ravindasenarath
Everything posted by ravindasenarath
  1. Can you please post the url to that post here?
  2. With all the respect mate. I used search. I really wanted to get answers for my questions without bothering anyone. I found some posts but I didn't find answers for exact questions I have. I always remember autolanka forum people being friendly and helping out others.
  3. Hello everyone, I have a 1999 Mazda Familia BJ5P. From the time I bought this I had the feeling that the visibility on night is not good. Current bulbs are not that good it seems. So I wanted to insert a new bulb set. I don't have much knowledge on headlight bulbs. I did some googling and talk to some friends. I'm expecting to go for a halogen bulbs. Friend of mine said Xenon is tend to burn of quickly because of moisture. I also herd that I can add a relay and go for a bulb with higher watt. So I would like to have some advices on this from you guys as I always had(Which always helped me to get the best decision). Following is basically what I would like to know. What is the best bulb(In term of visibility) for a non HID headlight? - ( Brand name etc would help ) What is this go for a higher watt bulb with a relay thing? It is safe for car's electric system? Thank you
  4. Fan belt of my mazda bj5p broke yesterday. I brought a new one and try to install it by myself. After some struggle I was able to install the new one(struggle was to remove the A/C and power steering belt). I tightened the fan belt some what using the adjustment and did tighten the main bolt too. Then I started the engine. For first couple of seconds engine worked quietly as expected but after that fan belt start to give a loud kiri kiri sound. I though the belt is too tight and try loosing it a belt but didn't help. I haven't done this before so afraid to tighten more. My question is is this because belt is loose or something else?
  5. Yes it includes everything. Condenser, Fan motor, all rubber seals replaced, new hoses, etc. Mazda spare parts are expensive.
  6. I repaired my A/D from ACTO A/C Repairs Nugegoda and I think I could recommend that place to anyone else too. Map - https://www.google.lk/maps/@6.8746881,79.8979251,281m/data=!3m1!1e3 Job : Unfortunately one of previous owners of may Mazda BJ5P has replaced it's condenser with a bad non Mazda one. It has been leaking( I guess the previous owner has top up the refrigerant when he was selling the car bcz I found A/C as good at that time). It had a bad cooling fan had to replace it. They Cleaned(did it very well) all parts. Changed compressor oil. Replaced all rubber seals. vacuumed the system. System filled with refrigerant. Checked and verified the performance. Cost : 20000 I haven't done a A/C repair before so I'm can't comment on the price( Feel like bit hight but I wouldn't mind since I got job done well.
  7. Thanks @Don Guys, If you can add a google map link of the workshop you recommend that would be wonderful isn't it?
  8. @Crosswind I couldn't post an answer to you earlier. Yeah it is not cooling enough. When I buy the vehicle is wasn't cooling that good. It was OK for one or two people, but when five people on people start sweating. So I went to a local A/C repair guy at Galle. Called "Kankutta"(No disrespect but that is the name people know him by). He said he need to disassemble whole A/C system to find whether there is a leak of refrigerant. He also suggest lets top up refrigerant and check after some time as a option. Since I needed the vehicle that evening I ask to top up refrigerant( he says it around half of what should be there before topping up) . He ask for 1500 and says he is only charging for the refrigerant. How ever after topping up A/C was super cool and there was condensation on the pipe. Now it has been around two month or more and cool of A/C got law by time. So I guess there must be a leak right?
  9. Hi guys, I have kept an eye on this article because I need to fix A/C(not cold enough) of my Mazda BJ5P. I would like to do a full repair on the A/C system so I like to find a place that do good clean job with proper equipment. So anyone know such a place around Nugegoda, Maharagama area? BTW I saw couple of places in this tread(aps - panadura etc).
  10. Thank you for your comments guys.
  11. Normally at service centers apart from washing and vacuuming the car they spray oil under the vehicle. I expect this is to prevent rust. But does it really help that way? Isn't there any bad effect to rubber parts(bushes etc) cause of oil since rubbers is tend to soften because of oil.
  12. Guys going to go for a Mazda BJ5P 99 special edition. http://www.autolanka.com/ad.asp?ID=174989 Got checked with mazna mortors . Have replace front right sock mount other than that all good. Wish me luck
  13. Why people do this? How can to current owner transfer vehicle to someone else? Does this have any effect on the price of the vehicle?
