Everything posted by [email protected]
  1. Hi Guys after a long time, i am currently using a es8 need your advise on a Honda HRV 2000 model 2w drive which i am planning buy need to know 1. how much it does on petrol. 2. parts prices and availablity. 3. Second hand value. Thanks Khasim
  2. Hi don thanks for being judgmental as it was a mistake from my end to select solved as I thought that marking solved would help the other members who would need your valuable advice. Thanks a lot guys for taking time to text your advice.
  3. My mec has replaced the amarcha/rotor hope it will last. As I believe the main components are replaced.
  4. Well I got the vehicle now with the replaced rotor well hope it will hold on,as the mechanic said nothing to worry as now the major potion of the alternator has been replaced, hope it will be OK. Well I believe that the mechanic is concerned on the prices and in the process tries to repair stuff as the alternator costs about 20,000. As after replacing the rotor costed only 4000 To replace rotor.
  5. He says the rotor is damaged,
  6. Hi guys alternator issue came up again,earlier the other componant were replaced except the rotor was repaired because due to unavailability,do you guys think if the rotor is replaced it will last as my mechanic has found one pls advice as I am tired of the brake downs.
  7. Thanks guys it was sorted out as rumesh said it was fault connection. Tx all for all our replies.
  8. Thanks any suggestions I called tech motor they didnt have sensors
  9. Hi guys need ur advise on where cud I fined es8 recon spares as I need to replace a Abs censor as the alternator issue is two different issues.
  10. Tx guys for all ur replies got the alternator repaired. Need to see how it will run!
  11. Tx guys for all ur replies got the alternator repaired. Need to see how it will run!
  12. Pls text Mahesh no thanks.
  13. How much do you tink it wil cost and where can I buy one.
  14. Guys. Tx for your inputs Guys but my batery light started sparking luckily got near a garage they said it is A faulty alternator. What do you guys recomen to replace the alternator or make the same as I cannot move the vehicle currently.
  15. Tx will try it.
  16. Hi Guys just bought a rec es8 2002 one month Back facing a issue as my ABS light is permanently on from yesterday. Pls advice what to do.
