AnushaS
Everything posted by AnushaS
  1. Could someone help pls!!!!!
  2. Cleaned the MAF(using w*r*h cleaner). still the same JBNET.
  3. Is there a difference between AF sensor and MAF sensor?
  4. Hi all, I have an accent 2000 1500cc manual car. Three weeks back check engine indication appeared but nothing was unusual.But i wanted to get it scanned and after scanning (error codes were P0444 & P0422) got to know that It was someting to do with the purge valve, which was then cleaned by a mechanic at a leading gurage in nugegoda. After doing everything light didnt come up for about another 100km+.Again the light appeared after about 100km,still nothing was unusual. when the car was taken to the same gurage a different mechanic without scanning cleaned the Air flow sensor and erased the code by removing the battery terminals. This incident happened a week ago. Apparently on today again the light appeared after about another 150-160km. Could anyone advise what could be done to rectify this issue. (still nothing is unusual on the car).
  5. Hi Friends, I have an accent 2000, 1500cc manual car. My problem is: i find a delay in acceleration everytime after a tank full of petrol is pumped. . This doesn't happen when the petrol level in the tank is below 3/4. (2 to 3 months back i replaced the purge valve due to an engine "miss" which rectified the issue) Appreciate your feedback on my current matter.
  6. Hi , I have an accent 2000 model. Few days ago i replaced 3 mounts except the gear box mount (which was on good condition ) now the issue is : there is a vibration at idle and even at the start (as never before). Appreciate if you could help me. AnushaS
  7. Thanks a lot every one!!!
  8. Hi, I have an Accent, 2000 model full option,manual car. Sometimes the center lock system (original system) locks only 2 or 3 doors, some times it doesn't lock at all. Appreciate if some one could help me out regarding this.
