hyndai
My Vehicle Details
  • Vehicle Make
    Hyndai
  • Vehicle Model
    Elantra
  • Engine Type
    1600CC
  • Mechanical Mods
    manual transmission, ABS
1,434 profile views
hyndai's Achievements
  1. I had the same issue. i did not purchsed the locally available stuff as they are not good quality. I got one from EBAY, a UK seller. it is crystal clear with no RF interference at all. try Ebay. http://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=FM+Band+Expander
  2. Hi as Fixzit said, it had a special connector. its BC5 and took bought it from EBAY. it was not required to install a separate connection to detect reveres mode. once the reverse in engaged, this triggers the camera into on mode. and the resulting signal from camera automatically turns the set into rev cam mode. Thank you very much every one.
  3. Brothers, i brought down a 2011 vitz from Japan and it has a double din player NSCN-W60. Seems like its a factory fitted set. The owners manual of the player is in Japanese and i don't understand a thing. However, there are some pics that show a rear view camera function there. that is essentially there must be a video input port in this player. I removed the player, but there are no labels at all. i am trying to install a rear view camera using the monitor of this player. so you guys have any experience with this player ? can you guys help me to identify the correct connection to connect a rear view camera to this unit ? here is a pic of the player http://cdn.mkimg.car...ct=1b952635e6bf thank you in advance. Kasun
  4. guys i heard that using "3MsComplete Fuel System Cleaner" can really boost up the performance and fuel efficiency. First, is this real? can they improve the conditions? and do you guys know a place where i can buy these? I am from Galle, so have no idea about where to buy. I am sorry if i have breached any rules by stating a brand name, i do not know any other brand. Best regards
  5. Guys, What is the importance of Engine Tune Up? what are the indications that indicates a need for an engine tune up & basically how do we do this? i mean is it a manual work or some thing done by using some specific machine and last not least what would be the typical cost of a engine tune up?
  6. Found a fault in stearing rack, felt a small crack like feeling when turning the vehicle. now the car is in garage, will see what will happen..and they also detected a faulty balancing bar or some thing....some rubber bushes were bad. gonna replace them. bad thing about garages in galle is they return the car with lots of rats, last time they ate my electronic system, wonder what gonn be this time.. thank you for your responces will post the latest nwes soon
  7. Devinda; i do all the changes you have mentioned in 5000km intervals, is it too much? by the way the car is in Galle and only in week ends its been used, so 5000 km means in some cases 7 to 8 months.
  8. Thank you all for the responses, please post keep on posting any suggestion that you think will help me. I ll start with spark plugs and air cleaner..will keep you all posted on this matter. thank u all.
  9. Is it ok to clean plugs? The current plugs are nearing 30000k. Is this too much runnig for a set of spark plugs? Is NGK a good brand? please give me some advices on these. I also think that the air cleaner is also bit used. But, why am i getting this occasionally? Since this happen ocassionally i think we can put aside the posibilty of a faulty air filter. Can this be a break binding issue connected with my hand break fault that i have explained to you, then why on earth the Check Engine light comes out occasionally...hahaha... keep on posting on this topic brothers, i have fixed many issues from your valuble comments...
  10. Guys; help me with this i have a Hyundai Jimmy (elantra hatch back). recently i have noted that it does not have the same pulling power it had earlier, but strangely this is occasional. I can seriously feel like some one is holding the car back. i also smelled some unburned petrol when starting the car several days and it had lot of petrol in it, not just a faint smell. yesterday also i felt this lack of pull and tried to reach some speed, the engine is too noisy and when reach 100kmph i felt a unusual vibration( in the stearing wheel specially) earlier there were no problem reaching 120/130. No unusual sounds nor vibrations. i suspect a faulty spark plug, in morning when engine is cold, it misfired several days with Check engine Lights On. i also had some hand break trouble which led to break binding situation some time back, but i fixed it. I also fill up some gas to A/C system and when turning on A/C i feel a greater impact on momentum than what i used to feel. some info about car; 1600CC DOHC 16V , ABS, All Disk Break, Tires new(Franklin), Wheel alignment and balancing done recently. pls help!!!!!! This is frustrating.
  11. Thanks a lot.......... i will try these places. the animation in Motor maniac's post shows what exactly happend.............hit from the back..no damage to rear window what so ever, then after 3 or 4 days, it burst with a huge sound while it was parked... thanks machanla.......... aruna
  12. Dear brothers i need urgent help from you. I have a Hyndai Elantra year 2000 version, 5 door hatch back model. i need to buy the rear windscreen. i checked with hyundai lanka, they dont have. i also checked several places, but the window is not available. From where i can get this? i think its very rare. please help. i need contact information as wel. thank you in advance Aruna :violent-smil ey-030:
  13. By the way, when i turn on A/C these days i can feel it more than i used to fel it earlier, when A/C was working propoerly. Now i can feel a significant loss of pulling power as i start A/C Could this be a sign of some thing has gone wrong?
  14. Thanks Don!!! that is very informative!! thanks again kasun
  15. Hi Dear all every thing with my A/C was ok. but gradually, withing a periode of 1 month, its cooling effect got reduced. Now nothing. but in early mornings, when engine is cooler, The A/C works! once its get hot, thats it. what might be the reason? what are the costs associated with A/C reparing, like replacing filter, recharging GAS and etc. Thank you all in advance; by, the way, i noticed, that one tube coming from A/C compressor is very hot while other one is ssoooo cold, but the air is not cool. hope you guys will help. BR kasun
