nisitha
  • Location
    Pannipitiya
nisitha's Achievements
  • Week One Done
  • One Month Later
  • One Year In Rare
Recent Badges
  1. Did the tune ups in two places recently in 5000km apart, places which are known to me. i am trying to understand the reason behind the miss.
  2. I have a peugeot 406 2L petrol engine. Engine starts perfectly in cold start. The engine hesitates after a while till the engine heats up to 90 degrees with the AC load. Without the AC, the hesitation is seldom present while it is heating up. Car runs smoothly when the temperature is reached. I have done an injector cleanup and replaced plugs, air filter & petrol filter. having done two tune-ups didn't help. Need help.
  3. I was found to be right on wiring configuration. Setup needs configuration using Peugeot planet My vehicle did not have the radio configured originally. Which is why it did not work with the attached wiring configuration. I got professional help on configuration on to the cars main computer. I cannot upload the wiring of ISO connectors via mobile phone. Uploader does not work and cannot post reply without going to more reply option
  4. Head unit with cd.
  5. I am trying to install a clarion setup. earlier it had a pioneer setup. in the previous installtion they have cut the wires to connect the harness suiting the pioneer swtup. i gave the car to a well known establishment and they failed to install. i bought the harness connectors and i managed to connect all the speaker wires correctly by checking each and every sqpeaker. in the radio harness i manages to connect the ground wire which is the obvious colour code. i am left with 3 lives wires and two data i presume. grey +ve white +ve white +ve white red i got the service manual of the setup paying 5 dollars which is having the block diagram which doesnt indicate the pins i am assuming the following is the right combination in comparison to similar setup harness connector pin8 - ground - yellow/green pin7 - +ve - battery - pin6 - +ve - ignition pin5 - pin4 - +ve? pin3 - data pin2 - data am i right?
  6. Hey guys, i need the wiring diagrams of audio /radio installation on a peugeot 406 petrol 2003. hynes manual did not help. thanks
  7. Not as a bad comment on peugeot 406. I went through many threads in auto lanka and on the web before considering to buy a peugeot 406. I recently got a 406 and I love the car. Only diffiiculty that I am facing is turing in tight corners. Its a large car and it has a big turing circle. I drive a toyota vitz and I have had a nissan bluebird. They both have pretty tight turning circles. But handling & driving experience is off the chart in comparison to vitz/bluebird. Peugeot 406 - Turning Circle: 11.45m Toyota Vitz - Turning circle 9.4 m Nissan Bluebird FG10 Turning circle 10 m Harshan Can you advice me on a good garage for repairs. Initially I'm thinking of doing the main repairs at carmart.
  8. You might want to consider the turning radius of D9.I think It's larger than that of general toyota & nissan cars.
  9. upholstery has small bubble like formation, Can this be fixed ?
  10. Thanks Don. How reliable is this car in comparison to a toyota or a nissan ?
  11. What is the average cost of maintaining a 406 car including both mechanical maintenance and Servicing ?
