dinuka888
Everything posted by dinuka888
  1. Restomod is a great idea which has never crossed my mind. Thank you @iRage.
  2. @Gummybr Thnx for the comment. I will not do it in an illegal manner ofcourse. I'm thinking about obtaining a permission from rmv before changing either the engine or body. Also the safety should not be compromised due to any modification and that's where I need opinions and insights. You are correct, if this fails what I have to do is restoring the 720 🙂
  3. Dear experts, I'm seeking the advise from you on my dream project of swapping a 1994 (d21) body and a TD 27t engine to an old datsun 720 chassis. 1. Is it mechanically possible install new engine and body to old chassis? 2. Will I be able to convert the old suspension to new one? 3.what will be the legal aspects of such an engine and body swap (if it is mechanically possible)? 4. What are the other things to look at before doing such a job? Thank you in advance.
  4. Hi, I am using a Nissan March (manufactured in yr 2000) which has run 127,000 kms. Recently an engine miss came up in the cold start. My mechanic removed the throttle body and found a lot of carbon built up inside it. He cleaned up the carbon and engine miss was gone... However when he removed the throttle body, I found some engine oil inside the air intake manifold. When I ask it from him he told that it's normal and is nothing to worry about. However, I am curious about the reason how the engine oil flows to air intake and is it a symptom of a much bigger problem... Experts in the forum, pls help me to solve this out... ☺️Thanks in advance....
