Everything posted by RViji
Beware, Vezels Are Invading The Country. Good Bye All Ion & Prmios.
yes,I found more infor in some old thread. http://forum.autolanka.com/topic/15973-toyota-prius-honda-fit-vezel-recall-information/?hl=vezel probably car dealers are taking the Lankan buyers for a ride,eh?
Audi A4 Diesel Engine Rebuild/does Not Start
Hi thanks for the support and greetings.added about 100km today, i hope this happiness lasts for a while. I think nowadays most car makers are using Engine parts from plastic(even cylinder head unit) to stay cost competitive and save weight, regardless of Japanese or European. That is one reason why I decided to rebuild this engine and run for a while,this Engine is old-school with no known troublemakers like DPF Catalyst,Common rail injectors which need super diesel etc... Even the hi-pressure pump is divided in to 4 parts and integrated in to the Injectors itself,so if one fails,the engine still runs with the other 3(although no pleasure to drive or hear).
Today we tried with feeding the diesel directly from a bucket at the front,and guess what? on the 2nd attempt it started!! and idled for about 10mins until the bucket ran out of fuel. The same procedure was repeated for a few times with increasing RPM only upto 3000 since the engine is newly built. but when we tried to start again normally,it did not. The pump was replaced with a hiace KDH200 tank pump,and then it starts normally!and test drive showed a noticeable increase of response and reduction of noise/vibration compared to before the rebuild. So the problem seems to have been also with the lo-pressure pump in the tank(may be not delivering enough fuel flow to start after many months of inactivity). maybe the direct diesel solution got rid of any air stuck between the feul filter and the pump duse injectors. a Scan afterwards,revealed no error codes(but same as before,so I am skeptical) I guess I will run this for a while,before taking to the dealer for a scan. Going to them in the first place would have not helped anyway,I do not think they do complete engine rebuilds.(they did not even have the parts available for such repairs.) but In SL, we have no choice but rebuilding to keep these dark horses running. And I hope the pain was worth it.
Kia Sorento - Steering Problem
in a different vehicle(Suzuki Swift),Electric Power Steering motor bushes were worn out,and replacing them solved a similar issue. Does the Sorento have EPS?
sorry for the confusion. what I meant is that fuel is coming out of the hose from the fuel filter attached to the engine durin IG ON. But no way to check if it is reaching the injectors (like common rail you dont see fuel pipes reaching the injectors,the whole fuel supply is inside the engine head),without opening the cylinder head again(means new gasket required). Ruwan also suggested to tow it to his workshop,and said maybe that ECU flash memory has been deleted after 3+months without battery supply. guess I will try this diesel bucket challenge before finally calling the car Carrier...
Place To Buy A Good Horn (Around Colombo)
Yes,i also like the deep tones they produce. As long as you buy from a renowned shop with good Warranty/afterservice,should be no problem I guess.
new crank sensor was fitted today. now RPM needle moves when cranking,but still not starting the Engine. Today the bass suggested feeding diesel from a bucket(with a Hiace KDH200 tank lo-pressure pump),directly near the filter and see if anything changes.apprently it has worked before in a Hiace before,but that is commonrail engine. has anyone tried this method before?will it damage the engine? I kind of want to try available non-destructive methods,before towing it to the dealer.
Reviews For Latest Mazda 6
basically you r right machan. but my point was why the Civic engine with same displacement gives more than twice the power as this Skyactiv technology from Mazda? why arent the Japanese getting the most juice out of their engines first,before adding extra motors and batteries to increase power?
doesn't 2litre with only 155HP sound a bit low? Euro engines(even the Civic Type-R,developed in Germany) already get 280+ HP with 2litre GDI engines. The 2015 Type-R will come with 300+HP,it seems. http://www.auto-motor-und-sport.de/news/honda-civic-type-r-auf-dem-autosalon-genf-top-civic-ab-2015-mit-320-ps-5723103.html sorry to go OT.
