singithi
singithi's Achievements
  1. Yes it is Manual. I have changed with a new Coolant Temp Sensor and plugged the 5A FE ECU and after that the engine miss gone and I drive two days about 50km s. After that the same problem again came. What would be the reason. Is it a problem with a ecu?
  2. I also have AE100-1993 car.My problem is little different.It start fine for 2,3 minutes and miss the engine. I tried to get used 5A FE ECU, but i couldn't find. Then I replaced with 4A FE, then the engine miss not more there. Engine is seems to running Ok. But I'm not sure what side effects will come from this 4A FE ECU.
  3. Dear Sir, I have TOYOTA AE 100 ,YOM-1993 car and when it start is fine but after 2 or 3 minutes its drop the the rpm and miss the engine. Check engine light is ON. Then I changed the cooling temperature sensor and it seems ok for 2 days and again the same fault came. PL advise.
