kosala02
kosala02's Achievements
  1. Check the radiator? Most probably your radiator is block.
  2. machan when you put K & N filter ,is it some different between mormal air filter?i mean fuel and runinng condituon.
  3. Thanks sylvi.do u know the part no?
  4. Any one know the price of EK3 K & N Air Filter?.Also where is the place?
  5. thanks machan,chalitha your car is manula or Auto???
  6. is recon radiators good??i checked in maruchi and japan lanka,they told price is 18k.its ok
  7. I checked radiator twice, they said not leak there. But when car is normal temperature coolant coming under bottom of radiator.
  8. When I put the coolant radiator is leak. Anyone know the place buy a Honda ek3 radiator and roughly price of that
  9. i cheked the gascket.its ok,also changed the genuine radiator cap. but didnt slove the problem.every i have to put the coolant for stock tank
  10. normaly praking cemnet floor.coolant not in cement floor.
  11. I put the coolant. But same issue, reducing coolant in radiator.i cant understand what is the problem.
  12. Thanks machan..
  13. I changed the genuine Radiator cap, but still water reduces in radiator.
  14. I have noticed every time heat gauge never above normal level. I am using water after check radiator. I went to Nuwaraeliya 1 month back, but never overheating. Only thing is water reduce in radiator.
  15. I have EK3 1999 model (Multimatic).Car running well. But reducing water in stock tank and when stock tank is empty reducing water in radiator. I cheeked radiator also. There is no leak in radiator and water hoses. I asked Honda mechanic, he told gasket is leak.is it possible. If you know something please tell me.
