shanjeevanm
784 profile views
shanjeevanm's Achievements
  1. I got mine checked. Its the issue with the rack. There are multiple issues related to the rack in suzuki some have issues in the steering column some at the rack end some at the rack itself identify your issue correctly thru reliable mechanics.
  2. it was fine for sometime and the noise is back. I checked with A*W as per them ppl complain the same with grand vitara as well it seems. so what they are saying is, our road conditions are not compatible with the variable rack system what RS has. no solution so far.
  3. pls chk my response below
  4. i got it checked. im going to explain in layman terms since i dont know the technical jargons for these. the issue was this section which i have attached herewith. This section is what connects the rack and the steering column (as i was told), once the gap between the sections connect both ends is tightened i didnt get that noise. however i was asked to monitor if im getting the noise again.
  5. i bought one recently... im also experiencing similar problem. found the root cause and the solution for this?
  6. i bought one recently... im also experiencing similar problem. found the root cause and the solution for this?
  7. i bought one recently... im also experiencing similar problem. anyone found the root cause and the solution for this?
