Dear experts,
what do you think about this kind of fuel performance chip.
is it harmful to engine or sensors
http://www.ebay.com/itm/PERFORMANCE-CHIP-GAS-FUEL-SAVER-ALL-PONTIAC-AND-SATURN-MODELS-1986-2015-/161394503809?pt=Motors_Car_Truck_Parts_Accessories&hash=item2593dcb081&vxp=mtr
HOW IT WORKS!!
The Performance Resistor Module is the answer to todays high fuel prices and
all of us looking to squeeze that hidden power and fuel economy out of your engine.
Typical gains with our products is a horsepower gain of up to +80 HP, while gaining up
to +25 MPG in fuel mileage due to increased engine efficiency! The way that our products work is by sending a continuous signal through a factory engine data sensor that your Factory Engine Control Module (ECM) monitors. This modified and continuous signal triggers your factory ECM to reprogram itself for a more optimum fuel mixture and timing curve, allowing the full benefits of an expensive power programmer but while retaining the complete safety of your Factory ECM.
The advantage of the Performance Resistor Modules is that they do not directly interface with your Factory ECM. If you compare our products against an expensive $400+ name brand power programmer, they work by interfacing with your Factory ECM via the OBDII port underneath the dash. The expensive power programmers completely rewrite your Factory ECM in order to override your stock tune. The two downsides to this is that your Factory ECM risks corruption if there are any power interruptions or errors within the expensive power programmer, which could require a tow to get your Factory ECM reflashed by your dealership. The second downside is that since those type of products directly interface with your Factory ECM, it will leave a footprint behind in the memory. Many dealerships check the memory for any codes or footprints during routine maintenance, and could void your warranty for using those types of power programmers!
On the flip side, since the Performance Resistor Modules does not directly interface with your Factory ECM and merely only sends a continuous signal through a factory engine data sensor, it will absolutely not leave any footprints behind in the memory since our products are simply triggering your Factory ECM to reprogram itself on its very own, being completely undetectable by your dealership. Our products are completely reversible and your Factory ECM will instantly revert back to the stock settings once removed!
Installation is very simple and we guarantee that anyone with no previous mechanical background will be able to easily install our product within 5-10 minutes. The kit includes a very detailed step by step Installation Guide that will make installation a breeze. There is absolutely no drilling, cutting required to install our products! With our Award Winning 5 Star Technical Staff, you can be rest assured that well be here for you until the end if you need any help or have any questions regarding installing our products!