Hi, it stopped working after a few weeks and some parts were rattling inside. probably some production defect. luckily the eBay store where he bought it(in Germany,yes they also sell Indian made horns there) gave a full-refund after seeing the video clip he sent them,without sending the parts back.
thanks for various comments. I forgot to mention that we had the tapper cover open,so we could see the injectors were getting pressurized by the rocker arm attached to the cam shaft.and injector wires were giving electric pulses. Yesterday we noticed that the RPM meter does not rise during cranking,so upon further searches on internet ,it pointed to a crank sensor problem. And it was also confirmed by inspecting the inductive sensor . another similar working sensor(Hyundai),showed a voltage when a metal piece is moved towards the sensor tip. with our sensor it did not. The cable at the sensor end seems to be damaged.the two wires inside are embedded into the insulation,and one is mesh-type. So I see no chance of repairing.since it seems like it needs to be replaced anyway,now waiting until the new sensor arrives.
thanks guys,fingers crossed.
Hi,this is a PUMP injection system,no hi-pressure fuel rail(common rail) ,hi-pressure fuel pump,catalyst. http://vwts.ru/engine/ajm/ajm_eng.pdf the only pump is inside the diesel tank,and it sends fuel to the diesel filter when IG is turned ON. the pressurization of fuel to 2000bar,is done inside the injectors itself. since there is no pump,Bass has not sure where to check fuel pressure, and where to insert the compression gauge,glow plug holes or injector holes? ps:I tried asking the Agent first about replacement parts,he sounded quite sarcastic wondering why I wanted to rebuild the engine(his words were,"oowa hadanne naa").and none of the engine parts I asked about were available,and he said it takes few weeks to bring them from S'pore!so I got in touch with this shop in Watta(D@rsana motors) and they were quite fast when I brought them my removed engine parts to find them inside the shop.
I really doublt this is some electrical fault,these cars are known for their simple but reliable electricl system. and when checking with a line tester(LEDbulb),pulsing voltage was seen at the injector supplies. the car is in Galle,but I guess no VW specialists in this area?plz PM me if you know someone.
Help me make the best choice for first car
for that range you could get a Euro diesel car,like BMW E36,Audi A4 . good handling and confort,fuel efficient,and fun to drive. but if you think about resale value,Maruti Alto would be the best choice for this price.
German manufactureres like Bosch,Hella have this deep tone which I really like. but make sure it is not made in India,one friend had a bad experience..
thanks for the comments. The scanner is Launch X431,high-end(but generic) scanner. but if the IMMO is locked,the light on the dashboard should be ON,right? according to this link,if the IMMO or ECU is kaputt I will be in some trouble. http://wiki.ross-tech.com/wiki/index.php/Immobilizer#Immobilizer_Generation_4 since I do not have the PIN anymore,the dealer has to connect the car to the VW plant in germany that manufactured the car to unlock the IMMO or something?(sorry ,no clue) today the Bass and I opened the engine ECU and checked,there were no visible damages like burnt PCB track/components. This engine seemed very simple to rebuild,with only 3 sensors(Crank,CAM and temperature) unlike petrol EFI engines. all the parts came from a well known shop for EU parts in P'Watta. I did not feel that a VW specialist is required.And I do not want to take it to the "specialist' Agent Sen*k ,for obvious reasons. How to check if the above 3 sensors are working,if the scanner does not give any errors? I really liked this car because it was economical and powerful at the same time.And it did not need superdiesel like most JAP commonrail engines.
timing was set according to this link for AJM 115PS engine. without the special tools of VW,I hope it is correct. If the timing is at fault, does it not show on the scanner?
Hello friends, We did an engine rebuild for our car when reparing an oil leak. Audi A4 ,AJM engine 1.9tdi diesel, year2000 changed items: valve seals,valves,gasket,piston rings,crank bearings,bigend bearings 4 cylinders were re-sleeved using same pistons with new rings everything is back together now,but the engine does not start when starter moves. the Baas did a full scan with a Launch scanner and no error codes were revealed. and diesel is coming to the injector lines(Pump injectors,not commno rail). it was working fine before the repair,except for oil leaking from one crank bearing. Bass is coming up with new theories,ECU is burnt or IMMO unit is locked.but i see no lights on the dashboard. Any expert ideas where to look for problems? thanks in advance.
