janappriya
janappriya's Achievements
  1. Thanks for your thoughts
  2. Hi All, I am planning to change ATF in my car. It's a Nissan wingroad with "QG15 DE" engine. What would be the recommended ATF for this engine and how much will it cost around per letter . This engine is same as in FB15's. Thanks in advance for your thoughts, Sampath
  3. is it? i forgot ask his name....dammm
  4. Hi, it a place @ cotta road (Rajigiriya). It cost me 2300. It not a big garage. It is just one man show. Guy seems to have good knowledge. If you wanna go there I can give you the directions Cheers, sampath
  5. I did this too during the tune up
  6. Hi All, Thanks for your thoughts. I did a tune up and checked for the engine mounts and clean the idle air flow controller. After the tune up it seems okay. Bu as mention in above RPM goes up goes up significantly when the AC is on in D position. Rpm goes up in very little when I put the A/C on the D position. Is this a problem? this Nissan Wingrd (99). QG15 DE Engine. Thanks guys, Cheers, Sampath
  7. Hi, thanks for the reply, If i have to replace the transmission hangers and idle up unit will it cost a lot? rgds, sampath
  8. Hi Experts, I recently notice when I switch on the AC car starts to get Vibrate. When it in the "N" position (Auto transmission) car remain smoothly and the RPM remains around 900. When I put the transmission to "D" position the RPM drops to around 600 and cars starts to vibrate. Will this can be a engine tune up issue or a engine mount issue or any other issue? Your thoughts are much appreciated. Thanks, Cheers, Sampath
  9. Thanks for your reply. Yes there is a vibration when this issue comes. When the car starts normally I can say there is less vibration. i also thought this may be the case. Can these type of issues come due to sensor issues? If I've to do a spark/injector cleaning is there any good place where I can do the cleaning. I heard there is a place @ Rajigiriya (Cota road). Any one has experience with this place. Thanks,
  10. Hi, I have a Nissan Wingroad (Y11), Year 99. When Iam starting the car it some time vibrates and stops the engine. the engine gets start and the RPM meter goes up to 900 to 1000 and it again drops down, vibrates and stops the engine. This is not happening all the times. It happens randomly. Some times it stops first time and it gets starts on the second or third attempt. All services are done on time. What could be the reason behind this. You thoughts are highly appreciated. Thanks, Sampath