  14. This must be a very stupid question. What does "open papers" means? Is it that car owner doesn't put his name in the book.
  15. Guys a advice or two on Mazda BJ5P 2000/2001as well there are 1300 cc and 1500cc , YOM's 1999-2003. Help on reasonable prices for these models please BTW I heard that BJ3P/BJ5P is not good on fuel and parts are expensive. Also wanted to know the reasonable price for 1999 and 2000 fb 15's ( People normally put 17/18 )
  16. So these cars like fb14 fb15 does they less values when the engine is 1300 cc? I saw a fb 15 1300 cc for 15M. Does this mean that it is not good in performance with 1.3 engine? BTW I'm staring to like the Mazda BJ5P 2000/2001
  17. Gave up the idea on this fb14.Thanks for every one to helping me understand(Even using "Deke Deke polla" ) Trying to go for a fb 15 may be. May be a Mitshubishi CS 1. There are couple of Honday City vehicles . Can anyone give a comment on this please.
  18. Appreciate your reply @Davy I have one requirement that is I need Automatic transmission. I'm expecting my farther to drive it. By the age he is reluctant to drive the manual AD Wagon(VB11) we currently have. There is this branding market price clearly. 1996 Toyota is marketed higher than 1998 Nissan, Mitshubishi and Mazda is always marketed below Nissan and Toyota. Is that just the brand or does Toyota really better than others? BTW what will you guys offer for this car? What bargaining point I have to ask him reduce the price.
  19. I did't mean to be harsh or anything. I really appreciate you guys feedback. Of course I need to make best our of my money(My mother's and farther's actually. Buying it for family not for my self) CK1 97-99 is around 15M CS1 is around 18-20M which is totally out of my budget. I really like this car by the way. I was one CK1 2000 for 14.5M may be registered in 2000 There are Nisan AD/Wingroad Y11 for around 13-14M
  20. With all the respect guys, after reading your comments I turn ###### and autolanka upside down trying to find a car with YOM after 2002 at least. But I couldn't. Price tag is closer to 20 for cars after 2002. Honda City 2001 is price around 16M. I have been searching for a car for couple of months. Nissan FB 14 98 cars are always priced around 15M. They are selling them for that price very quickly too. I'm going to do a test drive and look for something before seal the deal. On the first inspection what I notice is this guys has done all services repairs on time. I bounce the car and suspension responded well. He has maintenance records available. He looks like a guys who use the vehicle very carefully. I have inspect around 10 - 15 vehicles in last couple of months. Compared them all those what I recon is this car is in really good shape.
  21. Is 15.75M a good price for a b14(He ask for 16 and reduce to 15.75). This one is very well maintained, full option, 1300 cc, 180,000km, first owner, original paint, new tyres, new battery. I feel like it is bit high. But vehicle is in such a good condition trying to bargain more may be I'll loose the vehicle.
  22. Hi friends, When you are buying a bit old car ( 10 - 15 years ), when you went to check the vehicle what are the specific things to check. I'm going to to buy a car around 1.5M. So my choices are Nissan fb 14, Nissan AD ~1999, Nissan wingroad ~1999 etc. Following are the things that I usually check. Body(specially edges for rust) Spaces between doors, bonnet buffer fittings etc Whether all doors close and open gently I push the car down in four corners and check the bounce. As per my knowledge if it bounce passing it's original height from floor suspension is bad. Radiator over flow for color, rust Checking for rust under the radiator cap Engine oil level and oil colour Any oil marks/leeks in engine Try to rotate radiator fans by finger ( to check whether they turn gently) Break fluid colour, thickness Transmission oil level ( Usually I couldn't find the dipstick for this) Power steering oil level ( Where is it ? ) Start the engine and listen to the sound (whether it run smoothly) Put hand to the tail pipe and smell for petrol Check inside of tail pipe for oily black stuff Interior stuff ( check whether all works ) Check whether wheels wobble I learn these by watching youtube videos . So is there anything I'm doing wrong or any other things that I can check. Perhaps Sri Lanka specific things to check or things specific to car modes that I mention.
