MalindaG
Everything posted by MalindaG
Hi All, Can an expert tell me why there's oil like residue deposited under the radiator cap...?? I did a radiator flush in January... Vehicle - Toyota Vios 2003
@iRage I think i found the issue... The hose circled in the attached picture was cracked... Yesterday I get it fixed... Think this was the reason... And yes, fuel consumption was bit high... did 9km/l in city running... no fuel smell...
Hi, Can an expert help me to understand to reasons for the below increased outputs (Specially Hydrocarbon) in my emission test report ? (Compared between last year's & this year's reports) Vehicle Details - Toyota Vios - YOM 2003 Emission Details - Yr 2019 Yr 2020 HC Idel 72 462 2500 RPM 24 276 CO Idel 0.01 0.32 2500 RPM 0.01 0.19 Lambda Idel 1.05 1.08 2500 RPM 1.02 1.01 O2 Idel 0.94 2.90 2500 RPM 0.36 0.69 CO2 Idel 12.66 18.78 2500 RPM 13.17 17.77
Hi Davy, This abnormal wear is only in a small part of the outside of the tyre (as in the 1st photo). As in the 2nd photo, other area of the tyre seems ok... Is it still could be the worn out shock or bushes...?? I'll check the alignment report and let u know...
Hi I have a Toyota Vios YOM 2003... I noticed that there is an uneven wear in the front driver side tyre only in some area (not in the whole tyre)... Does any one know the reason for this...?? Is this due to the low quality of the tyre...?? Tyre brand - GT Radial Champiro BXT Tyre pressure checked regularly, wheel alignment & balancing done...
Thanks for the information guys...
You mean is it to mute the car alarm or to shut down the engine or something...??
Yes, i think... remote is a steel mate remote...
Hi guys, I have a Toyota Vios, YOM 2003. I recently saw a switch like thing in driver side, below the bonnet lever... Does anyone know what is it for...??
Thanks for the info rumesh... ill check those things...
I bought this vehicle 6 months ago... and within couple of weeks after I bought it I did a tune up and the service as I felt a little vibration... it's a manual transmission car, but even after the tune up it does around 9km/l in city limits with A/C... as the previous owner used toyota 15w-40, in my first service I used the same... but last week I switched back to 10w-30 as I thought thickness of the oil caused the low mileage... Is there a connection between low fuel consumption and oil level drop...??
@Rumesh88 Hi... I have a Toyota Vios YOM 2003 Mileage 130k There is a slight engine oil drop but no visual leakage... As you mentioned in one of the previous comments I checked the air filter and I noticed that there are some oil residue in the air filter... To check whether oil baffles are cogged, will that sili sili bag test help or is there another way...??
thanks for the info...
in the last service, the service station buggers have changed the engine oil from castrol 10w-40 to 20w-50 and i drive with 20w-50 for about 4500km... is it ok to switch back to 10w-40...?? vehicle - nissan wingroad yom - 2000 milage - 130,000km
thanks for the info mate...
yeah, there is a sound of air been sucked in when i open the fuel cap, but it only comes when the fuel level is below 1/3...
hi guys, i have a nissan wingroad y11, yom 2000... there's a fuel smell when the engine is turned off after a run... a mechanic checked the line, but there was no physical leak... the smell comes only when fuel is below 1/3 of tank... does anyone know the issue...??
User / Service Manuals - Download
MalindaG replied to Thusiwi's topic in User Manuals & Service Manuals
does anyone have nissan wingroad y11 yom 2000 model service manual...?? -
Hi, Does anyone know a good place to repair auto transmission issues and other issues, around Dehiwala, Mount Lavinia...??
Nissan Wingroad Y11 Automatic Gear Problem And Petrol Smell
MalindaG replied to MalindaG's question in Mechanical problems
petrol issue solved when i pumped full tank. don't know whether it's permanent or temporary. -
since then the starting problem didn't occurred again. yeah, there's a noise like opening a soda bottle when i opened the cap after a run. but i'm not sure whether it's a air sucking noise a gas coming out of the tank. -
yeah. earlier and now it starts in P, on that day it didn't, only the sound when the key is in ON position came eventhoug i tried to start it (i don't know whether it's the starter motor sound). so i move the gear lever and put it in N and gave a try. since then the starting problem didn't occurred again. yeah, there's a noise like opening a soda bottle when i opened the cap after a run. but i'm not sure whether it's a air sucking noise a gas coming out of the tank. -
MalindaG posted a question in Mechanical problems
I have a nissan wingroad y11 (yom 2000) auto transmission car. Two days ago when I tried to start my car, it didn't start. Then I changed the gear into N position started the car again and it started. Does anyone know what the issue is? And I have another issue regarding a petrol smell. When I stop the car and turn off the engine, there’s a petrol smell around the car. I’ve checked the petrol line and there’s no physical leak. And my car does only 6-7km/l in city limits and in outstation 11-12km/l with a/c. I did an engine tune-up, but the issue is still there. Can anyone advice me what should I do?
