Nimz77
Everything posted by Nimz77
  1. please let me know recommended compression Level for nissan pulsar (GA15de) 13bars for Each piston?
  2. Fuel Filter already replaced one month ago with nissan geniune,Injectors are ok as per ASNU LANKA
  3. as per asnu injectors are ok..i will try your advise for start and let you know...again thanks a lot.. any good place to buy GA15De engine ?
  4. Pls find here my ECO test reading Date:2014.01 HC idle :508 2500rpm :276 Date:2015.01 HC idle :455 2500rpm :180 plugs color is dull black
  5. im also having same issue
  6. thanks...but engine cost will be 40-50k ,(only engine block)coil pack replacement done on two months ago..fuel pressure ok..plugs are black..(as per garage they said my car having some fuel burning issue .is this related to low engine compression?) injectors checked at ASNU...they injectors are fine. As per garage they said go for engine replacement.(without opening) pls let me know best most reliable solution ?because repair cost = replacement engine cost do i need to check my car at A*W?but no change for solution
  7. Please let me know best place to get engine for nissan Engine:-GA15DE
  8. need need to crank engine two,three times.(15sec)..but when i park my car in the office ...after 6-8 hours same issue...delay start.any way im going to replace Piston rings,valve oil seal,Gaskets....pls advise// do i need to use genuine piston rings? is there any alternative good brand?
  9. thnaks thanks...but is this good for starter motor?starting issue related to motor ?
  10. http://www.ultimatesubaru.org/forum/topic/52515-difficult-hot-start-after-injector-cleaning/ i think starting problem is related to the faulty injectors .
  11. thanks don...today i did compression test..Results are follows piston wise 10,10,10,9 as per garage ..they said i have get replace Piston rings,valve oil seal,Gaskets...etc. but low compression for delay start? No issue with fuel line New Fuel pump but i will try spraying fuel in to air filter.. is this related to pump relay?
  12. Cam Sensor working ...may be i have to do compression test.because im seeing high oil burning.
  13. thanks a lot....friends...
  14. Still i couldn't find proper Solution...
  15. Today got fixed Steelmate security system ...pls advise best location to mount alarm shock sensor
  16. any thing related to tappet clearances?
  17. is there any issue with ignition coil or switch?
  18. tried but still same...going to check starter motor and battery also recently i have replaced distributor
  19. thanks...but im not seen any check engine light...even no errors for scan....i will check my starter motor
