prasannaek123
prasannaek123's Achievements
  1. When I when to garage in Kandy, The chief Mechanic had a test drive & inspection at the garage , he told me it is coming from inside the gearbox. He also stimulate the sound at the idle stage & show me. After that he checked the ATF & told me it is not good & we will have try by changing the ATF to eliminate the problem. My question is, will it become OK after changing the ATF?
  2. Hi, I have an toyota aqua 2013. This done about 17500kms. From few weeks back a small click noise coming from front driver side wheel area when applying the brake. And when i accelerate again that click noise coming and when speed up there is no noise. This only come when driving at low speeds. Now on my feeling that noise is very noticeable. I went to several garages and check, but they couldn't found any fault. They have checked all the mechanical s which related to braking. i.e. brake pads, calipers etc.I even when when to Toyota Lanka, Kurunagala & its also the same. I want to know, what it can be and place to diagnose this around kandy area.
  3. I am located at kandy, Watapuluwa.
  4. Thanks for the advice. The noise comes from front bottom of the car. I need a good mechanic who the issue. My self I have checked but I couldn't find any reason.
  5. I've got Nissan n16. This is 2003 made new model. 1.6cc Singapore one.. Now it is giving some noises from front & showed to several places & they can't found any problem with it. Noises are coming from the suspension system & like clink & duk noises when going on rough roads. I am in kandy & I want a place where I can fix the issues with it.
  6. Thanks every body. The workshop guys have found an meter cluster & replaced it. Every thing is fine now. Thanks
  7. Still I was not able to find a instrument cluster. Pls help me on this
  8. Hi, My car is Nissan N16ex singapore imported model(Some are Say N17), Auto 1.6cc Recently my car had an accident which was hit by another car to left back side. It was take more than one and half month to repair the car and , when i went to take the car after repairing the instrument panel gauges are not working. ( Those were OK after happening the accident) The ABS motor is continuously running with ABS light is ON. The guy in the repair center disconnected the ABS motor fuse & Start the engine & go for a test ride. The ABS light was ON. They said there is a problem with ABS motor & have to replace it. In the instrument panel no gauges were working Including ODO/TRIP meter & Clock.Only the lights are working. i.e. Air bag check/ Oil/ Battery/ signal etc. except Engine check light. It does not even switch on. Auto gear indicator lights are also not functioning One of the guy in the repair center open the cluster panel & check & found that one smoothing condenser is blasted. After that they have replaced it and there was no success. ABS motor was also replaced and the continually running ABS motor problem was solved, But ABS option is not functioning. They said they need to replace Instrument cluster as well. My questions are 1. Where can i find a instrument cluster for this model?. I have searched in many places and couldn't find this model.( 220 Kmph , auto indicator with digital clock) 2. Why the ABS option is not functioning even after replacing the unit.? 3. Can this be happen after a battery is connected with wrong polarity. My friend said that this can happen like that. I also have doubt after I have seen the blasted condenser in the instrument panel. 4. Does this damage some part of the ECU of the car? Pls help me on this. Pls tell me is there is any place to repair this. I am in Kandy. rgds.,
