Everything posted by kmcsb
Car Vibrates-Plz Help
thanks rumesh.. this is very useful..
thanks rumesh.. anyways do you have high quality image than this..i got print-out.. but its Littlebit smoke..
hi rumesh, i just chk my dashpot has two vaccum lines..i checked both got vacum(air) one is #20 and other cannot read..#20 is on right vaccum line-in... i notice one vacuum hose line got small craked..(i highlight with a red circle) is this a issue?
ok rumesh ..i"ll try to find it...thanks anyways....some honda genius coudnt find this problem...you are a master mind..
can u tellme which dashpot vaccum line should i chk..if you can plz post a pic
how can i chk tht dashpot is worikng correctley...??
i read your artilce again and redo your steps..but nothing changes..still vibrates...
Today I showed my car to technician..he chked my charging is ok...igot 14.5 whlie hedlights on...normal its read 13...
Today I showed my car to technician..he chked my charging is ok...igot 14.5 whlie hedlights on...normally its 13...
Finally I got tht part again...I reintalled and re-connecet 4 vaccum lines...but I still got vibrations while switch on hedlights, press brake, rolling up windows shutters.... But after re-set tht senosor cold start vibration soloved... pls help
Help With My Eg8
im going to replace my belts for the first time...so guys wht brands are ok..?? mine honda eg8 single carb i heard mitsuboshi is good....is tht true.. if yes can u send me part numbers of them ..( alternator,power stering,Ac ) thanks... when changing belts( without T-belt) .,,does only need belt or need any other things(replacment parts) pls tell me...beacuse this is first time... also how about brak bads??? wht is best?? FBL or FBK??? if you can plz send front disk brake pads oem number also...normally how much they are???
Help With My Eg8
Does anyone know where to buy door visors for eg8??
Repair Kit
thank you bro..pls pm his number
Repair Kit
i wish to rebulit/repair my carburetor on my eg8 single carb...... anyone knows good mechanic around in Colombo???? how abut malbe -upul??
ok thanks rumesh ..ill try to find tht part somehw..any ways thanks for your help again..
yep...he has just bypass it some other hose..i chked it today..yep my cold start is working,,,,do you wat is #18 for???you mean the reson behind this vibration acoording this broken valve?//
hi rumesh i chkd my vacuum diagram and #18 called charcoal canister...will it be effect tht my vibrate probelm???
no he just put a screw on it ..yeh i know its ajoke ....but i asked him would it be a problem...he told me tht no problem...i 'll post a pic later...
yep i found tht thermo valve with very difficulty....but he is twist wehn installing..line is closer one..its printed as #18.....ooops then i should need to fnd anther one...ohhhhh...rumesh do yuo know ay plz to get tht thing..this one is recondition part also......ooops.... i hav it part number -17350-PM3-013...
i think this is the vacuum diagram of my engile..yes its simiiler to d13b2.....but engine blocked as D15....anyways i upload photo tht for you waiting for answer... http://s13.postimg.org/6oixvx2p3/vaccum.jpg
my fuse box like this i cant see any eld unit on tht... tht dashpot item was replazed few months before..i think you probley rember it, tht was break some monthts backk.u have seen tht in my car.... finally i got tht part but when installing it 1st line was cracked by mechanic....thten he bypass it ... i think #18 vaccum line... then car works smoothley and begin to work cold start rev up also.... if i can i'll send a pic of tht.....
Ok thanks rumesh.. Is tht mean my ELD unit got an issue or not?! I think i still having original alternator..but i heard some small noise (like bees ) from alternator as well.. also i refer my manual i think my engine doent have ELD unit....my engine just smiller to D13b2.. I have got fuse box diagrams but unable to locate ELD unit.. i think my one iis 94 civic Lx model....uk model
Rumrsh FYI- i just found that vaccum relasing valve tht my AC repait guy had tossed..and i replazed it and set the vaccum horses correctly..now doing revup in cold start is ok.. SO i think problem wont reletive from tht point.. I also notice tht another dashpot line (unknown) goes to AC idle up valve.. When i start on AC engine idle up..so no worries when Ac on..only thing is Car gets vibrate when putting headlights and rolling up/down shutters and press brake.. Pls hlp rumesh..will it be a electrical problem?? Tht electric guy told me tht car is charging very well..when i on headlight its suddly drop 12v and comes up 13.5v just a few seconds..(used voltermeter)
rumesh i chked and didnt get any vacum on input on solenoid..so??
Ok i chked then i have notive my dashpot has 2lines/vaccum..and saw one vaccum hose name as 20..but other is uknown..so i just put headlights and remove #20 first nothing happend still vibrate..also took out second one also..same thing..then i refit 2 lines and put AC on..then i heard engine rev up..then i took out #20 nothing happend..still on rev up state..no vibratins ..then i tookout next hose(unknown #) then suddnly car gets vibrate.. So wht you think sir..im very thankful your giving hand like one of us..very appreciate..
