friend H.C ..for fuel gauge reset i did a trick ... 1.remove cover and remove both connectors.. 2.very gentely rotate fuel needle to high mark... 3.then plug onlt right side connector only (10 pin)..and turn ur ingingtion on.. then youll notice your needle come to down litllt by little and stop some point..( i think thts the fuel level mark) 4.then turn off igingation.. 5.then plug the other connector (12pin)... 6.fix the cover .. 7..and reistall gauge cluster.. anyways i tried tht temp will work on you method...- Help With My Eg8
i asked from fb guys..some are recomand priyantha motors -kiulapone ...do you know them.some of saying he's resonable..how about his work and price?? normally how much is cost for reset odometer???- Help With My Eg8
ok ill ask from technician .. when i start the engine temp needle goes directly to high mark(when hot engine)....and needle goes to middle position (@ cold engine)....but when i switch off car needle come to low position...- Help With My Eg8
speedmoeter is working now..... my other gauges are working well also except temp.... when i switch on my temp needl goes top high end....(red mark) my previus meterboard temp was woking well... also do you know any plz/person to adjust mileage..??- Help With My Eg8
this one i installed... mine eg8 single carb....will it compatible with my car???the person who sold m told tht is working well..but im facing some issues.. today i chked condition of speedometer ...so i did a test drive on highway... speedometer needle smothley reched to 40kmpl but after its passed 40km/h is stuck a while and jump 50-55 in few second....also 65-70... i reached maximum 120kmh...during tht sessoin its stuck @3 points and refresh.. why is tht??? will it be repaired... also this is passed more tht 200kms..m my genuine mileage is 166kms.. is there a way to get back this to original mileage without replzing old one..... will technical can do this thing.... does anyone knows any better technician can solve this problem??- Help With My Eg8
Finally I got meter board with tachometer... Now when car starts its idle near 800.. But I switch on headlight its drop to like 400 rpm.. Also my new Meter board temp needle top up (red mark) when I turn acc on my key...also when I switch off igingation temp needle drop down to low... But my old meter board temp needle works OK..all other gauges were working- Eg8 Single Carb To Vtec Conversion
thanks bro- Eg8 Single Carb To Vtec Conversion
Can anyone pls send mashesh (carb) pliyandala...- Eg8 Single Carb To Vtec Conversion
<blockquote class='ipsBlockquote'data-author="derickreaper" data-cid="257766" data-time="1393426840"><p> I found a gr8 guy who lives in piliyandala called Mahesh (working @staffords)who works only on Honda and he does carbs I went there to get a quote for my cars engine tuneup and that place was like heaven.. Lots of eg's ek's..☺ drop me a pm I'll give the number..</p></blockquote> Hi bro, Can you pm mahesh nmuber ,adress and how much did it cost for tuneup??? I fedup of serching a good tuneup guy.. Still my eg8 does 7kmpl...- Help With My Eg8
Fianlly replaze both right sides bearings(razors)....do i need to do wheel aligement after tht???- Help With My Eg8
ok thanks bro..i''ll chk....- Help With My Eg8
bro if you can plz pm there numbers and locations .. im in kotte..- Help With My Eg8
i went to wheel alignment plz , after inspect there told drive side front wheel bearing has gone..if it so ,do i need to put bearing on both tires as well...??. only right- front has gone...- Help With My Eg8
its sounds like dak dak ..- Help With My Eg8
i got eg8 and i heard some noise on drive side wheel when turning on left..... what would it be...??? i just repaired whole suspension 1 year back ( shocks,bushes,aligments) annd im in still stock tyres size 175/70-r13..- Help With My Eg8
how do i paint brake calipers and drum... will TOA spray do the job????- Best Rim/tire Sizes For Eg8
hi H.C plz chk your inbox..i sent you private msg.. - Help With My Eg8
