Kirikiththa
Everything posted by Kirikiththa
  1. Go to Lasantha Tyre @ Kumaragewatta/pelawatta, he will give you a good discount or JJ @ mount
  2. Hej Seems like you have a gear box issue, I think its related to your clutch and the pressure plate, during the long distances it will get heated and due to that it will have abnormal behavior like engine mis type vibration and/or abnormal jumps when u start from 0, 1st gear and 2nd gear .. this might with the reverse gear too.. better replaced the clutch/pressure plate otherwise it impacts your engine mounts Cheers!
  3. It will cause the fuel consumption and might be an issue for the sliding door.. which might stuck with tires when opening ( this will depends on the rim actually)
  4. Seems you have a trouble in your shock ab-sobers, please check your shocks as they can release oil when the seals are damaged
  5. I'd like to know from Autolanka gurus about the Nissan N16 Engine type, Is it Has any similarities to the VVT/VVTi/VTEC technology? Why is it not good in Fuel? Hope its not only the issue with the air flow sensor? is it a engine defect in N16? Any tuneups to reduce the fuel consumption? please advice with your expert comments
  6. Hi Autolanka gurus, Id like to know more about Nissan N16 Super Saloon 2001/2002 models and it's reliability on Sri lankan road conditions, especially about the fuel consumption and the related maintenance etc. etc. Did anyone recomend to go for a N16? Then Y?, I have some kind of thought of going for a N16 Luxary Edition (Teak dashboard/interior). Any of you recomend?
